Thin diagonal lines on screen. How to adjust whit balance ,screen end focus?
  • 700 Answers
Is that diagonal thin line about 10 to 20 degree slant? And then you have a very bright raster?
Then you set the flyback(for tube tv), I think its "screen" voltage is set too high adjust it slowly to lessen the brightness. It is commonly a small pot on the side of the flyback together with the focus pot.
If you have raster turn the tv on, use insulated screw diver, then slowly turn the knob to the direction(CC or CCW) where your raster go dim.
Be careful your dealing with live and high voltage. If your not inclined on electronics better not to.
Oh BTW, set your settings to normal.
Posted on Sep 30, 2009
I posted a problem on how to remove panel but I solved it. Now as I mentioned the tv comes on goes green then black no picture just sound. I followed instructions on adjusting G screw but it doesnt work...
Its possible one of two thing have occurred, you have maladjusted the G screen control on the high voltage screens and focus assembly. Turn down (counterclockwise) all three of the screen drivers. Adjust each until a light appears in the each lens, red green and blue. Go slow or lines will appear if set too high. If all three lamps stay lit after this adjustment the look at your screen with color level down to zero using your remote and the picture menu. Adjust the three color drives to get a good black and white balance appearing on the screen. Now adjust the color level from the picture menu back up to normal range.
If you still get green diagonal lines after this adjustment then I would suspect that the green lens has a heater to cathode short in the tube.
Oct 12, 2017 | Televison & Video
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
2 thin lines from top to bottom 5-6 in. from ends of screen.
if your set is a plasma then that can happen .. LCD screens are not known for that problem but it does happen to them also .. sometimes you can balance the screen a bit better by leaving a blank bright screen on for an hour or so ... also just playing wide screen often reduces the effect over time .. DLP type projection TVs dont normally do that but LCD and CRT type projections can .
Jun 24, 2010 | Televison & Video
Thin red arched lines, when screen is dark.
common problem with sony, focus and picture level need to be adjusted, should be done by a tech. (high voltage) in focus block.
Nov 24, 2009 | Sony KP-57WS500 57" Rear Projection...
Screen has too much green all of a sudden
Try balancing the tubes out, turn your color all the way down and the brightness in the middle, then find the focus block, it will be a block with 6 controls one row will say screen the other will say focus near the picture tubes, adjust the screen controls(one control for each color) until the picture has a good black and white look to it, then turn your color up and it should look fine. This is how i balance out the picture. But there is another method that allot of techs use, the other method is to adjust the brightness up until you see what is called retrace lines it is a jagged line going down the screen, once you see these lines back the adjustment down just until they disappear. Do this for all three colors. This method works but on an older set can throw the white balance off because of tube wear.
Sep 03, 2009 | Hitachi 57F500 57" Rear Projection...
My Sony Camera screen when i turn it on is white & has a pink line going diagonally through the screen
A multicolor vertical line may display on the camera LCD screen if there is glare on the subject being photographed. Avoid photographing very shiny surfaces that reflect excessive amount of light into the camera lens. Follow the procedure below to resolve this issue:
  1. Record the video or click the still pictures in a different lighting environment.
  2. On the camera, move the FOCUS AUTO/MANUAL switch to AUTO .
  3. Set the PLAY/STILL/MOVIE selector to MOVIE or STILL .
  4. Press the WHITE BALANCE button until the white balance is set to AUTO (no indicator).
  5. Record the video to new media.
  6. NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required.
Aug 13, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Thin red line question continued
they are marked "R", "G", "B" the "G" is in the middle. they are hard to see because it is imprinted in the molded plastic. also the words "screen" and "focus" are imprinted use a flashlight to see them. on most of these focus blocks the screen controls are the ones closest to the mounting screws. blue is to the right green in the middle and red to the left but not all of these are the same so check them before you turn them. the white blob is a type of glue to keep the posts from being turned and is a good referance point to get back to the same spot if you have gone too far with the adjustment.turn them carefully with a screw driver to brake the glue.then make your adjustment if this does not cure your problem you will need to replace the block have a tach do this ( critical white balance adjustment and picture tube voltages).
Mar 14, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Thin Red Lines on Top of Screen
Sorry, that is common for generic replacement xformers for
your make / model . There are some adjustments to minimize
the effect in servicer menu...............you can try turning down the
screen control a bit....................T.
Dec 21, 2007 | RCA F36650 36" TV
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
