Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
Is it difficult to replace a
I had an authorized GE repairman out today. My GE Profile built in dishwasher PDW7880G00SS was diagnosed as needing a new "pump outlet boot" and "short bottom door seal"? Is this a DIY project if I order the parts? I am asking because the parts are only $35 and the $251 repair bill is almost entirely labor charges. It sure would be nice to do this repair myself.
SOURCE: How do I remove the top rack on the ge profile built-in dishwashe
FOLLOW THE RODS THAAT HOLD THE BASKET AND AT THE END THEIR WILL BE A PLUG! IT WILL COME OFF AND YOU SLIDE THE RACK OUT THE PLUG USUALLY HAS A LITTLE LIP YOU NEED TO EITHER PUSH UN OR OUT TO REMOVE
Posted on Nov 30, 2008
SOURCE: dishwasher leaking
There is a front door seal that may be the issue. It seals along the door sides/top and continues under the door to seal the bottom surface when closed. Mine pulled out of the seal channel under the open door where you can't see it without a small mirror. The seal took a "fixed set" out of the channel so now it will not stay put. It requires replacement.
Hope this helps.
Posted on Feb 09, 2009
ginko
  • 19396 Answers
SOURCE: GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Posted on Mar 13, 2009
  • 9 Answers
SOURCE: I have a GE 24 in. GSD4030Z Built-in Dishwasher that leaks
you may have a pinhole in your drain hose
Posted on Apr 20, 2009
SOURCE: GE 24in GSD980X Dishwasher water leak in pump &motor area
I had the same problem. There is no way of replacing seal/joint between pump and motor. It can't be taken apart w/o destroying parts, it only comes as an assembly. Costs around 130$ for pump/motor assy, so it might not be worth it.
Posted on Jun 12, 2009
My ge profile model # gsd5132f02ww is not draining the water.what to do?
Max Power :Most likely You need replace MOTOR/PUMP ASSEMBLY GE DISHWASHER on the dishwasher as it sold asone piece.
Jan 28, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Electricity went out last night. when i get up this morning, it is making a high pitch squeeling noise and now none of the buttons work????? its a ge profile dishwasher
The electricity probably "surged" when the power came back on. It sounds lke the conrol board may have "fried". Call the repairman and get an estimate.
Mar 29, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dish washer doesn't fill up with water
The water inlet solenoid is probably weak and needs to be replaced. If you can't do it yourself, call the repairman.
Mar 24, 2009 | GE 24 in. Profile PDW7800 Built-in...
I set the cycle and push start and the breaker kicks off
It could actually be the breaker itself. If not, there is a "short" in the machine. The likely place for the short is the water inlet solenoid valve which is replaceable. If not there, then you need to call the repairman.
Mar 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
I have a GE PDW 8200 Dishwasher and there is standing water in the bottom of the tube. Why is there standing water after a complete cycle?
If it is older, the pump may not be draining the machine completely. The impellers, which is what acually moves the water could be clogged with yuck and could be cleaned if you can take the machine apart. If you call the repairman, he will likely replace the pump and motor.
Feb 24, 2009 | GE 24 in. Profile PDW7800 Built-in...
The panel on my ge profile ss dishwasher is not working...
At first thought, it sounds like the control board has gone bad. Make certain it is properly plugged in. If no luck there, call the repairman.
Feb 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Nov 30, 2008 | GE 24 in. Profile PDW7800 Built-in...
Replacement Door Panel for GE Profile Dishwasher
Are you trying to replace the microwave door or the GE dishwasher. Either way, www.applianceart.com (under the stainless steel section) has this roll of stainless material that you apply to your appliances. I saw it on the "Today Show." Its basically faux stainless. We put it on our refrigerator and it looks and even feels like real stainless steel. Its really cool. I think its called stainless foil or something like that. Also if you're looking for a stainless panel for your dishwasher they sell actual stianless panels there too.
Nov 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
61 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
