Question about Zebra Z4Mplus Label Printer
Zebra Z4MPlus not printing dark enough
I have a Zebra Z4MPlus. We changed to a different label & now its not printing dark enough on the label. How can I change the tension..if thats the problem? If I put a few of the old labels back in the printer, it prints correctly.
    Scholar:
  • 62 Answers
Problem is the temperature, printhead not hot enough. Download the zebra setup utility, you can use this utility to configure the print quality.
Heat setting can be found in the printer driver and easily adjusted there.
Posted on Nov 17, 2009
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Posted on Oct 06, 2009
  • 155 Answers
There are many types of printed materials and tapes different in each type of labes, you must adjust the dark and print speed for the type of label.
Roberto Martinez
My zebra z4mplus printer loads all the labels on the roll and when load the labels in the printer and turn the machine on. How can I make the printer stop loading after one label comes out?
I think your printer is set to print on Continuos media. If you use gap labels, you will need to set the printer from the menu on NOT CONTINUOS, then save the setting. In some cases the software or driver is the one who controls this setting. So you will need to change directly in the printer driver. You will find this option on the General tab (click Properties then) and Advanced tab (click on Printing Defaults). There you will have a list with printing parameters like speed, darkness, media type. Adjust as you need to fulfill your request. But first change directly to the printer, accessing the menu from control panel.
May 08, 2014 | Zebra Z4Mplus Label Printer
Calibration
I think your printer is set to print on Continuos media. If you use gap labels, you will need to set the printer from the menu on NOT CONTINUOS, then save the setting. In some cases the software or driver is the one who controls this setting. So you will need to change directly in the printer driver. You will find this option on the General tab (click Properties then) and Advanced tab (click on Printing Defaults). There you will have a list with printing parameters like speed, darkness, media type. Adjust as you need to fulfill your request. But first change directly to the printer, accessing the menu from control panel. Also verify if there is no label sticked on the media gap sensor.
Why does the label wrap around the bar every other label I print?
Try a different roll of labels. Clean with 100% alcahol
Apr 06, 2010 | Zebra Z4Mplus Label Printer
My Zebra Z4Mplus printer is skipping labels when I print
check the label margins, and label dimensions, and spacing , normaly is these problem, or is a printer driver problem, try reinstall driver
Jan 13, 2010 | Zebra Z4Mplus Label Printer
Password
The default password is 1234
Apr 21, 2009 | Zebra Z4Mplus Label Printer
Can't save the printer darkness in the printer
go to printer driver properties.. 1.click printing preferences set it to USE PRINTER CONFIGURATION 2.go to advance click Printing Defaults set it to USE PRINTER CONFIGURATION
you must set this two configuration note: fresh installed driver defaulth to software control
Oct 14, 2008 | Zebra Z4Mplus Label Printer
Change label size
Turn the power off. Remove old stock. Load new stock. Turn power on. Restart your program. Form size is software controlled from your form settings downloaded into the printer before your print. Make sure you restart your software to reload them.
Sep 03, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Aug 01, 2008 | Zebra Z4Mplus Label Printer
Zebra z4mplus
iN THE DRIVER CHECK THE head TEMPERATURE ISSUE. Most certainly you do not heat enough to do the transfer.
Else your ribbon is not mounted correctly. Zebra has an out inking transfer film
May 21, 2008 | Zebra Z4Mplus Label Printer
Zebra Z4Mplus Label Printer Logo
1,422 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
