Question about Samsung LE32R74BDX 32 in. HD-Ready LCD Television
Samsung LE32R7 in DTV mode stays on BBC1
The screen displays only a band with "1 BBC ONE" . . and below a box with the word "Mono" Not possible to change channel The 'D menu' button on remote has no effect The 'Menu' shows the satellite dish icon as greyed out and not accessible
This has only happened today - 30 Sept - retune day - coincidence ??
    President:
  • 1,653 Answers
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again.
If the channel icon is greyed out and you cannot tune the channels press the TV/DTV button on the remote control unit so that the icon is visible again and not greyed out. This will allow you to tune the TV.
Posted on Oct 02, 2009
My samsung lcd tv stuck on bbc 1 on mono it wont go off screen
pl.see whether the other channels were locked inadvertently 2)if you have set top box remove the connection and connect the cable to antenna slot if you could change channels set top box is defective other wise tuner problem
Feb 18, 2015 | Samsung LN32A330 32 in. LCD TV
No sound on iplayer on tvonics z500hd
Workaround procedure to get this to work 1. Go to BBC1. 2. Go to the Guide and select channel 200 - BBC Red Button. Press OK. 3. Exit the Guide and wait. You should see a notice about the BBC Red Button Service. Wait a few seconds. 4. Press the RED button - the display switches to BBC1 and shows the standard (Text) Red Button Index. 5. Press the BLUE button to close the Index. The display shows the BBC1 video and sound. 6. Press the RED button to get into the Red Button Menu. 7. Wait a few seconds and then select the BBC iPlayer. I gained access to the iPlayer once this way yesterday and twice so far today but when I went straight to the iPlayer from BBC1 I lost the sound. I've just shutdown and then re-started the HD500 and successfully accessed the iPlayer using the above method. Note, that if it doesn't work then just switch your box into standby, wait 15 minutes or until the Hard Disk stops and then you can switch it on again. No mains power-off or reset is required.
Mar 29, 2013 | TVonics Televison & Video
How do i turn ON DTV MODE
First screw in the antenna or (ANT) into the RF on the back of the display. Open the menu and scroll down to Setup and select Plug&Play. Then Select and Okay through the launguage setup. Select 'Home Use'. Then Select Air and it will begin programming stations on DTV.
Brian
Sound Effects
330-273-4822
Feb 04, 2011 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Ldc tv with built in freeview wont tune to bbc 1 bbc 2, retuned 20 times still no bbc 1 bbc 2 . before i did retune i would receive bbc wales post code OL16 2RR North west
Buy a digital antena,or roof antena recieve better siginal,get everythings.Tries reset to factory setting retune again will get BBC1,BCC2 well get it back.
Dec 18, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do i set up the channels in order bbc 1 bbc2 etc to match the buttons on the remote 1 2 3 ect its a LG 42 INCH TV
selact menu on remot cantrol and see on the screen tunig menu in chenal edit to selact .
frist selact ch for edit and set your chennal no 1 /2 or 3......after the selact no prees OK key to fix your fureat ch. in your selacting no.
EXP:
ch . pisesion 36 [BBC1]
edit ch No 1
then prees OK key and see your BBC! is ch no 1 on your remot.
Oct 30, 2009 | LG 42LC2D 42 in. LCD HDTV
Icannot access dmenu on the remote. samsung le26r7
my samsung le32 tv is stuck on BBC 1 Mono. i cannot access the D menu or change on to any DTV channels. I am in an area that broadcasts in digital. the tv works ok if I connect a freeview box
Oct 01, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Missing Channels
I have found that for some reason bbc brodcasts are not transmitted in hd,either on sat or cable
Feb 17, 2008 | Sharp LC-26DA5 26 in. HDTV-Ready LCD...
Samsung LE32R74BDX 32 in. HD-Ready LCD Television Logo
1,045 people viewed this question
Jerry Greenberg
Jerry Greenberg
