Question about Dell Inspiron 600m 1.5GHz Processor, 1MB, Pentium-M Processor - M7548
When I try to boot it simply says windows rootsystem 32hal.dll missing or corrupt, replace the missing file. How to go about it.
  • 75 Answers
HAL stands for Hardware Abstraction Layer. As it's a hardware related file it is not wise to copy from another computer. You need to reinstall by a bootable cd. try an external Cd drive if you don't have one.
or Restore your PC to the time that it worked well
All Programs-> Accessories -> System Tools -> System Restore
then check 'Restore my computer an earlier time" and select the date your computer worked well
and next next next next finally Restart your computer
Posted on Sep 30, 2009
<windows root>\system32\hal.dll file is
Resolution
1. Restart the PC. The hal.dll error could be a fluke.
2. Check for proper boot order in BIOS. You might see the hal.dll error if the boot order in BIOS is first looking at a hard drive other than your main hard drive.
Note: If you've recently changed your boot order or recently flashed your BIOS, this may be what's causing your problem.
3. Run Windows XP System Restore from a command prompt. If this doesn't work or you're receiving the hal.dll error message before you're able to complete this process, move on to the next step.
4. Repair or replace the boot.ini file. This will work if the cause of the problem is actually Windows XP's boot.ini file and not the hal.dll file, which is often times the case.
Note: If repairing the boot.ini does correct the hal.dll issue but the problem reappears after a reboot and you've recently installed Internet Explorer 8 in Windows XP, uninstall IE8. In this specific situation, IE8 could be the root cause of your hal.dll problem.
5. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the hal.dll error.
6. Recover data from any bad sectors on your hard drive. If the physical part of your hard drive that stores any part of the hal.dll file has been damaged, you're likely to see errors like this.
7. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
8. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
9. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Note: While this will almost certainly resolve any hal.dll errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
Important: If you can't gain access to your files to back them up, you should understand that you will lose them all if you continue with a clean installation of Windows XP.
10. Test the hard drive. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive but you'll want to test it to be sure.
If the drive fails any of your tests, replace the hard drive and then complete a "new" installation of Windows XP.
Mar 09, 2011 | Microsoft Computers & Internet
Tip
Fixing HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
  1. Insert and boot from your WindowsXP CD.
  2. At the first R=Repair option, press the R key
  3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
    Typically this will be #1
  4. Type bootcfg /list to show the current entries in the BOOT.INI file
  5. Type bootcfg /rebuild to repair it
  6. Take out the CD ROM and type exit
on Sep 20, 2010 | Computers & Internet
Unable bootup & error prompt that HAL.dll file missing or corrupt
CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location. Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
Resolution
Nov 09, 2010 | Acer Aspire 4720 Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
My acer aspire one will not start up. message
YOU WILL HAVE TO REPAIR YOUR WINDOWS INSTALLATION USING WINDOWS BOOTABLE INSTALLATION CD/DVD.
Apr 09, 2010 | Acer Aspire One PC Notebook
I am installing a recovery disk for an emachines computer and i get error message stating that the system 32hal.dll is missing or corrupt. i cant get back to the windows screen to install the missing file...
You have to start your PC with the XP cd-rom install disk, if you have
one.
Then, when you come to the screen with the following option displayed :
To repair a Windows XP installation using
Recovery Console, press R.
Then press [R] to start 'Recovery Console'
When confronted by a prompt asking you for Administrator password - just
press [ENTER]
Once in RC has started - type the following command :
expand x:\i386\hal.dl_ c:\windows\system32\hal.dll
(where [x:] is your cd drive-letter)
*NB If SP3 is installed - then the command you type must be :
copy c:\windows\ServicePackFiles\i386\hal.dll c:\windows\system32
....instead, as the files are of two different revision levels
(versions).
Then reboot.
Oct 28, 2009 | E-Machines T5212 PC Desktop
<windows root>\system32\hal.dll is corrupt or missing
See if you can get into safe mode. If you can't then your system files are corrupted and you'll have to restore your computer back to factory defaults.
I believe on your compaq presario they have a built in factory restore and its either accessed by the F10 or F11 key when you first turn on the computer. You'll know when you first turn on the computer at the compaq logo screen.
Let me know if I can help you further.
May 13, 2009 | Compaq Presario sr1403wm AMD Sempron 3000+...
Windows system 32 hal.dll error after restoring e-machine
There's actually a number of reasons why these annoying little DLL errors happen, but the most common, is caused when new programs are installed over all old ones and the old ones are not completely uninstalled 100%, causing registry pile ups and of course, getting a .DLL error messages.
Another reason, is damage that's been done by malware/spyware/adware programs, attaching themselves to your PC and wrecking havoc, deleting crucial DLL files from your PC.
The hal.dll file is created during install from 5 other dlls. HAL is the Hardware Abstraction Layer and it's the interface between the system drivers and the actual hardware.
Copying hal.dll will not resolve the problem.
A lot of times the file will be reported missing due to corruption of the boot sector or of the file system
Causes of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll file or a hal.dll file that has been deleted or moved from its intended location.
Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged HDD.
Suggested remodies-
6. Restore the hal.dll file from the Windows XP CD. If the hal.dll file is truly the cause of the problem, restoring it from the original Windows XP CD may do the trick.
7. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
8. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch.
Important: If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
9. Replace the hard drive. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
10. Perform a new installation of Windows XP after installing the new hard drive.
I have not tried it - but HERE is a free program purporting to fix the error.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Apr 10, 2009 | E-Machines eMachines Desktop PC
Power went outot two error messages:
hal.dll is not good, you need to boot from the windows xp cd and select "Install windows" then select "Repair windows installation"
Jun 10, 2008 | Computers & Internet
Windows>\system32\hal.dll. corrupt
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
