Assuming that this is a basic Kenmore / Whirlpool top load, direct drive neutral drain washer, please see the following Whirlpool (PDF) manual.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
FL CODE AND WILL NOT DRAIN COULD SOMEONE PLEASE HELP
SOURCE: Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
Thank you for your post, Rey!
From what you have described your Frigidaire washer will not go into a spin cycle. This could be a possible issue with your motor, control panel, or speed board. I would recommend performing a reset on your washer and you can do that by unplugging the washer for at least ten minutes. If that does not correct your issue I would suggest having a professional technician since it could be anyone of these underlying issues. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
