Question about Flat Panel Televisions
Menu not available on my philips lcd/hd ready tv
Cannot get the menu up, just says not available
4 Suggested Answers
  • 4402 Answers
SOURCE: wrong remote for tv
have to purchase a compatible remote
Posted on Dec 03, 2007
  • 4402 Answers
SOURCE: lcd philips tv
unplug and wait and hour and plug back in..
Posted on Dec 06, 2007
  • 41 Answers
SOURCE: How to upgrade Samsung LCD TV from a SD Tuner to HD Tuner
Not to my knowledge there isn't. Sorry maybe you can apply for the discount DTV card to buy the settop converter while there is still time. Go to it takes a while to get the discount cards so act fast.
Hope this helps
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: Philips 42PF9946 upgrade
i am wondering the same thing. the tv is great but i dont want to change it but i want to get hd...
can anyone help
Posted on Nov 28, 2009
0 characters
1 Points
The volume controls on both my remote and my Philips flat HDTV 37PF7320A 37." How do I fix it?
Read your Philips setup info that came with your tv very carefully and also if applicable read your cable box setup info very carefully then set every thing up like it says also check tv audio menu and make sure the audio is set to on
Sep 13, 2014 | Philips 37PF7320A 37 in. HD-Ready LCD...
No picture problem on Philips Flat TV 37PF5321 37 in HDTV-Ready Telvision
I am suffering from the same problem. When I turn on I get sound but no picture, although I do get the backlight coming on when I turn it on, I then get about 1/2 a second of picture then nothing. Even if I select TV specific functions such as the menu, I get no menu screen come up.
Any ideas out there?
Jan 09, 2011 | Philips 37PF5321 37 in. HD-Ready LCD...
My tv keeps reverting to the Philips TV Menu
If that TV has a 'menu' button on the front of the set, make sure nothing like coca-cola has spilled into where that switch is located. I would try a different remote in case the remote is getting flaky....
Oct 21, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Trying to find a port for sound input on Philips DVI LCD TV.
If it is two-channel sound, the 'line' inputs should be color-coded as red (right) and white (left).
Feb 22, 2009 | Philips 23PF5320 23 in. HD-Ready LCD...
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Philips 30PF9946
1 step can confirm if you can fix this. Press menu. If you can get a menu its fixable if you cant its in need of major repair.
Sep 12, 2008 | Philips 30PF9946 30 in. HD-Ready Plasma...
26" Philips HD ready tv (LCD)
Nothing much you can do. The soft plastic will get worse if you try anything.
The screen could be replaced, but would cost more than the TV.
Jan 29, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
Flat Panel Televisions Logo
565 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
