Question about Epson Office Equipment & Supplies
Replaced cartridge now printer not print
    Sergeant:
  • 310 Answers
Remove cartridge and check to see that you removed the protective cover. Replace and try again
Posted on Sep 30, 2009
Directions for inserting ink cartridges
Replacing the Ink Cartridges for Deskjet 6940 and 6980 ...
support.hp.com/us-en/document/c00569593
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
Replacing a Cartridge - HP Deskjet 2540 All-in-One Printer
www8.hp.com/.../printers.../replace-ink...toner/.../replac...
Hewlett?PackardLearn how to replace a cartridge in the HP Deskjet 2540 All-in-One printer.
Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ...
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
Jan 16, 2016 | HP Office Equipment & Supplies
How do I open the printer to get to the cartriges to be changed?
To replace a print cartridge: 1. Load a stack of plain white paper in the In tray. 2. Press the Power button to turn on the printer. 3. Open the printer cover. 4. Lift the print cartridge latch to the open position. 5. Slide the print cartridge out of the print cartridge cradle. 6. Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. 7. Hold the print cartridge so that the copper strip is on the bottom and facing toward the printer, then slide the print cartridge into the cradle. 8. Push down on the print cartridge latch until it snaps closed. 9. Close the top cover. The printer automatically prints a calibration page.
May 13, 2011 | HP DeskJet 5150 InkJet Printer
My hp d2360 is not working properly and i bought new cartridge but printer wasnt recognize the cartrige..
Please follow the steps below to install the Cartridge:
Install or replace the print cartridges
  1. Turn the printer on. The cartridge cradle will not move if the power is not on.
  2. Open the printer cover. Figure 1: Printer cover openc00658567.gif
  3. Wait until the print cartridge cradle moves to the center of the printer and is idle and quiet.
  4. If you are replacing a print cartridge, press down on the print cartridge to be replaced, and then slide it out of the print cartridge cradle. If you are installing print cartridges for the first time, go to the next step.
    NOTE: HP recommends using a print cartridge protector to store an opened print cartridge for later use. Figure 2: Print cartridge being inserted into a print cartridge protectorc00658568.gif
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 3: Removing the protective tapec00658569.gif
    CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts. Figure 4: Print cartridge facing upc00658570.gif 1 - Ink nozzles 2 - Copper contacts
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 5: Installing the print cartridgec00658571.gif
  7. Repeat steps 3-4 for the remaining print cartridge.
  8. Close the printer cover. The printer automatically prints a calibration page.
Mar 07, 2011 | HP Deskjet D2360 InkJet Printer
What is the replacement printer for HP Laser Jet
This document provides information about replacing the print cartridge for the HP LaserJet 1010 printer series, including life expectancy and replacement instructions. Print cartridge life expectancy The life of the print cartridge depends on the amount of toner that your print jobs require. When printing text on letter/A4-size paper at five percent coverage, the print cartridge lasts an average of 2,000 pages. This assumes that you set the print density to three and disable EconoMode. (These are the default settings.) See Ordering supplies for information on ordering replacement print cartridges. Changing the print cartridge Follow the below instructions to change the print cartridge:
  1. Open the print cartridge door, and remove the old print cartridge. See the recycling information inside the print cartridge box. Figure 1: Removing old print cartridge c00028312.gif CAUTION: To prevent damage, do not expose the print cartridge to light. Cover it with a piece of paper.
  2. Remove the new print cartridge from the packaging, and gently shake it from side to side to distribute the toner evenly inside the cartridge. Figure 2: Gently shaking new print cartridge c00028313.gif
  3. Pull the tab until all the tape is removed from the print cartridge. Put the tab in the print cartridge box to return for recycling. Figure 3: Removing tape from print cartridge c00035442.gif
  4. Insert the print cartridge in the printer, making sure that the print cartridge is in position. Close the print cartridge door. Figure 4: Inserting new print cartridge c00028315.gif
Apr 20, 2010 | HP LaserJet 1010 Printer
Teardrop light is flashing yellow. Green clock at left is lighted. Control panel says everything is ready but it won't print. There is no paoper jam.
This light that is showing the Print Cartridge Status. Here is what you can do:
If the light is on and not flashing: Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge. If neither print cartridge is low on ink, press the Resume button. If the Print Cartridge Status light remains on, turn off, then turn on the printer.
If the light is on and flashing: Verify that the correct print cartridges are installed.
