Sharp MX-3501N All-In-One Printer
Problem for Sharp MX-3501N All-In-One Printer
What does code: DK means?. How can I fix it?
By candie_ruiz on Sep 30, 2009
Solution #1
posted on Sep 30, 2009
Somewhat Helpful)
57 varieties
Rank: Guru  Computer Hardware  Expert
Rating: 88%, 529 votes
This code indicates that the Black Drum has reached 100k. It could also be the black developer and primary transfer belt are at 100k.
DC = Drum Cyan
DM = Drum Magenta
DY = D
rum Yellow
DK = Drum blacK
Even if it is reset you will still need the drum unit or drum/mc kit replaced very soon. These units do not last much longer than specified. After this the print quality deteriorates rapidly. Eventually the drum edges wear away so much that they can force developer out of the dev tank. You can usually get away with not replacing the K dev. If you reset the K dev at the same time as replacing the K drum unit, the machine adjusts itself can function normally. A dev normally lasts 200-300K. The primary belt unit lasts longer than the 100K spec and often beyond 200K out of them before replacement or refurbishment.
Finally, make sure that the Firmware is up to date.
Was this helpful?
Yes
No
Popular Solutions for Sharp MX-3501N All-In-One
Questions and Unsolved Problems for Sharp MX-3501N All-In-One
Do you recommend Sharp MX-3501N All-In-One Printer?
Answer
Answer
how to connect a sharp printer mx3501N to a network
Answer
I have a Sharp Mx3501 and the waste container needs to be changed. I was asked if I cant just empty... (More)
Answer
sharp mx-3501n will not power up! no indicator lights, fans do not start. no indication of power.
Answer
I am having problems printing large presentaion in PDF and PowerPoint
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp MX-3501N All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
