Question about Philips 170S5FB 17" LCD Monitor
Philips 42 inch plasma screen stuck in standby
Philips 42 inch plasma screen appears to be stuck in standby. I have no remote control so how do I wake it up!?
It is an 42FD9925 screen with VGA inputs. I have tried swapping leads around, the pc it is plugged into is fine (using it now). It is plugged into the PC for sound also but the speakers are emitting no noise and the red light in the bottom corner is on solidly suggesting the screen is stuck in standby.
Any suggestions!!
  • 105 Answers
SOURCE: Philips Plasma Flashing Red
every plasma tv ive come across with this symptom eneded up beeing a new panel. what i do is replace the x and y sustain boards and if that dont work youll need a new panel.
Posted on Oct 14, 2007
  • 7 Answers
SOURCE: 42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Posted on Jun 07, 2008
Did this solution work as I have the same model and same problem and I have ordered the remote from philips suppliers
Posted on Jul 12, 2009
  • 315 Answers
SOURCE: 42fd9925/01 screen not turning on
does unplugging it for 5 mins and plugging it back in help?
i'd call philips support, might have to get it repaired.
Posted on Jul 14, 2009
SOURCE: 42" philips plasma, black screen and flashing red light
This fix was posted on similar problem, worthy of repeating: Replaced 3300mf 10V capacitors at PS. Both had bulged slightly. Upsized to 25V as the previous solution poster had suggested 16V but I could not locate 16V so used 25V and TV is back to normal!
Posted on Dec 08, 2009
What does it mean when your tv states standby and you cannot turn it on or off with the remote control?
How to Fix a Sony Plasma TV With a Standby Problem ... > Finances & Taxes > Other Finances & Taxes
A standby mode problem on your plasma TV can result in the TV being stuck instandby mode, ... You can troubleshoot a standby mode error by performing a power cycle or restoring the TV to its factory settings. ... Turn the television on. ... What Does It Mean When My Rumor Touch Says the Camera Is in Standby Mode?
tv on standby mode cant get it off - TV - Streaming Video & TVs
Dec 27, 2015 | Televison & Video
Trying to put on closed caption on gateway tv 42 inch-a large black screen appears
don't know if CC can be used when watching a DVD. seems to me that it would cause a conflict on the display where the dvd is sending the image which is really not part of the TVs input control options.
CC is usually related to the digital signal from signal broadcasts and not video images coming from an external source. if it was controlled i would think it would be from the dvd remote controller. not the tv.
Oct 14, 2012 | Gateway FMC-901 w/ 42-inch Plasma TV...
I have a 42 inch philips plasma tv with a broken screen, could i replace it with a screen from a panasonic 42 inch tv
No--this is called a PDP or plasma display panel and no two (even same brand) can be interchanged.
The cost of a Panel exceeds the cost of a new set--broken screen=fatal issue.
Mar 31, 2012 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Just bought a philips 42 inch ambilight plasma t.v,and didnt know the plastic screening round the out side is supposed to light up, how do i go about setting this up?
Bottom left button on your remote should turn the light on and off. if this doesn't work sort through the options on remote and select ambiant light functions
Mar 12, 2009 | Philips 42PF9630A 42 in. Plasma Television
42" phillips plasma
Hi There, Let's try to isolate the problem. Remove the battery from the remote control. With the battery removed from the remote control, let me know if the menu still appears. Thanks, Mike
Nov 04, 2008 | Philips 42PFL5603D 42 in. LCD HDTV
Wow that is a lot of money in any currency. Coming from England its not uncommon to be paying £200+ to repair a tv like yours. If you could give a little more information then maybe I could narrow it down for you. You say its gone black but does your standby light still come on? If you try to turn it on with the remote control does the stanby light flash quickly then re-appear? Or does it come out of standby and have a black screen? Can youm get sound through a dvd player but no picture? If you can answer these questions who knows maybe he will do it cheaper if you supply the part yourself!!! Dont think he will but worth a try :-) please post again.
Aug 25, 2008 | Philips 42PF9630A 42 in. Plasma Television
42 inch philips plasma HDTV vertical bar on screen
does the vertical lines appear like solid vertical bard infront of the pictire??
Jul 08, 2008 | Televison & Video
I have a phillips 5 unit controller with no code seach button what button do i press
If it did not come with codesearch button AND it was the original remote that cam ewith the V, just point the remote at the TV and press the power button for 10 seconds - it should program
I'm just going based on the information that you provided.
Philips has a 7-day-a-week helpline at 1-888-philips
Jun 14, 2008 | Philips Magnavox Learning Universal Remote
Philips 170S5FB 17" LCD Monitor Logo
55 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
