Question about Mitsubishi WS-55859 55" Rear Projection Television
How much does it cost to repair a power supply circuit on a Mitsubishi WS55859 unit, parts and labor?
  • jjday3 Sep 30, 2009
    I took it to a repair shop and they told me it was a power supply circuit problem. Several parts would have to be replaced in the circuit and that the total cost is $450.00
    The green light in front blinks constantly but the whole unit does not power up
  • SD Tech
    SD Tech May 11, 2010
    If possible, tell me what the set does? If it comes on for a moment and then the power light goes off--do the self check---press and hold both Menu AND Input buttons on the front of the TV for 5 seconds and release both--power light will blink a two digit code----for example 2 blinks, a pause and 2 blinks---it will repeat this 10 times.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
Ok, I know this song--this set has a receiver built into it(DM board) it is a large metal box on the left side as you look from the back--usually it just needs 4 1000 mfd 16 volt caps and one or two fuses on that board replaced---450 seems a bit high----that receiver while large has only a few screws holding it in and 4 or 5 plugs
It is a $$$$ decision----if you look thru all my solutions on this site you will see I have answered this question for many other people who have this type of set with the same problem.
Let me know if I can help you---
Regards, SD TECH
Posted on Sep 30, 2009
Lg flatron L192ws DEAD CAN IT BE FIXED. shows no lights - nothing. Changed power leads but still dead.
A dead monitor indicates a power supply problem. If unit has an external power supply and you have have substituted it with another known working supply and the unit still does not work, then the problem lies within the monitor's circuits. Yes, it can be repaired, but it might just be cheaper to replace it due to high labor costs.
Jan 27, 2014 | Computers & Internet
TV does not power on - Mitsubishi WS-55819
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 12, 2017 | Mitsubishi WS-55819 55" Rear Projection...
Hi I got PMP3000 and all of a sudden in the program smoke came out of the unit and I unplugged the Mixer...I have given it to repair and they saying the Main power SMPS has blown out..they charging too...
Sorry... you likely have one of the power amp channels bad as well. One does NOT replace the power supply, instead repair it. You need a competent repair shop. I can tell you what parts are blown on the supply. They cost about $30 max for parts to repair the power supply. There usually is about $15 of parts blown on the amp that caused the problem and significant labor to repair the amp portion. If the smoke was dark or heavy, it was likely from the 0.03 ohm metering resistor on the bottom of the amp circuit board that caused the original problem. If one replaces the power supply and turns power on they will find one side of the amp doesn't work and MAY blow the power supply again immediately. I have repaired several of these units and have walked others through the repair sequence as well. You can contact me directly by email for more info if you need it. Unless you can find a competent repair shop that replaces components, including work on surface mounted boards, the cost of the module parts AND availability will preclude repair. The amp module is another $155 after the power supply is repaired if a channel is bad and one chooses to replace rather than repair.
Apr 19, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
The timer light keeps flashing and there is no picture after there was a lightning surge
Sorry to inform you but this is total disaster. The power supply and possibly the display boards have been compromised. TV;s and other sensitive equipment neeed a power surge protector boad. The cost to fix this is around 500-600 dollard. However if you have household insurance a claim can be made if you are covered for FUSION. Parts but not labor will be paid by your insurance company. Buy a surge protector board, $25 for the future protection of expensive electronics
Please rate my help++++Thanks for using FIXYA
Jul 30, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Dead
The power supply board probally dead,not worth repairing,beacuse the power supply board part and the labors of the Tech. the cost to u could be same amount of money to buy a new one.The new one cost only about $100 dollars.
May 28, 2010 | Spectroniq Portable 7" Widescreen DVD...
Power does ot stan on
You got a issue with the power supply if the green light goes off and does not bring it back to standby.
One of th issues could be a bad capcitor, A fuse, a resistor its hard to tell without me doing a visual inspection on the unit. I would have a estimate done on it if it cost more then $150 upwards it would be in your best intrest to replace the tv at that point. But I would have the power supply checked.
If you like my advice please rate the solution.
Thanks
Rulds2008
Fixya Expert moderator.
Oct 09, 2009 | Mitsubishi VS-4544 45" TV
WS55859 shuts off by itself after being on an hour or so, will turn back on after waiting 5 to 10 minutes
If the fan is running (they do fail fairly often), your power supply is progressing toward complete failure. Your description points to a thermal problem whatever the source.
Check fan operation first and if it is running, locate the power supply which will have the larger electronic components on it with several larger transformers and chokes.
Get the part number (if there seem to be two, the one on a label or stamped will be the completed board) and contact Mitsubishi's closest service center to inquire about the price of repair of the assembly or replacement cost. These may not be far apart.
Apr 02, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Blinking green timer light on Mitsubishi WS 55859
You can get the repair kit which has the capacitors you need plus a cd with the repair instructions and full service manual at the following link for 35.00 with free shipping. Your model is the V19 but the V21 is the same kit you need as the V19, 20 and V21 are the same DMs Just click on the repair kit catagory and you will see the V21 DM repair kit. and if you leave them a message they will include the info for the WS55859 on the CD.Heres the link.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Hitachi 50v500 tv
You may want to find a service shop willing to troubleshoot the power supply vs replacing a $300+ part. Labor will still be a few hundred but parts would be minimal.
Jun 19, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Mitsubishi 65909
I bought the mitsubishi black diamond gray 65819 is under warranty and had same problem , turns off like after 2seconds ,it can be fixed people but u need a sears tech, I had one come out and was told they no longer can get the part ,but he had to take it to repair it and yes its was a steal for me ,depending where u live the cost for me would have been $350 for part,$200 labor its the board that the power cord is connected to in tv... I live in s.a. texas , the unit that set up the service is 9905 ,the repair unit is just down the street from them off culebra so if u get tech says cant repair it this one does,it helps if u have the warranty or protection agreement
Jan 27, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
397 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
