Question about Intel 865G Motherboard
I need to know if I can connect a component video adapter for display out to a standard definition (480i) 50" tv with component inputs?
The video portion won't play but audio does
It looks like you've got a plain, old "480i standard definition" TV. The inputs on it will likely be limited to S-Video, RF Coaxial (cable) and one or more sets of "A/V" inputs that consist of 3 jacks - 1 each yellow, red, and white. Without knowing the make & model of the TV I can't be sure which / how many inputs it has. It looks like you're trying to play a DVD. Most DVD players only offer A/V type connections - again - you didn't provide this info so I'm forced to guess. The Yellow jack (on TVs and disc and tape player / recorders almost always provide the higher quality A/V jacks) is for the video signal and the Red & White are always the left and right stereo audio jacks. The cables used to connect devices to the TV have the same colored plugs to make matching them up easier than if they were all the same color. If you accidentally connected one of the red or white audio plugs into the yellow video jack, you will not have a picture. Check BOTH ends of the cable - at the TV and at the DVD player. All three plugs must be connected to the corresponding colored jack.
If it is connected properly, your DVD player might be one that was a more expensive type that offers "480P Progressive Scan" output along with the standard "480i interlaced scan" output. The 480i output was called "standard definition" and 480P was called "enhanced definition" and provided a better picture. If your TV only supports 480i, it will not be able to display a 480P signal. You will need to check the DVD Player manual to find out how to return the output to 480i again. If you no longer possess the manual, you may either Google it or provide the brand and model here so that we might take a look for it for you.
In the event that you are using RF coax (cable) to get the signal from the source into the TV, you may just be trying to watch it on CH4 instead of CH3 (or vice-versa). Try changing the channel up or down one from where it is to see if the picture comes in.
I hope this helps & good luck!
Feb 08, 2013 | Televison & Video
What is the screen resolution to the sharp 32C540 ?
480i is the highest resolution of your tv. The tv has composite, s-video and component inputs in the back. The manual states that with component connections are dvd compatible allowing you to enjoy the highest quality image playback than using s-video. Dvd's resolution are 480i or 480p. I'm guessing it's more 480i than 480p since the tv is a crt tube tv and does not have any of the digital inputs for higher resolutions.
Jul 06, 2011 | Sharp 32C-540 32" TV
Is this TV digital
This is not a digital TV. This TV has only an NTSC (analog) tuner. A converter will be needed to tune digital broadcast TV stations, your CATV or satellite company supplies a converter to allow this set to display programs.
The display is limited to "480P" resolution, called "Enhanced Definition", which is a step up from the traditional NTSC standard of "480i" resolution or "Standard Definition". ("P is "progressive scan" and "i" is "interlaced scan"). Progressive scan provides a better picture quality when compared to interlaced scan images. High Definition or "HD" is a signal that contains data that allows display of images with 720P, 1080i and 1080P resolutions (the larger numbers indicate more information, or higher picture quality). Your TV will receive all signals, SD, ED and HD, but will down convert to ED. Signals can be brought into the set via 2 composite-video connections, 1 each component- and S-video, an RF antenna/cable-box/VCR input, and a 15-pin D-Sub analog RGB input. More info can be found here.
I hope this helps and good luck! Please rate my reply. Thank you.
Jun 01, 2011 | Philips 15PF7835 15 in. LCD Television
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
I do not know how to work the display resolution
The tv display resolution will automatically change depends on your source/device output resolution and TV inputs used as well. Television component and HDMI inputs accept 480i up to 1080p signal while composite and s-video accepts 480i(lowest resolution) signals only. You will get high resolution signals from cablebox, game consoles, bluray etc through their component or HDMI output jacks.
Dec 25, 2009 | Sanyo DP50747 50 in. Plasma TV
How to get a high definition Picture??
Hi, first of all you need a high definition source. I'm not sure if your cable box is HD but lets take it as an example. The component leads which you are using isn't 'true' HD video quality, what you need is a hdmi cable from your source to your TV.
Your cable box maybe HD with a HDMI output, if it is then you need the lead to come out of the cable box into your tv's HDMI input using a HDMI lead. Then you switch your TV's source to the HDMI input and it then should be producing a HD quality picture, but to truly get the full HD experience you may want to subscripe to a HD channel or purchase a blueray player becasue most cable TV channels are upscaled to HD and the definition is not as good as on a blue ray disc or a true HD channel.
So in conclusion the cable and input you are using is not designed for HD input. I believe your TV is HD, check for HDMI inputs or DVI inputs.
Hope this explains your problem
Nov 28, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Jun 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Xbox Dashboard on high definition TV
With the latest update to the Xbox Dashboard available from Xbox Live®, you can change the default display mode of the Xbox Dashboard from 480i to 480p. Connect your console to the component inputs of a 480p-capable TV using an Xbox High Definition AV Pack toview the Xbox Dashboard in high definition. To get the latest Xbox Dashboard Using a Broadband connection and the Ethernet connector on the back of the console, connect your Xbox to the Xbox Live servers. When you do so, the latest version of Xbox Live, including the Xbox Dashboard, automatically downloads. You do not need to subscribe to Xbox Live for this update to automatically download to your Xbox. But if you don't have an Xbox Live account, get one! To set the Xbox Dashboard to 480p Connect your Xbox console to the component inputs of a TV that supports 480p with an Xbox High Definition AV Pack. Start the Xbox console without a disc in the tray to run the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Livearea rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twiceto return to the Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select Yes to confirm that your TV supports 480p. Pull and hold both the left and right triggers. While holding the triggers, click (press in) the left and right thumbsticks. After a brief blank screen, the Xbox Dashboard will display in 480p. If you want to return to 480i, repeat the controller combination in step 7, or switch your Xbox High Definition AV Pack with another type of AV pack. Note The opening Xbox animation does not display in 480p, only 480i. To resetthe Xbox Dashboard to 480i Start the Xbox console without a disc in the tray torun the Xbox Dashboard. Note If your Xbox console takes you to the Xbox Live area rather than the Xbox Dashboard main menu, press the B button on the Xbox controller twice to return tothe Xbox Dashboard main menu. From the main menu of the Xbox Dashboard, select Settings. Fromthe Settings menu, select Video. Fromthe Video menu, select 480p. Select No to indicate that your TV does not support 480p to reset your Xbox Dashboard to 480i. If your screen appears blank or scrambled If your Xbox Dashboard does not display correctly while in 480p, it might be difficult to see the menus to reset your display to 480i. Connect your Xbox High Definition AV Pack?s green color-coded video output jack (the one marked with the letter Y) to the composite video input of your TV. Note The composite input on a TV is normally color-coded with yellow. Proceed to reset your display to 480i as described above
Nov 20, 2005 | Microsoft Xbox Console
Nov 20, 2005 | Microsoft Xbox 360 Console
Intel 865G Motherboard Logo
37 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
