Question about EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express
How to overclock 945GCT-M2/1333 motherboard
How to overclock ECS 945GCT-M2/1333 motherboard'cause the multiplier and clock freq are ghost in the bios
  • 27 Answers
Try getting an overclockers BIOS. ECS motherboards don't usually offer the best overclocking support.
Posted on Sep 30, 2009
I cant overclock my system but i go to bios now whati had to do
The BIOS. Overclocking is best done in the computer's BIOS (Basic Input/Output System or Binary Integrated Operating System). There are also some motherboards that let you do a basic increase in power by setting a jumper, but this is dangerous and you have no real stability control.
There are some software programs available which allow you to overclock inside the operating system, but the best results are achieved by changing BIOS settings. Usually you can get into your BIOS by pressing DEL (some systems may use F2, F10, or Ctrl-Enter) as soon as your computer begins the POST
(Power On Self Test - when it shows the RAM size, processor speed, etc.).
Here, you can change your FSB (front side bus), memory timings, and your CPU multiplier (also referred to as CPU Clock Ratio).
Clearing your CMOS. Sometimes, an overclock can become unstable. If this happens, or your computer will not boot, you will need to reset the BIOS back to default and start over again.
This is done by clearing the CMOS (a small piece of memory on the motherboard which stores your BIOS configuration, and is powered by a small battery). Some newer motherboards will bypass user settings in the CMOS if the computer fails POST (often caused by a faulty overclock). However, most motherboards require a manual clear.
This can be done in two ways, depending on your motherboard. The first way is by changing the position of the clear CMOS jumper on your motherboard, waiting a few minutes, then repositioning the jumper to its original place.
The CMOS Jumper
The second way, if your motherboard doesn't have this jumper, consists of unplugging your computer, removing the little CMOS battery, then pressing the power button (your capacitors will discharge), and waiting a couple of minutes.
Then you have to refit the battery and plug in your computer. Once your CMOS is cleared, all BIOS settings are reset back to default and you'll have to start the overclocking process all over again. Just so you know, this step is only necessary if your overclock becomes unstable.
Locked or Unlocked. The first thing to know when you start the process of overclocking, is whether your processor is multiplier locked or unlocked.
To check whether your CPU is locked, lower your multiplier via the BIOS one step, for example from 11 to 10.5. Save and exit your BIOS and your computer will restart.
If your computer posts again and shows the new CPU speed, it means your CPU is unlocked. However, if your computer failed to post (screen remains black) or no CPU speed change is present, this means your multiplier is locked
Multiplier Unlocked Processors. Usually, your max overclock is limited by your memory, or RAM. A good starting place is to find the top memory bus speed in which your memory can handle while keeping it in sync with the FSB. To check this, lower your CPU multiplier some steps (from 11 to 9, for example) and increase your FSB a few notches (e.g.: 200 MHz to 205 MHz).
After this, save and exit your BIOS. There are a few ways to test for stability.
If you make it into Windows, that is a good start. You can try running a few CPU / RAM intensive programs to stress these components. Some good examples are SiSoft Sandra, Prime95, Orthos, 3DMark 2006 and Folding@Home.
You may also choose to run a program outside of Windows, such as Memtest. Load a copy of Memtest onto a bootable floppy, then insert the disk after you have exited the BIOS.
Continue to increase your FSB until Memtest starts reporting errors. When this happens, you can try to increase the voltage supplied to your memory.
Do note that increasing voltages may shorten the life span of your memory. Also, another option is to loosen the timings on the memory (more on this a bit later). The previous FSB setting before the error will be your max FSB. Your max FSB will fully depend on what memory you have installed. Quality, name-brand memory will work best for overclocking.
Now that you know your max FSB, you'll figure out your max multiplier. Keeping your FSB @ stock, you raise your multiplier one step at a time. Each time you restart, check for system stability. As mentioned above, one good way to do this is by running Prime95.
If it doesn't post (reread the section about clearing the CMOS), or Prime 95 fails, you can try to raise the core voltage a bit. Increasing it may or may not increase stability. On the other hand, the temperature will also be increased. If you are going to increase the core voltage, you should keep an eye on temperatures, at least for a few minutes.
Also note that increasing voltages may shorten the life span of your CPU, not to mention void your warranty. When your computer is no longer stable at a given multiplier setting, lower your multiplier one step and take that as your max multiplier.
Now that you have your max FSB speed and your max multiplier, you can play around and determine the best settings for your system. Do note that having a higher FSB overclock as opposed to a higher multiplier will have a greater impact on overall system performance.
http://www.pcadvisor.co.uk/news/index.cfm?newsid=107977
hope this helps
May 30, 2012 | Computers & Internet
Possible overclock
Overclocking is now set on bios.
Just change the multipliers for desired speed, but be careful
Jun 22, 2009 | Computers & Internet
Overclocking locked on 945gct-m2 mobo
There is no overclocking settings for this motherboard, the CPU speeds and core settings are automatically determined. You may be able to find a modified bios somewhere, but i would strongly suggest this not be done. A bad bios, or bad flash can essentially turn the motherboard into an expensive paperweight.
May 30, 2009 | Intel Computers & Internet
How to overclock my motherboard ?
there are 2 ways, overclocking using the bios to over clock the memory ( ram ) and also the processor ie changing the multipliers and other tweaks ( which should be in your motherboards manual ) that or using jumpers which are physically on the motherboard but later motherboards use the bios to tweak / over clock your computer.
Apr 13, 2009 | Computers & Internet
How to overclock P4M900-m7 es motherboard
try changing the clock multipliers in the bios section if not the board might not be able to olerclock or drop a line at overclockers.com
Jan 02, 2009 | Biostar P4M890-M7 Motherboard
¿Could it work with 2 Cards RAM of 1G/800? ¿Could PC work with this mother board and 2 Cards RAM of 1G/800?
That's a pretty big jumb from 667 to 800MHz. (Motherboard does not support 800MHz).
Manual says:
This motherboard accommodates two memory modules. It can support two 240-pin
DDR2 667/533/400. The total memory capacity is 2 GB.
Yet, ECS web site says it supports up to 4 GB.
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=830&CategoryID=1&DetailName=Feature&MenuID=44&LanID=0
BIOS for 945GCT-M/1333 (PCB:3.x) version 08/07/18 does not include information pertaining to increased memory speed up to 800MHz. (Bios link).
http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?detailid=830&CategoryID=1&DetailName=Bios&MenuID=44&LanID=0
Mike
Nov 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Cant overclock my cpu
Overclocking is not reliable.
Jun 13, 2017 | Computers & Internet
Overclock; Access clock multiplier settings?
Yes if the motherboard supports overclocking, but you should be very careful not to burn your processor.
Nov 03, 2007 | HP Media Center m7250n (ED842AA) PC...
EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0, Intel 945GC, Socket 775, MicroATX, Audio, Video, PCI Express Logo
1,813 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
