Question about Samsung J700 Cellular Phone
I am trying to put an audio file on to my phone but it keeps sending it to the phone which dosent have enoughth memory how do i send it to the memory card
  • 3 Answers
SOURCE: files not getting saved in memory card
the samsung j 600 saves the bluetooth transfered files only in the phone memory.you need to move it to the card .and if ur phone memory is full then you can't download via blutooth unless you free some.
thank you
Posted on Jan 24, 2009
  • 3 Answers
SOURCE: on my samsung j700 memory card dosent work on samsung pc studio 3
I HAVE THIS PROBLEM but what i do is move all the files on my files to the micro sd then i copy some stuff from my Samson pc studio 3 to my phone until my memory is full then i repeat it until i get what i want there is one problem i takes a LONG TIME.
Posted on Aug 10, 2009
nabulaila975
  • 205 Answers
SOURCE: My Memoir keeps saying I have no more memory left
rty this code *2726*3855#
Posted on Apr 14, 2010
Testimonial: "Quickly gave me a solution that worked after headaches dealing with the carrier & no answers from them! THANKS!"
  • 239 Answers
SOURCE: I can't save files or data directly to memory card
Samsung s3310 cannot import files to memory card directly,When we are transferring through Bluetooth.When we are transferring files through Bluetooth,it stores in default to phone memory and this memory cannot be changed to memory card memory.
There is one way to transfer large files with 500megabytes size through compression of file and splitting up to many sizes.We can use any software for compression and splitting up."ERROR MESSAGE:memory is full" can be avoided through this above way.
Posted on May 22, 2010
SOURCE: cannot access to my memory card files???
try to format the memory card or scan it with the kaspersky 2010
Posted on May 30, 2010
Testimonial: "fixed"
When i send video files via bluetooth from other mobiles to my nokia 6300, the message displays on the screen " file sending failed".Audio files received successfully but video files not. there...
Generally video files are bigger in memory than audio files.So firstly you check the memory status of Phone memory not for the mmc memory.And Check that the memory Card which you are using is less than 1GB Coz more than 1GB mmc is not supported in this model.Even if the mmc has enough space of memory however the size of the mmc is more than 1GB we cannot do this thing sometimes.So try to do what if not.
Apr 07, 2011 | Nokia 6300 Cellular Phone
Won,t send or receive pictures lg 290c
To send or receive pictures or any file, you need to be sure that your phones bluetooth is turned on, without it your phone will not be able to send or receive pictures or any files. Also, you can transfer files to a computer using a USB cable, connect it to a computer and other devices that Has a USB hub. Files can also be transferred through the SD memory card, you can transfer pictures to the memory card and remove it from your device, then you turn off your phone, remove the memory card, install it into other devices that allows memory cards, then you copy pictures from the memory card to other devices.
To use your bluetooth in transferring the pictures from your phone to other bluetooth devices, then you turn on youe bluetooth by going to the phones menu, select the settings, then you go to the bluetooth and turn it on, make sure the bluetooth device of other phones and devices are turned on then you select the picture to send and select via bluetooth, it will search for the available bluetooth devices, then you select the one you are willing to send your pictures to then you either pair id the device is not familiar, ensure you use a password that is easy to remember to pair with the other device.
That way your phone will be able to send the pictures. That should solve the problem. Hope this information assisted you!
Jan 10, 2011 | LG Cell Phones
I cant send music files to it via bluetooth it keeps telling me to delete memory and now ive deleted everything and it still wont let me send music files via bluetooth. I have a nokia navigator 6110
make sure that all of the files that you have sent before via bleutooth was move on your memory card.take a lokk at your phone memory on how much is the free space.because once you transfer file via bluetooth it uses your phone memory. check your inbox outbox and myfolders.delete or move the files that is in there.then try to send via bluetooth again.hope I explained it well.
Apr 15, 2010 | Nokia 6110 Navigator Cell Phone
Hi i have lg kp260 and everytime i want to send a muzic on my pho
one way to do it is, copy the files to your memory card, insert your memory card to your computer and drag and drop files. if your computer doesn't have a memory card slot, consider borrowing usb memory card reader from a friend and start copying the files from your memory card to your pc.
if the files you are sending is of big capacity, there is a possibility that phone may restart due to low memory, while you are sending files, your phone memory becomes low, they are sharing memories page, it may be the cause. try sending a small capacity, like images, and check if it will off. if this happens, then, go to your nearest service center and have it check.
take care..
Feb 27, 2010 | LG KP260 Cell Phone
When i send a text it keeps saying sending
sir/mam,
try to refresh your phone remove battery,sim card and memory card for at list 1 minute then put it again then test, if not reformat/reprogram your phone, go to cellphone repair shop.
Jan 01, 2010 | Samsung Propel A767 Cell Phone
Can't save music to external memory
ive been trying for ages to do this and its so easy but no one seems to be explaining it easy! Your phone without the memory card only holds one or two songs. you must have songs in there for it to say memory full. Go to this song press options , file, move to extrenal. Now try and send a song through bluetooth. You will be able to recieve it now you have freed up spave on the phones own memory. Remember to save it to external straight away so u can recieve the next item. Easy peasy!
Aug 21, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
LG KS360 that keeps saying no memory even with a memory card
Hello i ahve the same problem too, i just want it to save on to my 2gb memory card ??? can anyone help me plz
Jul 05, 2009 | LG Vu CU920 Cellular Phone
I'm not able to send any file bigger than phone memory with ngage
u can send files via bluetooth using card memory as messaging memory ,i know this option is not in ngage, u can turn the messaging memory using the software "msvDrive"just install the msvdirve.sis on ur ngage and the memory will change when u execute it.
May 19, 2009 | Nokia N-Gage QD Console
Saving songs on sd memory card
try just sending music from your pc to the memory card
Mar 27, 2008 | Motorola Mobility i870 Cellular Phone
LG Prada Phone and how to download mp3 onto it
I have posted information in 'hints and tips' regarding media files (pictures mp3s etc).  The first thing to remember when sending files to your phone is that they have to be done one at a time as the phone memory is limited.  The phone has a memory card inside it which is extra/external to the phone memory.  What is confusing is that you cannot send files directly to this memory card so each file you send to the phone has to be moved to the 'external memory' before you send another to the phone.
Jan 30, 2008 | LG Prada KE850 Cellular Phone
Samsung J700 Cellular Phone Logo
14 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
