Televison & Video Logo
Posted on Sep 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 52inch rca projectin tv model hd52w59 i
I have a 52inch rca projectin tv model hd52w59 i have alot of colors and it looks like all the colors are tryin to meet in the middle
Chi Chu
Level 3:
  • RCA Master 8,457 Answers
  • Posted on Oct 05, 2009
Chi Chu
RCA Master
Level 3:
Answers
8457
Questions
0
Helped
2822508
Points
26282
Ur convergence it dead,U know how to solder?Buy a covergence kit,replace what in that kit.Tries these Websites,Tv Repair World.com,Ebay.com.
1helpful
My RCA Model number HD52W59 has color distortion and double image and sunk picture in the middle. Is there any way of fixing this problem. This tv is a projection TV
Yes.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
1helpful
2answers
My RCA HD52W59 tv loses convergence every time I turn it off. it has been a problem off and on for almost 2 years. Coincidently kicking the tv fixed it for several months. It is worse than ever now. How do...
this is an easy fix , ur problem is on the deflection board , look at the flyback transformer it is a big black component there is loose connection u need to do soldered connection on the flyback than check a pico fuse look like a squer little box brow color , look very care full at this pico fuse u need a metter to check for continue the value is 1/2 watt 250 volts
Rca hdtv 52inch will play fine then picture goes black but still has sound.. after a few mins.picture will come back on , and will play fine could last all day or may go out again in a few mins.
My tv is relatively new, but the bad thing is that I had an old; big screen tube type rca model; home theatre, that was heavier than a car, and it went out, due to the cracking and popping sound, off sometimes, and back on.
What is strange is the new tv now, the hdtv, light weight, about five years old, is doing the same thing. Actually, now, the power will not even come on. The lcd green light in the front goes on and off.
Take no offense, but I thought I would not have these problems anymore. What do you suggest?
2helpful
I have color misaligned in my RCA HD52W59 tv. I can see three different colors yellow, blue and red. It is intermittent issue. Please What is the best solution for that?
Go to menu then setup if you do not see convergence in the menu then you have a Blowed Fuse FL231 its on right side of FBT flyback transfomer will be 3 small brown looking caps But are fuses it will be the one in the Middle! Go to Partstore.com Look for FL231
Rca hd52w59 making a high pitch buzzing sound
is this just a whine since you describe no problem with the picture it dosent jump or change color or flicker. there may be an easy fix this sounds like some coils oscillating and i tell you what can be done you can take some silcon and put on these coils to dampen then vibrations. now ther may be other problems but without looking this is my first gues ...where are these coils? ll037 on the power supply deflection board
RCA 52inch Model R52WH77 HDTV
may i suggest reading the ariticle the fl231 problem in my tips and tricks section of my profile. YOu MAY have a 5 dollars 30 minuter fix. Determine if you have the convergence option under the setup option of the customer menu. if you dont then congratulations you have a simple fix. i you do have the convergence option and the autoconvergence then you might have other problems. and will have to troubleshoot further. If so ill talk you through some more. THIS set has NO stk convergence ics. my feeling is the fl231 which i see alot on this perticlar model at the shop
3answers
Rca 52inch hdtv
Please replace STK392-110 quantity 02 in your tv to fix convergence problem.
Above said part is available here.
Regards,
2answers
HD52W59 bowed picture
Check your screen. I have the same problem with mine. If the screen has a ripple in it, it could give the same effect.
2helpful
Images: three colors appears separates in the screen: red, green, blue
do they look like these:
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
