Question about AMD Athlon 64, 1.6 GHz Athlon 64 X2 4600+ (ADA4600DAA5BV) OEM / Unboxed Processor Upgrade
What is the voltages , vcore etc for normal settings of a amd 4600+
    Problem Solver:
  • 9 Answers
Just got to into your Bios and reset the factory settings and It will reset the changes you may have made.
Posted on Oct 03, 2009
Issue modify vcore for e6300
Really?
Are we talking about the Asus P5LD2-VM motherboard, Zoltan?
(Zoltan is a C-o-o-o-o-l name!)
Because I'm looking at the motherboard manual right now, and state you are mistaken.
1) Use the Right Side Arrow key, and highlight the - Advanced - tab on top of the Main menu.
2) Use the Down Arrow key and highlight -
JumperFree Configuration
Press the Enter key.
Configure System Frequency/Voltage
AI Overclocking - [Auto]
Use the - key, (Minus), and move Auto to Manual
Use the appropriate arrow key, and highlight -
CPU VCore Voltage [ Auto ]
There are 40 Voltages you can choose from.
1.7000Volts to 1.2875Volts.
Remember,
Use SMALL increments at a time. Do a 24 hour stability test.
(Small increment example, 1.7000V to 1.6875V )
If your system is stable for 24 hours, then you can come back, and change the Voltage one more small increment.
(1.6875V to 1.6750V)
Also remember; you are changing the Front Side Bus of the Processor. (FSB)
Change it TOO much, and your ram memory, and expansion slots will not work.
(Ram Memory typically operates at a frequency rate ('Speed'), of half of the FSB of the Processor.
Processor FSB is 800MHz for example? Ram Memory operates at 400MegaHertz.
Intel Core2 Duo E6300? 1066MegaHertz Front Side Bus.
{1066MHz FSB}
Ram memory? 533MHz)
Asus Support > P5LD2-VM > Download page,
http://www.asus.com/Motherboards/Intel_Socket_775/P5LD2VM/#download
For the - Select OS box, click on the blue Down Arrow, and choose WinXP. (Doesn't matter as you are just going for the manual)
Click on the + sign next to Manual (14)
Scroll the inside scroll bar down until you come to -
Version E2281 -
P5LD2-VM User's Manual for English Edition (E2281)
Click on the blue - Global
A PDF file version of the motherboard manual will come up.
Using the PDF file page number box at the top, go to;
Page 63 - 2.4 Advanced menu
Page 65 - CPU VCore Voltage [Auto]
http://www.techwarelabs.com/reviews/processors/e6300/
Overclocking article at the end. Just one of the hundreds of overclocking articles out there.
Regards,
joecoolvette
Aug 15, 2012 | ASUS P5LD2-VM Motherboard
Manyal
EP-8K3A
Introduction
KT333 with VT8233A AGPset/266MHz FSB/3 DIMM with DDR333/1 AGP-4X/6 PCI/USB1.1/ATA-133/6CH Audio/ATX
Specification
PROCESSOR:
The Socket A compatible AMD AthlonTM XP processor 1500+ to 2700+, 600MHz to 1.4GHz AMD AthlonTM and AMD DuronTM processor up to 1.3GHz
CHIPSET:
VIA KT333 AGPset (KT333+ VT8233A)
DRAM MODULE:
184pin DDR DIMM x 3 for PC2700 Memory
DRAM Size: 64MB to 3GB
EXPANSION SLOT:
PCI x 6!A4X AGP x 1
ONBOARD I/O:
Winbond W83697HF LPC I/O integrated with FDD, Parallel, Game, Serial and IrDA v1.0 and Power-On Controllers
ONBOARD PCI / IDE:
PCI Bus IDE Port with PIO / Ultra DMA-133 x 2 (Up to 4 Devices)
I/O CONNECTOR:
PS/2 Mouse and PS/2 style Keyboard
COM1, COM2, Printer, Audio-in/out, MIC & Game Port connectors
USB:
USB connector x 4 (2 for Opt.)
