Question about Honeywell Programmable Thermostat Heater
Help! I'm cold. Thermostat went blank. Going to
Help! I'm cold. Thermostat went blank. Going to try replacing the thermostat. Does the brand or style matter? Right now, going for the lest expensive.
  • Honeywell Expert
  • 252 Answers
Just determine what kind of system you have and make sure the new stat will work. (did u try batteries in the old stat? Is the power on to the furnace?
Posted on Oct 01, 2009
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
Home air condition thermostat is blank. My home's central air condition stopped working. So the first thing I did was check the thermostat and it was blank. I then went down to the basement and got the...
Put new batteries in the thermostat. Make sure that the switch that power the furnace is in the "on" position. Sometimes people mistake that switch for a light switch and turn it off.
May 23, 2014 | Heating & Cooling
Set temperature, it goes past it, then it keeps going down until it shuts off
You can test the element by bypassing the thermostat. The element should come on and stay on, probably glowing cherry red. If it will continue to do that for an hour, then you know the element is good.
The problem sounds like a classic thermostat problem. It will come on from cold and up to temperature, but as it drops, the thermostat doesn't click back in because it is stuck open. Its sensitivity is gone, but when it goes cold, the temperature change is big enough to close the circuit.
Sep 17, 2017 | Masterbuilt 20070106 Electric Smoker
Honeywell thermostat went blank
Hello, the thermostat will go blank if there is no power being sent to it, this could be due to a burned out transformer, or a blocked condensate drain which has a safety switch attached to it. You can use a shop vac to clean the line by attaching the hose to the end of the 3/4 inch pvc pipe. If that does not help a new transformer will most likely be needed
Nov 12, 2012 | Heating & Cooling
Honeywell digital thermostat went blank, ac unit wont come on, its an 8400c, no breakers tripped
This thermostat has batteries. Try replacing the batteries. You may have to reprogram and make sure it is on.
Jul 18, 2010 | Honeywell Programmable Thermostat Heater
Carrier a/c thermostat was working fine, then display went blank!
if it has no batt I would ck transformer for 24to26 volts no voltage replece transformer be sure trans has 115 volts to it trans should be in furnace section
Jun 09, 2010 | Carrier 38CKC030 Air Conditioner
The thermostat worked correctly for months then
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need
May 10, 2010 | Honeywell Programmable Thermostat Heater
Our Robert Shaw thermostat 9520 just went blank. Do you have any ideas, nothing is working?
Remove the cover by using a coin or screwdriver to prise it off. Insert the coin at the left side between the backing plate and the the cover, and twist.
Romove old batteries and insert new ones.
Mar 06, 2010 | Shaw Robert RS-9420 Thermostat
Honeywell thermostat t8400c intermittent blank screen
It actually sounds like the batteries are going dead if the 24v from the furnace are not providing the power to the thermostat.
Sep 28, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
597 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