Follow these steps:
1. Open the printer's top cover, remove the black or photo print cartridge, then close the cover.
2. Do one of the following:
  • If the light is flashing: Open the top cover, replace the print cartridge you removed, then remove the tri-color print cartridge. Go to step 3.
  • If the light is off: There is a problem with the print cartridge you removed. Go to step 3.
3. Manually clean the print cartridge.
After cleaning the print cartridge, reinsert it into the printer. If the print cartridge status light continues to flash, replace the print cartridge.if the light is on and not flashing. Check to see if a print cartridge is low on ink. If a print cartridge is low on ink, consider replacing the print cartridge.
Jan 07, 2010 | HP Hewlett Packard Deskjet 5650 InkJet...
Bogus message to replace print cartridge
To resolve the issue remove al the print cartridges and clean the print heads. Now insert all cartridges and try to align the printer. Click here for instructions to align the printer.
May 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
I need step by step instructions as far as how to change cartridges in hp deskjet 5440 printer
[This is from HP.com]
Introduction This document explains the basics of installing or replacing the print cartridges. It is for a 5940 which is the same printer design, yours may look a bit different but I copied this from HP at the section for your printer so follow the instructions and you should be okay.
Insert the print cartridges
NOTE: The printer shown below is the HP Deskjet 5940 series printer. Your printer might look slightly different.
  2. Open the printer cover. Figure 1: Open the cover c00393707.gif
  3. Wait until the print cartridge cradle moves to the right side of the printer and is idle and quiet.
  5. Remove the new print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strips are on the bottom and facing toward the printer. Figure 2: Remove tape c00393708.gif 1 - Protective tape CAUTION: Do not touch the print cartridge ink nozzles or copper contacts. Touching these parts will result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
  6. Slide the print cartridge at a slight upward angle into the cradle until the cartridge snaps into place. Figure 3: Install the print cartridge c00393709.gif
Original Page here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00411520&lc=en&dlc=en&cc=us&product=445441&os=228&rule=27868&lang=en
Regards,
Worldvet
Dec 01, 2008 | HP Deskjet 5440 InkJet Photo Printer
I haven't the manual for this printer color laserJet 2600n series,
HP Color LaserJet 2600n Printer - Installing Print Cartridges When a print cartridge approaches the end of useful life, the control panel displays a message recommending that to order a replacement. The printer can continue to print using the current print cartridge until the control panel displays a message instructing to replace the cartridge. The printer uses four colors and has a different print cartridge for each color: black (K), cyan (C), magenta (M), and yellow (Y). Replace a print cartridge when the printer control panel displays one of the following messages: Replace yellow cartridge, Replace magenta cartridge, Replace cyan cartridge, Replace black cartridge. The control panel display also indicates the color that should be replaced (unless a genuine HP cartridge is not currently installed). Change the print cartridge
  1. Turn off the printer.
  2. Open the front door. c00315320.gif CAUTION: Do not place anything on the transfer belt (ETB), which is located on the inside of the front door.
  4. Remove the new print cartridge from the bag. Place the used print cartridge in the bag for recycling. c00315322.gif
  5. Grasp both sides of the print cartridge by the blue handles and distribute the toner by gently rocking the print cartridge from front to back. CAUTION: Do not touch the shutter or the surface of the roller. c00315323.gif
  6. Remove the orange shipping locks and the orange shipping tape from the new print cartridge. Discard the shipping tape and shipping locks according to local regulations. c00315324.gif
  7. Align the print cartridge with the tracks inside the printer, and using the handles, insert the print cartridge until it is firmly seated. c00315325.gif
  9. Turn on the printer. After a short time, the control panel should display Ready.
    NOTE: If a cartridge is in the wrong slot or is the wrong type for the printer, the control panel will display one of the following messages: Incorrect yellow, Incorrect magenta, Incorrect cyan, Incorrect black.
  10. Installation is complete. Place the used print cartridge in the box in which the new cartridge arrived. See the enclosed recycling guide for recycling instructions.
  11. If a non-HP print cartridge is in the printer, check the printer control panel for further instructions.
    NOTE: When replacing or changing a black print cartridge, a cleaning page will automatically print. This helps prevent speckles on the front or back of printed documents. A cleaning page can also be generated using the control panel or the HP Toolbox.
Nov 03, 2008 | HP Color LaserJet 2600n Printer
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
