Question about SanDisk Sansa e250 MP3 Player
Couldn´t connect SanDisk Sansa e250 to Computer
When I connect the mp3player to USB it detects a new hardware, but at the of of new hardware installation it Says:A service installation section in this INF is invalid.
My USB connection is fine because when i connect the mp3player in Bios or DOS in starts recharging.
Please Help!!!
  • bgorja20 Dec 20, 2007
    Well you know i m not stupid u know. I know hot to plug in the mp3player tu USB. Is it maybe something wrong with my Windows XP SP2. The other MP3 players like philips or teac work. Are there any drivers for Windows XP
  • princess3814 Dec 25, 2008
    when the usb cord is pluged in it charges but can not get the hardware on my computer! I have windows XP too
    Problem Solver:
  • 12 Answers
I don't know what to tell you, but since nobody else is helping. Make sure that you've got the mp3 player plugged into a usb port.
Oh, and hopefully you're running XP or Vista. Sandisk requires it.
Posted on Dec 20, 2007
Accidentally deleted everything on sansa e250 computer can't see device.
Hi there
I can understand issue. When you say the device is not detected. Then it could be an issue with the system files would have got deleted because of the format.
To fix this issue, i would recommend you to keep the device in MTP mode ( Menu->Settings->USB->MTP).
Connect the device to the computer.
It will give the message as Found New Hardware.
Go ahead and install the MTP drivers by following on screen instruction.
Then Unplug the device.
Restart the computer.
Connect the device.
Now we are offset and device will be detected.
IF still you have issue kindly revert..... Good luck
Feb 18, 2010 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player with Mac? Is there any driver to make it compatible with Mac platform? Thank you
NOTE: MAC computers do NOT support MTP modes of USB conectivity in a MP player. A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized. MAC computers supports Sansa players in MSC mode Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
Check in the System Profiler Open System Profiler from the Utilities folder, which is inside the Applications folder. From the Contents column on the left, under the Hardware header, select USB; the panel to the right will show all the USB devices that the computer recognizes. It may not identify them correctly by name, but it should have the right number of devices listed. . Navigate to USB Mode settings. Sansa View - From the Main Menu, select More > Settings/Options > System Settings > USB Mode.
Sansa Fuze and Sansa Clip+ - From the Main Menu, select Settings > System Settings > USB Mode.
Sansa Clip, e200v1 series, e200v2 series and e200R - From the Main Menu, select Settings > USB Mode.
2. Select Auto Detect, MTP or MSC. e200R - PlayforSure is MTP and Rhapsody is MSC
See this tip posted here on this site for a better explanation on the modes - MTP and MSC. Solve your MP3 Player Connection Problem.
Feb 05, 2010 | SanDisk Sansa e250 MP3 Player
My sandisk e250 sansa mp3 player does not boot. shows only SanDisk logo. My computer also do not detect the player as new hardware.
  1. Turn off player.
  2. Slide HOLD button to locked position (towards headphone jack).
  3. Press and hold RECORD while connecting to the PC.
  4. Release RECORD when you see "welcome to recovery mode" on the player's LCD.
  5. Open My Computer/Windows Explorer and see if you can find a new removable flash drive labeled "16MB-FORMAT".
  6. Right click on 16MB-FORMAT and select New Folder.
  7. Name the new folder "sansa.fmt" (without the quotes).
  8. Wait one minute.
  9. Reset HOLD back to unlocked position.
  10. Disconnect player from PC.
  11. Wait for player to reboot.
Jan 27, 2010 | SanDisk Sansa e250 MP3 Player
Sansa will not detect
If you are using a USB connector [that connects extra ports to your computer] it sometimes doesnt work... so if possible hook the USB sansa cable to the main ports in the back of the server. It might also work to hook it in, and then go to 'My Computer' and see if it shows up there. Good Luck =]
Jun 05, 2009 | SanDisk Sansa e250 MP3 Player
Charging pro
I believe the cable is the charger. I have an e250 which charges from the computer. Simply connect the player to the computer using the cable, and when the player is detected by the computer - it is charging!
My friend have a different charger though, but she bought it from the store.
Mar 27, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Not able to sync
I went to device manager and uninstall the device. Then went into Add hardware and reinstall the device and it worked.
Mar 19, 2009 | SanDisk Sansa e250 MP3 Player
Connecting sandisk mp3 player to a computer
try going to click on support and then click on your model player. Go through the troubleshooting questions and find your problem. there should be a few solutions for you to try. Good luck :)
Jan 27, 2009 | SanDisk Sansa e250 MP3 Player
My computer charges the sansa e250 but does not detect it for me to load the songs
chekea el cable, puede ser una linea de datos rota
check the cable, may be a cutted data line
Apr 16, 2008 | SanDisk Sansa e200 MP3 Player
WMP won't detect my MP3
See if this helps: -Close all programmes on your computer. -Turn off your Sansa e250. -Attach the cable into the USB port of your computer before attaching it into the actual e250. -The scroll wheel on the Sansa should have turned on by now. -Then it's just a matter of waiting for a few seconds. -Try opening Windows Media Player to see if it detects your device. Otherwise, be patient. Goodluck.
Mar 15, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
240 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
