Question about Samsung LE26R72B 26 in. HD-Ready LCD Television
Up until today samsung freeview tv model LE26R74Bd working fine: this am, will not do anything except volume control, stuck on BBC2, have tried new batteries in remote, leaving off for an hour. Buttons on side of TV also not responding. Any ideas, is it to with the freeview retune. Can still get normal telly on the non digital setting!Help!
    President:
  • 1,653 Answers
PRESS THE DTV / TV BUTTON TO GET TO THE MENU.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Posted on Oct 03, 2009
On my Techwood it as built in freeview but every other channel is right except bbc1 and bbc2 both channels say bbc wales,How do i get them back to bbc1 and bbc2 please PLEASE HELP.THANK YOU.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
Jul 02, 2016 | Televison & Video
Volume intermittently increases all the way to 100 and cannot be controlled by the remote
This happens with some models. You can open the TV from the back and disconnect the connector for the side control board. You will only have control via the remote but your volume issue should be resolved.
Apr 12, 2014 | Samsung Televison & Video
Had my samsung dlp tv repaired today. tvs fine now but the remote does not work(still works on dvd player) direct tv remote does power on tv either or control volume anymore
It sounds that the remote control should be programmed once again with TV with its setup codes. Setup codes for Samsung TV are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Check these codes, and select one which have maximum functionality with your TV.
Jun 28, 2012 | Samsung TV Remote Control
Freeeview update has not allowed BBC1, BBC2 Channel 7 and 8 to be viwed. They have been deleted from the menu on digital. I can get BBC1 and BBC2 on analog.
Make sure all cables are securely connected to your Freeview Box or Freeview TV before you begin
Do a Factory Reset of your Freeview TV and then do a rescan of new channels. If successfull then all channels should be back and working.
Oct 14, 2009 | Panasonic TX-28DK2 TV
Started to retune our tv this afternoon and it gets stuck on channell 68 and won't switch off, except manually. What should I do?? The set top box is Netgem. Thanks
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
No digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Jun 03, 2009 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Ho to do it
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0060
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Apr 17, 2009 | GE JASRM24912 Remote Control
Goodmans GTV69RFDT Television had all freeview now only getting 3 channels
First ensure that the TV input is set on the Freeview channels, just in case.
Then check the antenna, when Freeview does not get all channels, it is always the aerial (antenna).
Many areas in UK have still poor reception. If you use an internal antenna, go to Argos or Currys and buy an amplified antenna for freeview, that will improve the signal.
Oct 15, 2008 | Goodmans W280NS Television
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Thomson 80gb freeview recorder box (Top up tv model) UK
have you connected the small cable at the back?
Jun 04, 2008 | Televison & Video
Samsung LE26R72B 26 in. HD-Ready LCD Television Logo
654 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