BIOS:
Award Plug & Play BIOS
Built-in AC97 Digital Audio (by Realtek ALC650):
Compliant with AC97 2.2 specification
6 channel slot selectable DAC output for multi-channel applications
Supports digital SPDIF Out Function
EXTENDED FUNCTION:
Supports Hardware Monitoring Function by W83697HF
Supports exclusive KBPO (KeyBoard Power On)
Supports CPU Vcore , Clock and Multiplier setting via BIOS
Supports Memory Voltage setting via BIOS
Supports STR (Suspend To RAM) power saving Function
Supports Wake-On-LAN Function
FORM FACTOR:
305mm x 245mm x 34mm ATX Size
OS Supported:
Windows 98SE/ME/2K/XP/Server2003
Jun 05, 2011 | EPoX EP-8K3A+ Motherboard
Where is vcore set? bios or cpu driver?
Vcore settings can usually be found in the bios settings menu. But be careful when playing around with those settings!
Mar 06, 2011 | Acer Aspire 5004WLMi Notebook
My computer no longer recognizes my Nikon 4600 so that I cannot download photos etc
Please re install your camera driver in Computer and re- run the program. Seems old program was malfunction. By re install the program, normally it can be work again.
Regards,
Dec 15, 2010 | Nikon Coolpix 4600 Digital Camera
BIOS voltage settings for ASUS M2N-SLI Deluxe 570 SLI chip set.
Hi glen909nwi,
Here's the configuration for that board. If your trying to overclock, you'll want to go with a higher setting.
CPUChiosei HT Voltace 11.20 VI
Allows you to set the pocessorhipset HyperTranspoit voltage.
Configuration options: [1 .20V] [1 .25VJ 11 .30V] [1 .35VJ [+1 .40V1 [+1 .45V] [+1 50V]
Chtoset Core Vo#aae f1.40V1
Allows you to set the dlipset core voltage.
Configuration options: [1 .40V1 [1 .50V] [1 .60V]
Ctitpset Slan&w Core Vo?taoe 11.40 VI
Allows you to set the diipset standby coe voltage.
Configuration options: [1 .40V] [1 .6OVJ
CIhVsef Fi-E Voitaae 11.50 VI
Allows you to set the dlipset PCI Express voltage.
Configuration options: [1 .50V1 [1 .55V1 [1 .60V] [1 .65V] [1 .70V1
CPU Vcore Offset Voltage fDisabdJ
Allows you to csable or set the processo vCore offset voltage.
Configuration options: [Disabled] [Offset lOO.OnIV]
ASUS M2N-SU Deluxe
Oct 21, 2009 | ASUS M2N-SLI Deluxe Motherboard
Hardware monitor found an error
First I would make sure all the power plugs are properly plugged into the motherboard and all other devices.
If that does not solve it then I would get the Power supply tested at a local PC shop. Or just get a new decent power supply. Looks like the Power supply without a doubt is defective.
Jul 08, 2009 | ASUS A7V333 Motherboard
Diagram of motherboard wanted
Based on your post/description, you would want to do 2 things: 1) upgrade a Cyrix and 2) install LAN capability.
#2 is easier, all you need is a PCI LAN card with the right drivers for your operating system and you should be set to go;
#1 is trickier...
If you are referring to a Cyrix MediaGXm motherboard, at most that you can go up to is a 300 MHz CPU and hopefully a max of 256Mb of memory depending on the motherboard version.
If you are referring to a Cyrix MII-433 processor which ran at 300 MHz (100x3), hopefully you can try replacing the processor with an AMD K6-2 500 or higher, that is of course assuming that the motherboard is compatible (FSB, VCore voltage, multiplier). You should take into consideration that other than the MII-433. most Cyrix CPUs run at 83 MHz bus in a (Super) Socket 7 motherboard and technically is extremely overclocked (PCI bus running at 41.5 MHz). You should meticulously check the various jumper settings to accommodate your upgrade CPU. For stability, perhaps you should choose an Intel 266 with MMX, for speed AMD K6-2 500. This is of course if you can still locate such processors and appropriate memories.
Good luck and kind regards.
Nov 01, 2007 | Computers & Internet
AMD Athlon 64, 1.6 GHz Athlon 64 X2 4600+ (ADA4600DAA5BV) OEM / Unboxed Processor Upgrade Logo
65 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
