Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My husband did some checking and found that the outside unit was running as normal, but there was no cool air coming through the vents inside the house. turning the a/c unit off at the thermostat did NOT turn off the outside unit...was only able to do this at the circuit breaker. It seems that the fan is still blowing (when everything is on) but is not cooling. Is this related to our thermostat? Do we need to have the freon level checked? I apologize for not having specifics on our unit, other than it is a Trane, approx 14 years old. The inside unit was replaced about 5 years ago.
  • 252 Answers
Nope, nope, sounds like a stuck contactor in the electrical compartment of the condenser, but there are actually several things that could cause it.
Posted on Oct 01, 2009
My American Standard Heritage 11 unit was not working properly when i came home from work and the temperture in the house according to the thermostat show the temperture in the house to be 85 degree&#
the dual run capacitor is bad located in main panel of unit size of small red bull can it will be swelled up on top indicating it bad get on at electric motor or electric supply house most ac stores wont sell it has a rating like 35/5 370
Aug 27, 2012 | Heating & Cooling
I have a programmable thermostat that I set to 68 at night. The system turns on and runs, but when I woke up this morning, the tempterature in my house was 58. I felt near a vent and it felt like it was...
Hello, sounds like the units high limit switch is opening and shutting down the burners. When this happens the blower motor and inducer motor will run nonstop....and this is why you probably just felt cool air blowing from the air duct. Usually a dirty filter, blower wheel or weak blower motor can cause the units limit switch to open.
Dec 01, 2011 | Heating & Cooling
Honewell RTH 7500 Temp Sensor Problem?
Check your installer configuration. If you have it set up, in the configuration, to match your system, and you can turn it up by 5 degrees with no heat, it may be a fault at the tstat. If and when it fails to cycle on, you can jump R to W, by touching those 2 terminal/wires together, and it should begin the heat process. If it don't, then it's not your tstat. Hope this helps!
Mar 12, 2017 | Heating & Cooling
What's your problem? I have a Airtron furnace/air cond unit and last night I smelled a odor that of something electrical burning. I also noticed that the heating unit stayed on and continued to blow...
I'm willing to bet a relay burned up. You likely have your tstat set to auto changeover, meaning it automatically goes from heat to cool to maintain desired set points??
Jun 21, 2017 | Heating & Cooling
Earlier this week, I noticed that the house felt "stuffy" but the thermostat showed everything to be cooling as expected. Last night, the house was definitely warmer than expected when we got home. My...
If both fans runs (inside and outside), check if the compresor runs , if does probably the unit is low in freon and needs to be recharged after the freon leak has been fixed (remember this is a seal system and it shouldn't leak), but if the compressor doesn't work , it could be the capacitor , the pressure switch (if it's low on freon ) or the compreessor itself.But befor do anything ,if you have a digital thermostat replce the batteries.
Sep 30, 2009 | Ruud UBHC Air Conditioner
Day / Night HVAC is running cool air BUT the furnace is running 2
Strange. Does the thermostat control both the air conditioning units and the furnace. If not make sure the furnace thermostat is turned down to below 65 degrees.
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
Cooling problem with a ge top freezer refrigerator
I have one that did the same. The coil in the back of the freezer was frosting up because it wasn't defrosting like it was supposed to. I noticed that the thermostat looked damaged so I ordered a new one from sears parts direct which by the way will show a diagram of the model you have. I just installed it last night so I will post how it comes out. This morning the freezer has a burnt smell but I am hoping its from the defrost not working for a while!
Mar 03, 2008 | GE Hotpoint Top-Freezer Refrigerator
Heating & Cooling Logo
103 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
