Question about Dell 3100cn Laser Printer
Far right side of the text or picture missing on Dell 3100cn.
Far right side of the text or picture on printed page is missing. A vertical line up and down missing print. What part needs to be replaced on the Dell 3100Cn to fix or print missing areas?
    President:
  • 1,653 Answers
Refer to the following table
Cause
Solution
How common*
Contamination in the laser path
1. Clean the laser path. (Remove the laser/scanner assembly and clean the lens.) 2. Replace the laser/scanner assembly
8
Defective fuser.
Replace the fuser assembly
Lack of toner or faulty toner cartridge.
Redistribute the toner in the toner cartridge. If the problem continues, replace the toner cartridge.
7
Posted on Sep 30, 2009
  • 141 Answers
Either the fuser or transfer unit.
Dell 3100cn laser printer poor print quality
It sounds like you've got contamination on the drum cartridge or on one of the toner cartridges.
I'm actually going to be installing black toner in my 3100cn in about 8 hours, so I'll inspect and clean each of the carts, and write up the process for you tonight.
Jan 27, 2010 | Dell Office Equipment & Supplies
1/2" white line appearing down right side of page
Try replacing the toner cartridge. This seems to be a problem with the photo-sensitive drum, which is located in the cartridge.
Jan 05, 2010 | Dell 3100cn Laser Printer
Our Dell 3100CN printer blocks out a 1/2" wide line (all colors) print area on the right side. We replaced the printer drum unit and that didn't fix the problem. It was printing fine until we replaced the...
Try the cleaning rod. visit: http://support.dell.com/support/edocs/systems/3100cn/en/ug/section22.html
for images (under replacing the "cleaning rod pad") for where to find the cleaning rod. You likely don't need to replace the pad, just use the rod (pull out and push in 10X) and try to print again.
Cheers
Oct 22, 2009 | Dell 3100cn Laser Printer
Blank vertical line from top to bottom on the right
Check to make sure that the locks on the toner cartridges are all the way seated. If they are not seated right they block the image from the laser to the imaging drum. All they have to be is a 1/16 of aan inch open and will do this.
Jul 01, 2009 | Dell 3100cn Laser Printer
Print missing on right side of page
Drum, fuser and power supply can contribute to this issue. check if you have the printer connected to a surge protector or a UPS. Laser printers are picky about surge protectors especially if they are not designed to handle the voltage.
try connecting directly to the wall the issue should get progressively better.
if you can rub the images off the paper then it's the fuser.
Feb 16, 2009 | Dell 3100cn Laser Printer
Border is spotted
sounds like a fuser or transfer roller problem. Try replacing.
Feb 06, 2009 | Dell 3100cn Laser Printer
Vertical toner smear-off in all colours
Looks like the ridges inside the cartridge are catching. Here's a solution;
http://www.ahfx.net/weblog.php?article=133
Dec 12, 2008 | Dell 3100cn Laser Printer
Dell 3100cn
I've the same problem with a 3000cn but on the black color. all other colors are great execpt the black one.
Any Ideas someone ?
Apr 02, 2008 | Dell 3100cn Laser Printer
Trouble Printing Pictures
Hi
All you need to do is reset the printer to the factory settings, follow the instructions manual for dell 3000cn steps.
Print the Gradation [ESS] Test Print On the Printer
To print all four 20% toner test prints, perform the following step:
Power off the printer.
Hold down the up and down arrow buttons on the printer and power the printer on.
Press the down arrow button until Test Print appears and press the button.
Press the down arrow until Cyan20% [ESS] appears and press the button.
Press the button. The test print will print.
Press the Cancel button.
Press the down arrow until Magenta20% [ESS] appears and press the button.
Press the down arrow until Yellow20% [ESS] appears and press the button.
Press the down arrow until Black20% [ESS] appears and press the button.
STEP: Clean the contact points on the drum cartridge and the right side of the 3000cn-series / 3100cn printer.
To clean the contact points on the drum cartridge and the right side of the printer, perform the following steps:
Unplug the power cable.
Pull to open the front cover, and then lift to open the top cover.
Raise the lever on the top right side of the drum cartridge
Grasp the drum cartridge by the handle and lift up and out
Using a clean, dry, lint-free cloth, wipe the contact points on the drum cartridge
Clean the right side of the drum cartridge.
Using a clean, dry, lint-free cloth, wipe the contact points on the right side of the printer
Insert the drum cartridge.
Close the top and front covers.
Plug in the power cable.
Power on the printer
This should resolve the issue
Nov 08, 2007 | Dell 3100cn Laser Printer
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
717 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
