Question about Samsung BlackJack II Smartphone
The battery is relatively new and won't hold a charge very long. Could this have anything to do with the amt of txt or data usage?
  • 105 Answers
Yes the more you use your phone the less your battery will stay charge and by whatever else you do with the phone like watch movie listen to music the brightness on the phone everything affect the battery hope this was helpful:)
Posted on Nov 15, 2009
Does the New apple update to OS10 does it use data while on wifi and double charge users?
I have not seen that happen. I am on my home wifi 90% of the time and my cellular data usage has not changed. In my cellular settings I turn off most of my apps from being able to use cellular data, I only allow my important apps to use cellular data when not on wifi and this helps control usage in general, but I have not had to change it with the 10.0.x updates.
Oct 03, 2016 | Apple iPhone Smartphone
Why does my battery not hold its charge
More than likely, like all batteries, it has outlived its usefulness - unless its relatively new or unless you are one of those folks whose daily cell phone usage exceeds the hours of sleep you get each night. But generally, when a battery of any kind - car included- won't any longer hold its charge, it is dead or dying, or perhaps the charger is defective in some way. Call the manufacturer or the store where you purchased it.
Aug 14, 2016 | Cell Phones
I have 100% charge but only 17 secs usage on relatively new battery, a fix please?
The battery, even though relatively new, could be failing and unable to hold a charge. Replacement may be the only practical answer.
Nov 13, 2014 | Computers & Internet
Sony vaio vgn-nr285E battery won't hold a charge
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 03, 2011 | Sony VAIO VGN-NR285E/T Laptop
My dyson handheld charges fully, but keeps cutting out when using. About 7 seconds is the longest continual usage time
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to replace the battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
May 21, 2011 | Dyson DC16 Root 6 Bagless Handheld...
My new samsung galaxy ace has a VERY short battery life.. it doesnt matter if i change the settings.. it only last for about 1 day at most.. not even 24 hours.. how can i fix this?
"If your battery sat on the shelf for a year, then it has deterioated enough to where it would only hold 1/ 2 to 2/ 3 the original charge."
galaxy ace is relatively new. nothing you say makes sense.
if you don't use data service, you can switch to gsm (not 3g) to preserve battery life. works with me across devices.
Feb 24, 2011 | Samsung Cell Phones
Sony Ericsson K770i does not hold charge :(
Replace the battery, but I am assuming you mean 10% per hour with normal use. If you are on the 3G, playing music, making calls, thats all you're probably going to get. Thats 10 hours, if you use it often I wouldn't expect any more. I charge my new Blackberry every night, and I have to.
If not, then definitely a new battery, because 10% per hour without data or music and usage, it must be the battery, probably replace the charger too if you want to be really really certain.
Jan 27, 2010 | Sony Ericsson K770i Purple 3G Camera...
How do I charge my daughters amt mp3 hello kitty clip on. when I plug it into my computer do I turn the player on to charge or keep it off. she was kind enough to lose the directions.
G'Day To charge your AMT mp3 player you must first plug it into your PC USB port using the supplied cable. Next turn on the player using the sliding switch on its side.The indicator shows the battery is charging, but it is not. To make it charge you have to turn the player off. To do this, hold down the "play" button until you get the "Bye-Bye" message. The screen will go black and the battery will now charge. Do not use the slide swich to turn off!...woozie. Australia
Jan 18, 2010 | Audio Players & Recorders
Battery?, wiring??
If your Alternator didn't charging the battery, even though you brand new battery will not last. So there is two possible cause, 1) Your Alternator is not functioning. 2) there is a wiring problem that causing your battery to discharge easily, but you check it after you switch off the key remove the battery negative terminal then touch it back to batt term. and see if there is little blue spark, if does your wiring system got problem. If not, so your Alternator do not charge the battery.
Jun 01, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
The Battery Won't Hold A Charge
unlikely
just go out and buy a new battery for the item
remember battery life depends on the data download usage so if you are a big fan of movies and the like , the battery life will be short
Sep 08, 2017 | Uniden Cordless Phone
Samsung BlackJack II Smartphone Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
