Question about Bosch Dishwashers
Bosch SHE45M Odor? What can I do
BoschSHE45M Odor? What can I do
    President:
  • 1,653 Answers
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean. Do this on a regular basis.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Add 1/4 cup (60 mL) of liquid chlorine bleach to tthe machine. DO NOT use more than 1/4 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C) if you have one or use a 60C wash. DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure as necessary.
Posted on Sep 30, 2009
Bosch dishwasher model she6af02uc/03 odor
try running some bleach in the wash cycle
Aug 28, 2012 | Bosch Dishwashers
DISH WASHER WON'T DRAIN BOSCH SHE45M
Hi:
This maybe due to a clogged drain hose, sometimes food will clog the drain valve causing the unit not to drain the water. Check the drain plug for clogged debris in it.
Jan 27, 2011 | Bosch Dishwashers
Pump runs but nothing is pumped out
I just had a tech over,have the same problem with my SHE45M. Was told the plastic impeller is spinning on shaft. New to replace the drain pump.
Oct 16, 2010 | Bosch 24 in. SGS43C12 Classixx...
Continuous Odor in the machine
I would check your drain line. If its connected to the disposal make sure its elevated you may be getting back flow from the disposal into the dishwasher. Hope this helps _MJ_
May 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a BOSCH model 53L06UC dishwasher and was
every bosch dishwasher unit is different. you can get odor from different source. #1 solution to fight odor is the proper maintenance. every month run the cycle with just a cup of vinegar on a hot wash. i am a old bosch tech and alot of people dont add the jet dry properly. this is for drying,spots and-cleaning you must add the jet dry or rinse agent (same thing)into the compartment. close compartment,then lower and raise door 3 times,then fill again repeat until you cant add anymore then it is filled.if this help please send me a 4 thumbs up post. thanks
Feb 28, 2010 | Dishwashers
We did not get a install book with our new dishwasher. it is the she 45 mo model. need them badly, because it is different than our old machine. we bought the display model
Hi
You can download the Bosch Dishwashers installation manual at this link. Just click on "Get this Manual"
http://kitchen.manualsonline.com/manuals/mfg/bosch/dishwasher_1.html
I have also included the actual users guide and operating manual for the SHE45 which is available here;
http://kitchen.manualsonline.com/manuals/mfg/bosch/she45m.html
Please allow time for the downloads to complete as they are large PDF files - then print or save to your computer as required.
Hope this helps. Please do rate my answer. Many Thanks.
Sep 07, 2009 | Dishwashers
Bosch SHE45M - Drain problem
Hi..
please check whether you have something in the drainpump locking it up or a blockage somewhere between the sink and the unit or the pump itself has failed or not.
thanks
May 04, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bad odor when open door after cycle
This is just a suggestion, run a cycle and after a few mins of it washing, open the door and add a cup of bleach and let the washer run. See if this helps.
Apr 09, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Odor 2 days after cycle
After you have unloaded the the dishwasher, prop the door open with the upper rack out.
Let the inside air out. After a short time the remaining moisture will evaporate. Stainless steel dishwashers are prone to an odor if you do not use the machine daily. There are after market products that are citrus based that will help. Check with Bosch.
Jun 14, 2008 | Bosch Evolution 500 SHE45M06UC Built-in...
Bosch dishwasher will not drain - causing moldy odor
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
212 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
