Question about Motorola Mobility HS850 Consumer Headset
Hi, I have an bluetooth n136 hs850 and it is turned on and blinks ,but i cant get it in descoverble mode, it wont stay blue keeps blinking, can youtell me how to get it in discoverable mode? thankyou
  • 3 Answers
Close flap (off mode) hold down the "on" function button until the blue light comes on. once it comes on open the flap.. the blue light should stay on. you should already have your phone set for pairing. if your phone ask for a password. its generally 0000..but heres a link to the guide..http://direct.motorola.com/hellomoto/motosupport/source/generalpairinginstructions.asp?p_headset=742
Posted on Dec 19, 2009
SOURCE:
My motorola n136 headset will not charge. This is my second headset with both doing the same thing. When pluged in to wall charger the blue light comes on but it is not charging. What am i doing wrong?
I dropped my 4-5 month old Motorola N136 bluetooth under my couch while activated. Took me a week to get it out, and now it will not take a charge. All I get is the red light blinking over and over when plugged into my charger. Any ideas? lotsofstufflv@gmail.com
Jan 03, 2011 | Motorola Mobility H270 Bluetooth Headset
I have this motorola n136 that I used with my old Samsung phone. Then I bought a new samsung and bought a new charger for the blue tooth and now I cannot synch the two together.
Your headset may also be called a HS850 (may look different) but the instructions would be the same. Instruction manual is here:>>>>>>>>>
http://www.motorola.com/mdirect/manuals/HS850_%209489A97O.pdf
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Dec 17, 2009 | Motorola Mobility Bluetooth Hands Free...
I have a motorola hs850 and it keeps flashing blue and it cannot go into discoverable mode need some help thanks
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 17, 2009 | Motorola Mobility HS850 Consumer Headset
Motorola HS850 N136 bluetooth won't go into discoverable mode. I press and hold the call button. The light turns blue for a second but then turns off. I am trying to get my cell phone to discover it.
open the boom (mic) right when it turns to solid blue!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
May 06, 2009 | Motorola Mobility HS850 Consumer Headset
My N136 / HS850 Bluetooth
push once to turn it on, push it once to turn it off if its in the on mode,
hold power till it flashes red,blue over and over then its in discovery mode and all zeros is most likely the code for it.
Jan 23, 2009 | Motorola Mobility HS850 Consumer Headset
HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 21, 2008 | Motorola Mobility HS850 Consumer Headset
Lost N136 Manual
I have an N136 which turns out to be an HS850 (with folding boom}. This model requires the boom to be folded while the answer button is held down, When the light comes on the boom must be extended before the light goes out. The light will now stay on and the phone should find your headset.
Jul 31, 2008 | Motorola Mobility HS850 Consumer Headset
Trying to pair motorola n136 with my sprint rumors phone
Found this when trying to pair mine:
I had the same problem - what I thought was the unit number was not - it is actually HS850. Instruction manual is here:
http://www.motorola.com/mdirect/manuals/...
Basically, hold down the call button until it lights up (steady -not blinking), open the boom, and search for devices in your phone. When it finds it, the passkey is 0000.
Jun 21, 2008 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
432 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
