Question about Minolta Photography
MINOLTA X 300 SHUTTER RELEASE JAMMED. FITTING NEW BATTERIES DOES'NT HELP AT ALL. Barry.
  • 302 Answers
The Minolta X-series (X-300/370, X-570, X-700) were known for this issue. Two capacitors under the top and bottom covers go bad over time. They prevent the shutter from releasing, so you cannot wind to re-**** the shutter. If you're handy at these things, you can buy the caps, remove the covers, solder in the new caps, and be fine. This issue is well known and you can find instructions on the web. Or you can send it in for repair. Garry's Camera repair in Niles,ILL will do it cheaply at $58 incl return postage. Look him up on the web.
Posted on Oct 11, 2009
I have a Minolta X-370 camera that will not advance the film. Lever seems to be frozen.
The shutter is already wound and the shutter is not releasing.
You may have bad shutter release capacitors if the batteries are good.
May 11, 2010 | Minolta X-370S 35mm SLR Camera
Minolta X 300 camera On replacing batteries
on this camera can you lock shutter button down?
may have moved it changing battery.
take out battery may release it
is battery up the right way?
Feb 15, 2010 | Minolta Photography
My Dynax 5D will not release the shutter nor will it turn off unless the battery is removed. The access light and the display remain on when the camera is turned off at the switch. All menus and autofocus...
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 12, 2009 | Konica Minolta Dynax 5D / Maxxum 5D Body...
I have a minolta x-300 and the shutter won't release when I took a long exposure with the 'b' setting, is there a way to reset the shutter?
'B' settings and other long exposure settings on electronically controlled shutters are always the death knell for a nearly exhausted battery. The X-300 is totally reliant on batteries to power the shutter and so the shutter lock-up is cured simply by replacing the batteries with fresh ones. For consistently accurate exposures use two silver oxide SR44 cells instead of cheaper lithium alkaline LR44 cells which have an unstable voltage.
Don't leave it too long though as the shutter can stick if left this way for too long.
A pdf manual for your camera is at the following address:-
sawlani.googlepages.com/minolta-x-300.pdf
Aug 03, 2009 | Minolta Photography
Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
Jun 15, 2009 | Minolta X-370S 35mm SLR Camera
Pentax P30 - shutter jammed after flat batteries, no lights
Common problem.
Shutter motor needs replacement.
Mar 19, 2009 | Photography
My daughter just got a used Minolta 700-X. We are trying to load the film, but the advance lever won't advance to load the film after we put it in. Can you help?
Are the batteries good ,is the battery cap and contacts clean? Can you fire the shutter? Move select off auto and try to release the shutter. If the shutter fired off auto and will not fire on auto with good batteries. Either the shutter or flex circuit must be replaced. There are no new parts avail. for the X700.
One other item for the X700. check to see if the shutter fully traveled on the last shot.
Dec 07, 2008 | Photography
Shutter stopped working
If the metering lights go out when you press the shutter release fully down, then the camera needs the shutter capacitors replaced. If they stay on, it could be the release magnets on the shutter unit itself, or worse.
Aug 12, 2008 | Minolta Photography
Minolta x-300
The X-300 is very similar to the X-700 minus a few features like program 'P' mode. The VF displays are very similar for metering and exposure. You can read the users guide for the X700 here on
Mar 03, 2008 | Cameras
Minolta X370 film loading problem.
 First make sure your batteries are OK , camera will not work without two 1.5 v batteries. If your camera still doesnt work this is probably  because the shutter is cocked but you cannot release the shutter and that is why you cannot advance the transport mechanism. The shutter release mechanism needs repairing first. SREMEDY : take bottom cover off ( 4 screws ) and locate 220 mf 6v capacitor ( it is the only one in this part of the camera , cant miss it ). Replace the capacitor while you keep an eye on the polarity ( indicated on the casing of the capacitor ) and you camera should work fine ( dont forget camera needs  two 1.5v  batteries to work ! )
Oct 10, 2007 | Minolta X-370S 35mm SLR Camera
Photography Logo
351 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
