Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Cannot install All-In-One
Windows recognizes that new hardware ready to be installed but Lexmark install software says it can't find the printer and to make sure it is connected.
    Problem Solver:
  • 4 Answers
This uses a usb port..depending on your comp.if you do not have an extra port to use, you will have no problem in buying a hub,which will have extra usb ports. also you will have to unplug-set for 5min or so.with comp off replug printer,then turn on comp.
Posted on Dec 20, 2007
Will only print maybe one page of a 4 page document and sometimes wont print at all
Below are 3 possible solutions.
Unexpected page breaks occur
Cause Solution
Job has timed out.
Set the Print Timeout to a higher value:
Blank pages
Cause Solution
Toner is low.
Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it.
Install a new toner cartridge.
Toner cartridge is defective or empty.
Replace the toner cartridge.
Jobs do not print
Cause Solution
Printer is not ready to receive data.
Make sure Ready or Power Saver appears on the display before sending a job to print. Press to return the printer to the Ready state.
Specified output (exit) bin is full. Remove the stack of paper from the output (exit) bin, and then press .
Specified tray is empty. Load media in the tray.
Wrong printer software is installed.
Verify you are using the correct printer software with your printer.
If you are using a USB port, make sure you are running Windows 2000, Windows XP, Windows Server 2003, or Windows Vista and using Windows ME, Windows 2000, Windows XP, Windows Server 2003, or Windows Vista compatible printer
software.
Cause Solution
Internal print server is not set up properly or is not connected properly.
Verify that you have properly installed the print server and configured the printer for network printing. For more information about installing a network printer, click View User's Guide and Documentation on the Software and
Documentation CD. Copies of the printer software are also available on the Lexmark Web site at www.lexmark.com.
You are using the wrong USB or Ethernet cable, or the cable is not securely connected.
Make sure you are using a recommended cable.
Make sure the connection is secure.
For some reason Lexmark has not posted information for this model. If you need a manual you might try the C534 manual at: http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_C534&segment=SUPPORT&userlocale=EN_CA&frompage=null#2
Dec 10, 2010 | Lexmark C533DN InkJet Printer
Installation of hp deskjet 940c
First load the cd software into your PC. The once you follow all the directions in the set up/run , you must connect the prrinter.
This will be now detected and installed- the new hardware.
Your printer is now ready. Make a test print.
Sep 06, 2010 | HP DeskJet 940c InkJet Printer
Printer and or software not being recognized by
Go to the Lexmark web site, support/downloads section. Download the Windows 7 drivers (ALL of them!) Install all of the drivers. The end.
Feb 07, 2010 | Lexmark X5250 All-In-One InkJet Printer
I just got a new computer with windows vista installed when i went to use my printer it keeps saying printer not commuciating with the coumpter
hello,
plug your printer to a power supply, connect the printer to the computer, make sure it is screwed properly, the computer detects it as a new hardware, install the new hardware hen it is ready for use.
when you are about to print, you select the item you want to print, then you right click and select 'print' from the options, select the type of printer you are about to use and it is ready for use.
Jan 03, 2010 | Lexmark C533DN InkJet Printer
Window 7 does not recognize the printer
Lexmark support says: "Upgrading to Windows 7?"
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_X2600&page=product#1
Click and follow the advice, which involves disconnecting USB cable and uninstalling your current printer driver, downloading and installing new driver software for Windows 7.
Nov 28, 2009 | Lexmark X2600 InkJet Printer
Lexmark z45 not working with windows xp. i installed a lexmark z45 on my laptop that has windows xp and it will not print
Check the printer status:
1 Click Start > Control Panel > Printers and Other Hardware > Printers and Faxes.
2 From the Printers folder, double-click the Lexmark Z45 printer icon.
3 From the Printer menu, make sure:
– Default Printer is selected.
– Pause Printing is not selected.
Check the printer port:
2 Click the Ports tab.
3 From the list of ports, select the USB printer port. If the USB port is not listed, uninstall and then reinstall the printer software.
4 Click Apply.
5 Click OK.
Make sure you have not installed multiple copies of the printer software:
Windows XP: From the Start menu, click Control Panel Printers and Other Hardware > Printers and Faxes.
In the Printers folder, make sure there is only one Lexmark Z45 printer icon. If you have installed multiple copies of the printer software, uninstall each copy. Then restart the computer and reinstall the printer software.
If the printer port is incorrect or you have installed multiple copies of the printer software, uninstall and then reinstall the printer software:
1 From the Start menu, click Programs or All Programs Lexmark Z45 Uninstall.
2 Follow the instructions on your screen to uninstall the printer software.
3 Restart your computer.
4 Reinstall the printer software
Oct 27, 2009 | Lexmark Color Z45 InkJet
I am trying to install my lexmark x5470 to my laptop but it is not listed
To install your printer do as follows:
A) If you have the CD that came with the printer:
  • run the CD to install the driver and the software;
  • follow the installation instructions
  • do not connect the printer to the computer prior to installing the driver/software; do it only after the installation process is concluded or if and when the install wizard instructs you do do so.
B) If you don't have a CD:
  • read this FAQ: How to Install a Downloaded Driver
  • download the correct driver for your system from LEXMARK:
    Downloads for Lexmark X5470 printer
    Note that here are four different drivers for your printer: one for MAC systems, and three for Windows systems (Windows Vista 32, Windows Vista 64 and Windows XP/2000). Make sure you download the right one. To access the Windows drivers, click on the 'Microsoft' tab.
  • install the driver following the instructions on the FAQ above
Sep 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
Desktop does not recognize printer software or hardware
did you install the dirver first and plug in the usb cable when asked? If you don't run the install first it will not identify the printer.
Also plug a memory stick into the same usb port to verify it is working correctly.
Apr 28, 2009 | Lexmark X5150 All-In-One InkJet Printer
Trouble with installing software for PCI FLASH Memory Dell All-in-one
First uninstall the Lexmark and unplug it from your system. Next, do a SHUT DOWN. Turn on your system, load the CD, go through the installation process, then plug in your Lexmark.
Jul 15, 2008 | Lexmark P4350 All-In-One InkJet Printer
Computer will not communicate with printer
Ckeck in control panel & se if the driver software installed. It should be listed in Add/remove programs. If it is, power up the piinter & load windows Vista update service. See if Vista has any patches for you're printer. If no, goto Lexmark & go to the driver section for you're P4350 printer software for Vista. While in Vista update, install any updates listed.
Click on the link provided.
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:479:0:0&searchLang=en&os_group=Windows%20Vista&target=
Creat a folder on you're desktop & down load the latest driver software in-to the folder you created. Uninstall any Lexmark software that might have been in add/remove programs. Install the driver software you downloaded. If all this still fails, call Lexmark since this is a new printer. The number should be in you're manul. Or you can go here for free support.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_652569481_0_en,00.html
Luck!
Mike
May 29, 2008 | Lexmark P4350 All-In-One InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
