Question about Nikon Fieldscope III 60mm
Need a new lens shield on the end of the scope
Need a new lens shield on the end of the ED82 lens. It had
fallen & was bent. Do you know where I can buy one? It
screws off the end of the lens real easy!
Thanks,
Steve Neitzel
sneitzel@centurytel.net
HOW DO I ADUST THE LENS ON BARNETT 4X32 SCOPE
4x32 mm Illuminated Crossbow Scope Owner's Manual - Crosman
https://support.crosman.com/hc/en-us/article_attachments/.../432RGMK-515.pdf
E. Windage (horizontal) Adjustment. F. Objective lens. 2. EYEPIECE FOCUSING. Without using your scope, look at a distant object for several seconds.
[PDF]4x32 Crossbow instructions - Mission Archery
missionarchery.com/wp-content/uploads/2014/07/4x32-Crossbow-instructions.pdf Keep the protective lens covers in place when the scope is not in use. ... This optimum adjustment may also require the rings to be moved along the scope rail.
Barnett Crossbow Scope Review - 4x32mm - HuntingOptics.net
huntingoptics.net/crossbow-scopes-reviews/barnett-crossbow-scope-review-4x32mm/ This is a bit above the curve for 32mm objective lens scopes, so I'd call the field of ... The Barnett 4×32 multi-reticle crossbow scope is very easy to sight in, once ... Thanks for reading my review of the Barnett 4x32 multi-reticle crossbow scope.
How to zero a crossbow scope (Tutorial) - YouTube
? 7:55
https://www.youtube.com/watch?v=Td-qESCt7Gw Nov 7, 2013 - Uploaded by Weaponsandstuff93
How to zero a crossbow compatible scope to shoot accurate groups with bolts. ... Some of them crossbows ...
Sighting in a Crossbow Scope - YouTube
? 3:03
https://www.youtube.com/watch?v=TnOIy1ZTe1U Aug 23, 2012 - Uploaded by Ghostkamo
Easy steps to sight in a Red Dot Scope. ... Just bought a Barnett Ghost 410 and needed to check how to ...
HOW DO I ADUST THE LENS ON BARNETT 4X32 SCOPE - Fixya
www.fixya.com/support/t26743320-adust_lens_barnett_4x32_scope 25 mins ago - If your rifle is taped for scope rings this is a easy thing to do, if you do not have any screw holes on top of the barrel you will have to have a smith ...
Sighting in my Barnett scope - HuntingNet.com Forums
www.huntingnet.com > HuntingNet.com Forums > Archery Forums > Crossbows Sep 1, 2009 - 10 posts - ‎7 authors
I have the Barnett 4x32 Multi Reticle scope and as per the instruction it tells me to set the top reticle line at 10 yards. So after about 10 shots I ...
barnett 4x32 scope Questions & Answers (with Pictures) - Fixya
www.fixya.com > Forum > Tags Get free help, tips & support from top experts on barnett 4x32 scope related issues. ... I have a chipped lens on the inside of the scope how do i get it fixed this will need to be sent to ... How do I adjust the reticle for a Simmons Mag 4X32 ...4X32 ... ADUST THE LENS ON BARNETT 4X32 SCOPE Google Search
Sep 18, 2017 | Optics
The needle and arm just slide all the way to the end of the record. What can I do? Thanks!!
The needle (stylus) has fallen off the end of the cantilever that contacts the record surface. U need a new stylus assembly.
OR, it is bent at an extreme angle and slides across the record surface.
Mar 10, 2015 | Audio Players & Recorders
My lenses have fallen out of the tube and now I do not know in which order to put them back in. Please help!
How interesting! Why did they fall out? I suggest you start by doing a web search for your model of spotting scope (since you haven't included that info so I can't search for it) and look for a technical drawing that shows the lenses and their order. But, even that might not solve your problem because some of the lenses may be slightly different from one face to the other, which difference may not be obvious from drawings. Thus, if a lens is inserted "backward" it could affect the focus and magnification. Ditto with lens spacers and threaded rings. Then there is the matter of re-assembly being accomplished without fingerprints, dust, weather sealing, etc. I hope you are successful.
Oct 06, 2010 | Optics
Hawke HK3102 internal ocular lens unseated
You probably can't fix it, and I don't know if it is worth fixing. There is a guy on ebay that fixes scopes, but like I said, this might not be worth fixing. you can buy a new one for what it will cost. So considering it a total loss, it won't hurt for you to try. You can take off the rear just by unscrewing it, and then the cross hair tube will come out, all different, but usually a cylinder screw driver, ( a tube with 2 notches on it, or a flat piece of steel the diameter of the inside tube. ) Take it out and see what happens next, going in from the front will release the seal, but it might already be broken. If you end up with a basket case, put it on ebay for parts. Hope this helps.
Jun 05, 2010 | Hawke Sport Optics Hawke® Endurance MAP 3...
Front glass fog from the inside.
First buy a dew shield, this will help prevent dew for some period of time. You may also need to buy a dew heater for the scope. Depends on where you live.
DO NOT leave the scope pointed up toward the sky for long periods of time.
Bring the scope outside at least 1 hour before you are going to use it. This lets the optics reach ambient temperature which will give you better views.
Here is a retailer that sells a dew shield and dew heaters: Bring the scope inside for a day or two and see if the dew "inside" the tube vanishes all by itself, before you decide to open it up. The corrector lens must be reinstalled in the EXACT position it was in before you removed it.
http://www.optcorp.com/
Apr 08, 2010 | Celestron NexStar 8i (600 x 203mm)...
I PURCHASED A NEW HAMMERS 3-9X42B RIFLESCOPE. THE RIFLE WAS DROPPED & THE SCOPE TUBE WAS BENT. DOES HAMMERS HAVE A PRODUCT WARRANTY FOR MY SCOPE? THANK YOU, MARK M., BENTON, LA.
Don't know about hammer's warranty, but why do you expect them to warrant something that you damaged/destroyed? Most warranties do not cover negligence.
Aug 26, 2009 | Optics
LXD75 AR6-AT
This is an old problem but I will answer it--
The rattling sound is a KNOWN ISSUE with these scopes. It actually does not affect anything. The scope is what is called an acromatic refractor. ALL ACROMATIC REFRACTORS show color fringing around bright objects. You would need to buy an APOCROMATIC refractor with 3 lenses to get true color correction. These scopes are very expensive to buy.
You can also use a "minus violet" filter to eliminate most of the color fringing in that scope. If the scope cannot be collimated it should be returned to Meade.
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Dec 18, 2007 | Meade LXD55 AR5EC Achromatic 5 in f9...
BROKEN SHIELD
Behind the protective shield are two plastic layersright next to each other if the front one is not broken and the quality of the picture is good considering the damage to that specific spot on the screen you should not have to replace it,only remove whats left of the broken shield.Be careful not to scratch that front lens.
Sep 21, 2006 | RCA P61960 61" Rear Projection Television
Nikon Fieldscope III 60mm Logo
Top Nikon Optics Experts
Mark Campeau
Level 1 Expert
Are you a Nikon Optic Expert? Answer questions, earn points and help others
