Question about E-Machines eMachines Desktop PC
E-machine monitor will not boot up with computer. Starts in blue light and then changes to orange. Also get message no driver for PCI simple communications controller. Where can I get driver
  • 21 Answers
Check monitor data cable or system Ram
Posted on Sep 30, 2009
Will not cme on
Hi
Firstly - Is the cabling, mains and data cable, securely attached at both ends and the power turned on at the mains?
Secondly - If so when you press the monitor power button, does a light come on? (often orange coloured) If yes does this change colour when the computer starts its boot sequence? (often to green or blue)?
If no light can be obtained it is likely that the monitor is faulty.
If a light comes up on power up, but doesn't change colour during the computer boot sequence then it is more likely to be the graphics card that is faulty, or sometimes the computer PSU.
The easiest way to find out whether the computer or monitor is at fault is to replace the existing monitor with a monitor that is known to be in full working order, for example from another computer. (Or connecting your monitor to a computer that is known to be working)
Having isolated the faulty component it can be replaced and you should be up and running again.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 18, 2014 | GNR TS902D Monitor
When i turn it on it only appears only a second , my monitor turn black
Hello Chelleydiao, hi, its either you have a CPU problem or the monitor itself. Check or use another monitor to see if the problem is fix. you see an blank monitor can also be caused by the CPU if it fails to boot. the aid the checking, do you see any orange light on the monitor? or any indication.... the led light on the screen in summary: green or blue means there is power and the CPU boots up. if orange the CPU fails to boot, if there are no lights on the Monitor panels, there are problems on the monitor. check these first....I need a much detail description.
Dec 18, 2010 | AOC Monitor
W Thought it was the computer - so I chont power on. Would, for a while come up with no signal message, but now blue light barely flickers. Thought it was the computer so I changed computers, worked for...
A good rule of thumb to follow is: if the power button turns orange/red when it goes out, it's usually a problem with the monitor. If it stays blue or goes off, it's a problem with a driver or cable connection. Good luck!
Nov 24, 2010 | Proview PL713S 17" Flat Panel LCD Monitor
Computer powers up but monitor goes right to sleep?
when i power start my computer,,the light come on and seems to operate but the monitor doesn't come on,,,when switichin the monitor off and on , the blue light comes on and it reads monitor goin to sleep and the screen gets dark,,but the monitor orange light is on,,,pls help
Sep 21, 2009 | HP Pavilion MX70 17" CRT Monitor
Dell Inspiron 530 boots then the screens turn off to orange light
Is the PC actually doing to sleep or is the display just amber with the fan and power light on the PC still running?
Do you have multiple video cards or multiple ports?
You may have the monitor plugged into the non-default port on your video card or the wrong card. Try plugging the monitor into another port as the PC should use all outputs when booting but then define a default display once the driver is loaded. Also take a look at the default video display in your BIOS settings. Depending on what your setup is you should be able to choose between (onboard, PCI, AGP)
Jun 10, 2009 | Dell Inspiron 530s Desktop Computer...
Can't get Picture on Monitor, replaced video card
Boot up into the setup, usually F2- in the video section look to be able to make a change from Onboard to PCI ...apply-save change and exit ...also make sure you have connected the monitor to the correct area...I , like a big dummy, have often just hooked it up to the first blue socket i saw and of course...not much happens.
I hope this helps you Fred, (if it came with drivers install them)
please leave rating, thank you kindly
May 04, 2009 | HP Compaq Presario Media Center SR1750NX...
No display
you need to boot to safemode and reset your resolution it sounds like someone has set the resolution higher than the monitor can support, just press F8 right after the post screen goes away when you turn it on, then select safe mode, once in safe mode go to your display settings and set the res and color depth to a low settings ie. 800x600 or 1024x768 then reboot and it should work
Dec 06, 2008 | ATI RADEON X600 Pro, (128 MB) PCI Express...
Monitor problems
ok ,you may have two monitor drivers installed, or if it is wireless the driver may be faulty etc... a problem like this occur when you have two places on a monitor can be attached to your motherboard, direct or PCI, hat means look at the back of your comp. if there is a similar port that the one your using then when the monitor goes blank and just sits their, switch it over, and you should get an image. if its a driver problem, then safe mode will only work, and reinstall your PCI TO PCI or: your PCI BRIDGE drivers in the computer managment console. good luck. if all fails try using an older monitor or just a spare. cheers.
Sep 25, 2007 | Gateway FPD1760 17" LCD Monitor
E-Machines eMachines Desktop PC Logo
77 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
