Question about Whirlpool ED5VHGXM Side by Side Refrigerator
Ice maker not working
Freezer is not pulling water into the ice maker, but water is available from front door dispenser
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
oiy
Posted on Sep 30, 2010
Samsung side by side ice maker not working
You have 2 separate valves, 1 for the water dispenser and 1 for the ice maker. (otherwise your ice maker would overflow every time you got water from the dispenser and your dispenser would flow every time the ice maker went to refill.) They are fed from the same tubing.
The cube/crushed ice motor is completely separate from the ice maker itself and should have absolutely no bearing on the water flow.
You have narrowed down the problem quite nicely to the ice maker water valve. There is one more thing to check though, the connector. There should be a multi-contact connector from the ice maker to the back wall of the freezer, usually 6-9 wires. Pull that apart and check the cord side (ice maker side) for any corrosion. BE CAREFUL NOT TO TOUCH THE OTHER SIDE AS THERE IS LIVE 110V!!! If you don't see any corrosion, still try try disconnecting and reconnecting 5-10 times and see if that solves your problem. If you see corrosion, unplug the refrigerator before working on the back wall part of the connector. [This connector besides powering the ice maker also allows the ice maker to control the water valve which can't be inside the freezer]
Sep 03, 2016 | Samsung Refrigerators
Dispenser stopped working
Hello...yes there is a kit you can buy that has the solenoid, and other parts ...door flapper....you have to pull the front off the freezer section where you change from water to ice.....
Nov 11, 2013 | Maytag MSD2756G Side by Side Refrigerator
The freezer door is not sealing properly and seems to be off the track.
the spare seals are available,if the seals are not sealing,then may be its got worn out/ over stretched so it has to be replaced.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | LG LFX25971ST Bottom Freezer French Door...
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Water dispenser won't work
check the freezer door switch; this is a safety so the ice maker wont come on while the door is open
Oct 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker quit making ice
There are repair instructions available for this particular ice maker at www.AnyoneCanFixIt.com Specifically, you should locate it at www.anyonecanfixit.com/household.htm
Aug 24, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice maker and now water dispenser does not work
Do you get water to the connector at the bottom of the freezer door ? if you do then the water pipe in the door is probably frozen - read new door ! if not then check thw electrical connector at the bottom of the freezer door as they have a habit of corroding.
Feb 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Whirlpool ED5VHGXM Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
