Dc Jack replacement
I have
Toshiba Satellite L35-S2151 PSL33U-026018 How to replace Power jack ?
    Problem Solver:
  • 13 Answers
It is usually not the Jack itself that has the problem. It is the connection of the battery to the MB. The pins entering the MB get loose with time and heat caused by oxidized connectors and have to be touched with a hot soldering iron to re assert the connections. Delicate work better done by someone used to doing these things.
Posted on Oct 29, 2012
  • 177 Answers
You have to remove the screen from the laptop (in most cases) open the lower plastic case ,lift out the otherboard,carefully de-solder the dc-jack and then solder in a new dc-jack,and the re-assemble the whole thing.
Posted on Feb 09, 2008
My toshiba satellite l35 wont turn on,,,the light blinks then shuts off ,,,thats all it does
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 17, 2011 | Computers & Internet
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
May 19, 2010 | Toshiba Satellite P15-S420 Notebook
Fixing DC Jack for Toshiba Satellite L35 cost how
I believe the L35 uses what is considered a satellite power jack which means the actual jack is not soldered to the motherboard but uses a cable and plug, therefore is the easiest of the power jack repairs. The cable can be found on ebay for around 30 bucks or less. I usually charge 50 bucks for the labor plus the part, the laptop has to be disassembled to complete the repair. Below is a link for disassembly if you want to use it as a reference and perfrom the work yourself.....
Jan 04, 2010 | Toshiba Satellite L35-S2366 Notebook
DC Jack pin is broken on my Toshiba satellite p25 S607
you have to strip down the laptop so you can access the underside of the motherbord then you need to desolder the solderd connectors and remove the DC jack
then put the new DC jack in its place and solder back in place
please note this is quiet a big job and requires knowlage of laptops
Nov 22, 2009 | Toshiba Satellite P25-S607 Notebook
My wife has a toshiba satellite L35-S2151 laptop. When she went to turn it on, the orange battery light flashes 8 times and nothing else happens. Any clue as to what is going on?
Try turning on the device with the power connected if it turns on, keep the power plugged in for the entire day. See if you will have the same problem without the power supply. If it still occurs without the power supply, you may have a bad battery, you can verify if you can get swap battery from a similar laptop.
Oct 01, 2009 | Toshiba Satellite L35-S2366 Notebook
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
Toshiba Satellite no power
replace only the power jack and clean the power supply board with some can find the jack in some electronic shop..
Jan 04, 2009 | Toshiba Satellite M45-S169 Notebook
Steps to replace DC power jack L15-S104
its not so easy to replace you dc jack please don't try your self....
Apr 25, 2008 | Toshiba Satellite L15-S104 Notebook
Computers & Internet Logo
440 people viewed this question
David Payne
David Payne
