Question about Mitsubishi WS-55809 55" Rear Projection Television
WS-55809 cloudy foggy picture
I get intermittent cloudy and foggy picture, as though the color has been 95% removed. This sometimes happens when I turn it on, goes away after I power on and off several times, sometimes it persists. Other times it works normally for days. After removing the front panel I noticed a hard silicone-like white ooze on each of the guns, not reaching the circuit board, just a hardend white blob coming from the black plastic housing clinging to the side of the tube. Is this the coolant leaking? Could this be the source of my problem? If so, what do I do? Can this be a DIY fix?
  • SD Tech
    SD Tech May 11, 2010
    THE material is there to make it clear if anyone has tampered with those assemblies---it is not a Coolant leak (Glycol)
    Top Expert:
  • Mitsubishi Master
  • 21,413 Answers
Check the EHT splitter assembly, this feeds the focus grids on the output tubes.
BE CAREFUL as there is more than 25kVolts there!
Posted on Apr 23, 2017
5 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Mitsubishi WS 55809
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 21, 2008
Slinteriors
  • 8617 Answers
SOURCE: mitsubishi ws-55809 needs new red tube
you can get a red mitsubishi tube at the following link and it comes with free shipping. If youre not sure which one to order, leave them a email and they will respond quickly, just let them know your model number and what youre needing. they are listed under the projection CRT catagory on the left side of their page. Here's the link.
http://servicemanuals.vstore.ca/
Posted on Jun 22, 2008
tatunka
  • 85 Answers
SOURCE: Mitsubishi WS-55809 won't turn on
find your reset button
Posted on Nov 14, 2008
Ecollier2012
  • 3459 Answers
SOURCE: Mitsubishi ws-55809 goes to white foggy screen occasionally
It will cost between 30.00 - 70.00 dollars to do it yourself depending on if you buy the parts seperate or as kit.
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 27, 2009
My Mitsubishi ws-55809 works fine although the screen turn pink but the picture is still visible. After a while it goes back to perfect color. Then it repeats this back and forth. Sometimes it will fl
Problem is likely on the small circuit board that plugs onto the bottom of the red picture tube---be careful as dangerous voltages in and around that board---each of the three picture tubes has a small board that plugs on the end of the tube.
Oct 21, 2012 | Mitsubishi WS-55809 55" Rear Projection...
My Mitsubishi HD 1080 Model WS-55809 - the colors are distored. The picture is like double vision. For example the menu words all have yellow & red shadows.
Ur convergence it dead.U know how to solders?Buy a convergence kit.These websites have the kit.Tv repair World.com,Tv repair kits.
Dec 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Sep 25, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi ws-55809 distorted picture
Sounds like you are having a convergence error.
What you could do is either replace the TV or have some wires/circuits/boards replaced.
Shop around for prices.
If you're lucky you'll find someone willing to do a free estimate, as replacing anything on these will set you back a few hundred...at least.
Hopefully, in your case, the problem can be solved by tightening a screw or two.
Jul 15, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Curved in at top and bottom and rainbow colors on bottom
REPLACE ALL STK?????? CONVERGENCE AMP IC'S & CHECK RESISTORS FOR THAT CIRCIUT
Apr 12, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Black and white picture
you have the cables hooked up the wrong way
Nov 09, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi tv model WS-55809
that happened to me and i just gently hit it on the top and it fixed itself
Jun 28, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809
can you post a picture of what the picture looks like? If so I should be able to diagnose the problem
Apr 30, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Cloudy pic
Do the self test on threads or ctechnicians.com
Dec 28, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55809 55" Rear Projection Television Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
