Question about Garden
I REQUIRE THE DIAGRAME FOR PUTTING A NEW TRANSMISSION BELT AND PTO BELT ON THE ABOVE MODEL
  • 437 Answers
Try going to www.precisionope.com and looking for a diagram there.
you did not list the brand or model in this request.
Posted on Sep 30, 2009
How to change pto belt on club cadet 1046
To replace a transmission drive belt on a Cub Cadet LT1046 you need to remove the deck, preferably put the front wheels up on blocks or stands, unplug the PTO power (directly under the engine, which can be a pain ) You need a 5/8" socket to get the bolt out of the PTO pulley assy.(electric clutch). If you don't have an impact wrench take a spark plug out and push rope into the hole. This will bind the cylinder and keep the drive shaft from turning. Remove rope and replace plug when finished. Battery and/or spark plug wires should be removed for this process for safety.
The PTO may be stuck on there so you may want to tap it with a hammer and a block of wood carefully to release it. Loosen old belt from tensioner pulley. Lower engine pully on drive shaft, below pully "keys". It may be difficult to remove. Spray with "PB Blaster" or similar bolt loosener spray. Remove old belt from engine pulley first, transmission pulley last. Remember how belt goes around pulleys before doing so, make a diagram to help.
You'll need to put the belt on the transmission pulley first then thread the belt up to the engine pulley. Thread your belt back through the pulleys and tensioner (make sure your spring is strong enough to tension the belt or buy a new one).
The PTO pulley is "keyed" on the shaft. Replace bolt and washer. Torque bolt to 38-50 ft. lbs. using the rope meathod as described before. Put your deck back on and you're ready to mow again
May 11, 2017 | Garden
How to replace belt on bmw e60 2006 diagrame
Is the drive belt still fitted? If so draw a diagram of all the pulleys connect the pulleys in your piccy with lines as per your belt run on the engine.There may be an automatic tensioner you will require a tool to operate this You should be able to replace the belt now. Hope this is helpful.
Nov 29, 2014 | 2006 BMW 5 Series
How to engage blades the new craftsman pro series 54" 24hp mower
flip the pto switch there will be a little clutch diagrame above it
Sep 07, 2014 | Garden
Trying to change the drive belt on a GTX 2446 Troy Bilt garden lawn mower rider can't get the pulley upper plate of the motor
You must remove the electric PTO clutch in order to remove the motion drive belt. Also it probably require you remove the bolts holding transmission if your going and secondary drive so can it off and on.
Aug 09, 2014 | Garden
Dar n PTO Clutch
Most likely low tension. first, double and triple check the routing of the belt against the manual. then make sure you have the correct belt.
May 04, 2014 | Cub Cadet Garden
Pto on yardman 42 lnch cut belt will not go tight
A spring keeps the tension on a PTO belt. It may be broke or unhooked.
Jan 13, 2013 | Craftsman Garden
Replace drive belt lt 1000
look for tag on inside of hood for belt numbers. Or get model number off of tag under seat that starts with a 917. then call the 800 number.
instructions... Remove deck, remove pto pulley/ clutch, lock brake, remove crank pully and belt from crankshaft then remove belt from transmission and idler pulleys. Reassemble in reverse order with new belt ensureing the belt is not snagged on any belt guides and all idler pulleys are free.. ( PS sharpen blades while deck is off and check deck belt)
Oct 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Installation of motor drive belt on cub cadet tractor
This one's a PITA. That said, I had to remove the PTO clutch and pulley, the seat, the brake and transmission pedals, and finally the sheet metal that constitutes the fenders and foot plates.
Belt is put over the fan above the transmission and onto the pulley there, then run along bottom of main frame towards the front until it reaches the engine drive shaft.
The belt goes onto a pulley on the engine drive shaft (above the PTO clutch and pulley, which have to come off). I couldn't slide the drive pulley down the shaft, so pulled the 4 engine mounting bolts and move the engine around slightly to allow putting the new belt on between the pulley and it's surrounding sheet metal. Once the belt was on, and before any other steps, I realigned the engine mounting holes and replace the bolts.
The belt is then run around the pulleys under the middle section of the tractor. Leave the spring loaded idler pulley for last. you might need to loosen (not remove) the bolt that goes through the idler pulley in order to get the belt on. The biggest fight is pulling the spring loaded pulley over so that you can put the belt onto it.
Once the belt is fully routed over all pulleys. Reinstall everything that you had to remove - and you should be good-to-go.
ONE LAST COMMENT: Many shops sell belts that DON'T have Kevlar. Make sure you but the one WITH Kevlar. The others rarely last one season.
Aug 31, 2012 | Cub Cadet Riding Lawn Garden Tractor 25hp...
We have craftsman lawnmower model944605120 can't get the belt back on help
Which belt are you referring to, the PTO (Mower Deck) or the Drive Belt (to the transmission).
Jun 30, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
