Question about Canon BubbleJet i560 InkJet Printer
I changed ink on my Canon i560 and now it won't print
I changed the ink and now it flashes the orange light 5 times and then the green. I have rebooted, I've turned off the printer and then back on and still no change.
  • 403 Answers
Go to this link below. Just copy and paste this link to get all the information for your unit from phone numbers, PDF manual, drivers, and more.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=232&modelid=9282#DownloadDetailAct
Hope this helps, let me know if I can help you with anything else.
JimmyC
Posted on Sep 30, 2009
Testimonial: "I now know what the problem is. It looks like it is cheaper to buy a new one than spend any more time on this printer."
Can I reset the EEPROM of a canon print head?
Reset Procedures for Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
you done.
Aug 14, 2012 | Canon BubbleJet i9950 InkJet Photo Printer
When I turn on my Canon i560 printer the light blinks orange and green and will not print anything. I've tried to turn it off and on, unplug it and nothing seems to be working. What can I do to fix it?
try this. It is the reset for the waste ink error (8 flashes)
1) With the printer power OFF, while pressing the Resume button, press the Power button. (Do not release the
power button.)
2) While pressing the Power button, release the Resume button, press the Resume button again twice, and then
release the Resume button and Power button.
3) The green indicator flashes during initialization.
When the indicator stops flashing and remains on, press the Resume button 4 times to clear waste ink message.
(The indicator toggles between orange and green each time the Resume button is pressed.)
4) Next, press the Power button, and the green indicator will light, and the function will be executed.
5) Turn off the printer then back on and error should clear.
Aug 04, 2010 | Canon BubbleJet i560 InkJet Printer
Canon 1560 error - orange light blinking 5 times
It's mean "Print head not installed/Defective print head".First open cover and remove the ink cartridges.Then open holder and remove the print head.Clean the contacts on printer and print head using piece of cotton and some alcohol.Then put back all again.If the problem persist you need to replace the print head.It's part number now is QY6-0064, because the old QY6-0042 is discontinued.
Oct 29, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
Blinking in orange 5 times
Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Flashing orange light - restarted printer - still problem
My i560 printer will not print. The green light flashes once then the orange light flashes five times, this then continues all the time.
What can the problem be ?
ED.
Aug 23, 2009 | Canon BubbleJet i560 InkJet Printer
Why flash by 5 times the orange led?
Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
3. Release RESUME
Good Luck, I hope this helps?!
Aug 12, 2009 | Canon PIXMA iP5300 InkJet Photo Printer
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
8. Your printer should respond as normal.
Please remember to rate all Techs who assist you for free :)
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560
may be ink level is too low,check it first,make sure delete the all pending documents
regrads
prasanna
Mar 07, 2008 | Canon BubbleJet i560 InkJet Printer
I560
If you are lucky clean the contacts on print head or change the waste ink absorber may solve the problem , if not you need to change the print head , part code:QY6-0064 or QY6-0042, about 38 $ on Ebay.
Here is also the manual reset procedure for I560 (and other Canon printers ):
1. Start with the printer OFF
3. release RESUME
5. Let green light blink until printer is done moving print head.
6. Select functions below with RESUME press POWER to execute:
Number of presses - light color - function :
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Nov 15, 2007 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
223 people viewed this question
old marine
old marine
