Question about HP Officejet 4215v All-in-One Printer
Hp officejet 4215v all-in-one *WON'T WORK*
It will not print..
says:
remove and check left cartridge.
when i do it says:
insert left cartridge.
i have tried everything!
someone please help.
becca
  • 1 more comment
  • tnjman Feb 14, 2009
    did nothing to the printer, but it says remove and check the left cartridge.
    left = color - and it may be empty, but still should NOT do this ****.
    Also, HP SHOULD let us use ONLY the 'black' cartridge, which is one of the print options, but no, it is ****-WARE, because it forces you to have both cartridges full and in place - that is bloody stupid. If I only HAVE a black cartridge, then I should be able to run the printer and print only from that cartridge. What a joke.
  • jimhill24 May 12, 2009
    It says "remove and check left cartridge" I put a new one in and it still says the same thing. I am stuck.
  • Artur Rzasa
    Artur Rzasa May 11, 2010
    Is this a new or old cartridge?
    If it is new, please check that the protective tape has been removed which protects the nozzles (bottom of cartridge) and electrical pads (back side of cartridge).
    Also make sure that there is no dirt or other obstruction between the electrical pads (gold coloured dots) and the matching pins inside the printer.
    Problem Solver:
  • 7 Answers
Cartridge problem
Posted on Jan 29, 2008
My x5495 black and color cartridges are not printing. they have ink in them, but will not print. have cleaned cartridges and still will not work.
Try this approach:
  1. When you're on Copy mode, press the Menu button on the printer operator panel.
  2. Press left/right button until Tools is selected on the screen.
  3. Press check.
  4. Choose Maintenance.
  5. Press left/right button until Clean Cartridges is selected on the screen.
  6. Press check.
Your printer will then print a test page forcing ink through the cartridge nozzles and clean them. After the page is printed, try to print your document/file again to verify if problem is resolved.
You may also try to reseat the cartridges by removing both cartridges from your printer > close the printer cover > unplug/re-plug the printer into the power source to reset it > when the printer turns on, firmly re-insert the cartridges. Try to print again.
If that doesn't help, try to insert different known working cartridges.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 29, 2011 | Lexmark X5150 All-In-One InkJet Printer
I just put all new ink in my printer and will not print. Unplugged it to re-boot it, still won't work. If i copy something by hand will not print, if i copy something from computer it does not...
be sure that you remove the tape from the cartridges before you insert it in the printer, it has a color pink attach to the tape remove it slowly then insert the cartridge to the printer,
Aug 03, 2011 | Computers & Internet
Ink cartridge light of mt HP Deskjet F380 All-in-One is blinking and an E appears, have tried replacing cartridges and everything, but no result whatsoever.
Hi
Please try this solution
Remove the USB cable into the printer and leave the printer on.
Remove all the cartridges.
Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
Disconnect the power cable and from the power source supply.
Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
Reconnect power cord and turn on the printer.
Return all the ink cartridges and close the door. Wait for the calibration process.
Print the test page to check if it working.
Reconnect the USB cable and try to print again.
Post comment if you need more help. Regards
Apr 09, 2011 | HP DeskJet F380 All-In-One Printer
HP printer all-in-one model2410xphotosnart keeps giving me the message to remove and check print cartridges which I have done and both are full. Will not stop blinking and when trying to print makes...
Welcome to Fixya
This means the the printer cannot determine which cartridge is causing the error. Make sure that you are using original HP cartridges.
Please see troubleshooting procedure below:
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts. Click here to see how.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  3. If replacing cartridges fails to correct the problem, click the link at the top of this page to contact HP.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 03, 2011 | HP Office Equipment & Supplies
Inserted new cartridge but it saying "print
This can happen if you dindn't remove all the tapes from the cartridge.
Please check this and let me know if you solved
Feb 28, 2011 | Dell 924 All-in-One InkJet Printer
How do i install ink cartridge for HP 4355?
To install the ink cartridge
1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
Important : Do not touch copper-colored contacts or retape the cartridges.
4) Insert the tri-color print cartridge.
Caution : The device must be On before you can insert the print cartridges.
a) Slide the tri-color print cartridges into the left slot.
b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
5) Insert the black print cartridge.
a) Slide the black print cartridge into the right slot.
b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
c) Make sure both cartridges are secure, Close the print cartridge door.
6) Align the print cartridges.
a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
b) Remove the alignment page from the output tray.
c) Place the alignment page face down into the document feeder.
d) Press OK to scan the alignment page.
After the page has scanned, alignment is complete.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Dec 01, 2009 | HP Office Equipment & Supplies
Canon ip6220d turns on, screen lights, small noise then power off
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth.
Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Hope this help. Please Rate My Response! Thanks!
CF
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Aug 26, 2009 | Canon PIXMA iP6220D InkJet Photo Printer
Error on printer Connon ip 1000
Error code: 5600
Description: Cartridge displaced error
Symptom: blink in orange 9 times,beep 10 times
try removing and replacing the cartridge
please rate our help to keep the service online
Aug 24, 2009 | Epson Stylus Photo® R2400 InkJet Printer
Cyan or yellow ink cartridge light stays on. Can not print.
I had this problem after I ran a print cartridge out of ink on my HP business inkjet 1200. The Print color light stayed on solid, and would not print.  After much frustration and trying many other things, I purged the air from the print cartridge pump, and that cleared the problem. To get rid of the air (which I could see through the translucent wall of the pump) I inserted a syringe needle (without the syringe) into the nozzle of the cartridge, and expelled some ink with the air. This is messy, so I recommend gloves. I have been refilling my cartridges for years.
Jan 30, 2009 | HP Inkjet 1200dn Printer
The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Jan 08, 2009 | HP OfficeJet 7310 All-In-One InkJet...
HP Officejet 4215v All-in-One Printer Logo
205 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
