TV hard reset
How do I "hard" reset this tv? I was told there is a bottom on the bottom or back that needs to be reset using a paperclip but there is no mention of this in the (crappy) manual.
  • 1 more comment
  • Rich Coutee Jan 01, 2008
    I need to reset my proscan 42" LCD so I can rescan my digital channels because some of my channels are not coming in correctly. But it will not reset all the way. Is there a way to mannually reset tv to factory settings besides the ots screen?
  • Anonymous Mar 13, 2008
    at first it was unlocked and i was trying to set the channels so can hook the cable up but then it just locked and no one know who put a parental code on it.
  • Wilfredo Serrano
    Wilfredo Serrano Feb 28, 2012
    My apologies, The reset I explained is for a Sharp. Just noticed its a Proscan.
HELLO
I have a problem tv no sinal so need a full reset fj3
32pf9631d
pluse help
thankyou
Posted on Mar 22, 2010
    New Friend:
How to reset a a sony KF50XB800 model number
Posted on Feb 23, 2015
    Problem Solver:
  • 6 Answers
Sorry I am late: But for those whom wish to hard reset a sharp:A) Unplug TV from wallB) Hold down Input and vol - (Should be last button furthest from the Power Button) (while plugging in the tv) or simultaneously. VIP or wont work. C) Release the Buttons (One you see the letter K-inside a box left top corner.
You have now successfully reset the TV. Try turning off and back on.If it doesnt come back. You have other issues.
Posted on Feb 28, 2012
How do I get to remove the small screen at the bottom right corner of the tv ?
try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. http://electronicshelponline.blogspot.com/
Aug 20, 2017 | Televison & Video
Tv stuck on one channel
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Apr 26, 2017 | Televison & Video
How do I hard reset my Magnum smart TV?
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jul 05, 2016 | Televison & Video
How do I connect my new roku?
You could see something for sure.
Verify the input you have the Roku plugged into is the one you currently have selected on the TV.
If that doesn't work, plug use a paperclip to press the small "reset" button button the Roku.
You can also choose to perform a hard reset:
Hard reset
If a soft reset doesn't fix your problem, a hard reset may be your only option. This will clear all data off the Roku 2 and reset it to factory default settings.
1. Remove all cables except the Power cord.
2. Using a paper clip, press and hold the Reset button on the back of the device for about 15 seconds.
3. Continue to hold the Reset button, then remove the Power cord from the back of the unit.
4. Release the Reset button, then plug all of the cords back into the device.
The Roku 2 should walk you through the setup process again.
You can also accomplish a hard reset by selecting Settings > Factory reset > Factory reset > Yes on the device's menu.
Finally, try using a different HDMI cable.
Let me know if any of this helps.
Source:
How to Hard and Soft Reset the Roku 2
Jun 06, 2014 | Televison & Video
Vizio tv hdtv lcd changes channels and makes the volume go up and down on its own.
I called Vizio when my TV acted up and was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in.
Hope this works for you, if it does, let me know by coming back and voting. Thanks!
Sep 11, 2010 | Vizio L32 32 in. LCD HDTV
Tv turns itself off as soon as I turn it on: it will not stay on
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. Hope this works for you, if it does, let me know by coming back and voting. Thanks!
No Picture
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. It works fine now.
Apr 02, 2010 | Vizio L32 32 in. LCD HDTV
My vizio wont turn on but the vizio organge light comes on please help
I called Vizio, was told I needed a hard reset, and this fixed my problem: I unplugged the TV; held down the on button for one minute, then plugged it back in. Hope this works for you.
Mar 26, 2010 | Vizio L32 32 in. LCD HDTV
Help
sounds to me that the remote control's volume button is wedged in there. try to jimmy it loose with a paperclip. It could also be stuck ont he tv at the bottom. are you wall mounted, stand, or just laying on carpet? the volume is at the bottom of the tv. hope this helps...cheers.
Apr 03, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Tv repair
First, you need to get the TV to work then worry about the remote. The TV will power on/off using the power button on the TV but thats it. You can try whats called a 'hard reset'. Unplug the TV from the wall and anything connected to it for 4 hours. Then plug everything back in. The manual is on the website: http://esupport.sony.com/US/perl/model-documents.pl?mdl=KV20FS120
Jul 02, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Televison & Video Logo
3,358 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
