Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
We had a power surge in our area a little while ago and our tv went. I took the cover off the rear and saw a 6.3 amp 125v fuse right inside where the cord went and ir was burnt. I replace it with the same size fuse and tried the tv it did not work? any help? Dan
  • 832 Answers
1.Check the power outlet where your TV is plugged.
Also your power panelboard for tripped off breaker.
2. If ever, your TV won't power on, then, it needs to
check your TV circuits. You can start at the power
supply IC for busted part., then to the other section,
(transceiver, audio, and video section)
Posted on Sep 30, 2009
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Tv will not power up when turned on after a power surge occurred.
Prayfully the fuse inside the tv took a little shock and broke ...if not that would leave the transformer or the board took a surge also but this would also depend on a little more details...
was the power surge damaged?
was tv plug damaged?
does the power surge still work (if it wasn't damage)
and not all power surges are power surges unless it specified of purchase most are like power surges but are only close to and a extended extention cord updated..
if the power surge is damaged or even still works then go have the fuse check and any further damage will also show up on the board it will have a burned part...
Nov 11, 2008 | Televison & Video
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
Fuse locations for RCA Scenium HD65W20
there are 2 fusable devices in this chasis dt307 they are f14200 and f14100 fl200 6 amp 125 v is located Power supply pcb. left rear chasis. f14100 3 amp 125v dm1 power supply pcb left rear. Does the unit have no flashing light... good luck on your troubleshooting and if you need any help contact me via email at the my shop at willie@fordtv.com
Mar 03, 2008 | RCA Scenium HD65W20 65" Rear Projection...
Replace the FU303 fuse
I have just been buying it at radio shack. However in my case it seems once the fuse blew for the 1st time, it happens now every few months -- so must be a symptom of a larger issue.
Dec 18, 2007 | Pioneer SD-643HD5 64" Rear Projection...
6.3a slow-blow 125v fuse
It will work, the amp rating is most important, 125v / 250v does
not matter.......note: if you blow the fuse again, the TV will
need service.................T.
Dec 08, 2007 | Panasonic CT-36SX12 36" TV
6.3 slow-blow fuse
Important parameter is 6.3 amp slow-blow,voltage rating = 125v
or 250v OK, No Worries.............................T,
Kp53v80
yes most likely it shorted out your hori transistor and you may have a bad FBT.flyback transformer.
Nov 17, 2007 | Sony KP-53V80 53" Rear Projection...
Power surge
its a problem in the power supply
Oct 23, 2007 | Samsung SlimFit TX-S2783 TV
T.v won't turn on at all
The 6.3 Amp 125V fuse always blows on this TV after a while. replace with a 6.3Amp 250V fuse and it should do the trick unless something else is wrong. a 6.3 amp 125V is almost impossible to find so chances are if you find a 6.3 it will work. Tried a 6 Amp 125v at first and it blows after the first time you turn it on and off and then back on again. 250V seems to work well. Hope this works for anyone else with this TV. Beats having to move it to the trash because it is HEAVY.
Feb 12, 2007 | Panasonic CT-32HXC43 32" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
67 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
