Question about iRobot Roomba 530 Robotic Vacuum
My i-robot spins first to the right, moves back a little, then spins again. after about a minute it stops the red light flashes it says oh oh and beeps nine times. how can i fix this?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 66 Answers
Hey
Please look for other same problem posted here ;-)
You are probably facing a bumper sensor issue.
Try to clean the bumper first and if this goes on, either call iRobot service, or
take a look at this page for the step by step 9 beep fix.
Have fun
Avi
Posted on Apr 12, 2010
  • Daveyon Mayne
    Daveyon Mayne Nov 29, 2010
    Most times the issue can be of a faulty IR LEDs inside the bumper optical. eBay has the repair kit for cheap. Do a search on ebay for roomba bumper repair kit.
My iRobot Roomba 780 just won't start moving to do the cleaning. When I press the CLEAN button it moves back from the dock, turns 180?, and then moves forward about an inch and makes the uh-oh sound...
make sure all virtual wall lighthouses are turned off. Your Roomba may be getting a signal to not proceed if the lighthouses are turned ON and facing the Roomba
Feb 22, 2014 | Roomba 780 Robotic Vacuum
My roomba spins and moves back and after 2-3 minutes stops and makes the uh oh sound followed by 10-12 beeps I cant say Im sure how many. Some days before stopped cleaning and told me to remove and clean...
Your bump sensors are malfunctioning. I had the same problem.. The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great. I'd recommend it.
Jan 28, 2011 | iRobot Roomba 530 Robotic Vacuum
It keeps spinning on the spot and then stopping with the red light flashing
Your bump sensors are malfunctioning. I had the same problem. The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great. I'd recommend..
Dec 31, 2010 | iRobot Roomba 530 Robotic Vacuum
Spins, red light, many many beeps
look for 9 beep problem in FixYa
or see here
good luck
Avi
Apr 06, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba stops uh oh beep and run light flashes with status light on
please count the beeps and let us know of it
this tells you the kind of fault it has
look in your Roomba's user manual, this is all explained there ;-)
Avi
Mar 27, 2010 | Roomba Robotic Floor Bagless Vacuum
Roomba 560 won't run correctly
Hey
if it's 5 beeps it says: Drive wheel is stuck
You should clean both , push both in and out and confirm it turns freely
Good luck
Avi
Feb 24, 2010 | iRobot Roomba 560 Robotic Vacuum
Backs up spins in circles, then red light flashes and beeps
Sounds like either the battery is bad or not being charged properly with subsequent loss of programming.
Jul 23, 2009 | iRobot Roomba 500 Series Virtual Wall...
Can not charge thr battery
bbaker58,
When you press the "clean" button after charging, does the Roomba give you any audible tones? Those tones are the key to understanding failures in the 400 series. See chart below to decode those tones
If you get no tones at all, then either (1) you're not getting power from the battery to the main circuit board or (2) the main circuit board is dead. You really have to open the unit up to figure out which it is. Circuit board replacement is a pretty involved procedure since it requires disassembly of almost the entire robot. If you are brave and want to try it, replacement PCAs are available from places like www.RoboticVacParts.com. They are my favorite shop because they sell parts tha iRobot refuses to sell to consumers and they're prices always beat what iRobot charges.
Roomba Says
What It Means
What You Should Do
Plays 4-note song as Power button blinks RED
Play sound The battery is low and needs recharging
• Connect the robot to the charger or Home Base® and recharge the battery. “Ehh”
Play sound The Cliff Sensors are dirty or malfunctioning
• Pick up your robot and turn it over.*
• Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors.
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh"
A wheel is stuck or is not touching the ground
• Lift the robot and place it down again.
• Press the Clean button to restart the cycle. “Uh-oh” plus 1 beep
The robot's main brushes are stalled
• Pick up your robot, turn it over* and remove the wire guard.
• Look for something blocking the brushes; you may need to remove and reinstall the brushes to remove the obstruction. “Uh-oh” plus 2 beeps
The robot's Side Brush is stalled
• Pick up your robot and turn it over*
• Check to see if something is wrapped around the Side Brush.
• Remove the Side Brush with a screw driver and check for string or hair wrapped under it.
• Replace the Side Brush, place Roomba in the center of the room and press Clean to resume cleaning. “Uh-oh” plus 3 beeps
The robot's vacuum is stalled
• Remove and empty the Dirt Bin.
• Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin.
• Spin the Vacuum Impeller around, shaking out any debris that may be stuck.
• Replace the grill and the Dirt Bin. “Uh-oh” plus 4 beeps
Play sound
The robot's Drive Wheels are stalled
• Your robot may be stuck, or something may be caught in a wheel.
• If it's stuck, place it in the center of the room and press Clean. It should resume cleaning.
• If it is not stuck, lift the robot, turn it over* and look for something caught in the wheels. Test the wheels by pushing them in and out and making sure they rotate freely. Place robot in the center of the room, press Clean, and it should resume cleaning.
If this continues to happen every time you clean, you may need a software upgrade. Contact iRobot Customer Support.
“Uh-oh” plus 5 beeps
The robot's Cliff Sensors are obstructed
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out. “Uh-oh” plus 6 beeps
The robot's Wheel Drop Sensors are overloaded (robot is stuck in a bumpy area)
• Pick up your robot, place it in the center of the room, then power it off and then on again.
• Select the cleaning cycle you prefer and let it go to work.
“Uh-oh” plus 9 beeps
The robot's Wheel Drop Sensors have failed at startup
• This failure requires you to contact iRobot Customer Support. Click here to send us an email. “Uh-oh” plus 10 beeps
The robot's bumper is not registering obstacles
• If the robot travels for a long distance without bumping into anything (which would be unusual), it might think it’s stuck and can’t move; press Clean again and it should resume cleaning.
Jun 02, 2009 | Roomba Robotic Floor Bagless Vacuum
Roomba red 4100 cleans in small circle stops starts agains cleans small circle stops then status light comes on and clean button blinks.
When the status light comes on, the Roomba is going to sing "uh-oh," and then beep a number of times. Count the beeps. They're a code that tells you what's wrong with the Roomba. You can check iRobot's website for a chart of beep codes. Search "What is Roomba saying to me?" on the troubleshooting page.
Apr 06, 2009 | iRobot Roomba Red 4100 Bagless Robotic...
iRobot Roomba 530 Robotic Vacuum Logo
831 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
