Question about Cell Phones
Blackberry how to fix my blackberry screen blurey
2007 60 inch vizio plasma hdtv model vm60p screen went half dark pitcher half blurey happend all at ounce im not sure what is wrong not very good with plasmas
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Aug 24, 2016 | Vizio P2 42 in. HD-Ready Plasma Television
I landed on my blackberry bold 9700 and half the screen is white and the other half can be seen. what do i do?
Your phone screen is broken,this can be fixed by changing the mobile screen (LCD screen).it can be buyed from blackberry showroom or from mobile shops.http://www.youtube.com/blackberry#p/p/54E0D34A19270D02/24/xMsE3t3ZprA.in this site you can make it clear all your doubts about your mobile phone.
Dec 04, 2010 | RIM BlackBerry Bold Smartphone
I have a blackberry storm and my screen is broken can it be fixed
Hi, yes it can be fixed, you have to go to service center and they will get replced it, please contact your service provider for more information, i hope this information will help you
Nov 25, 2009 | RIM BlackBerry Storm 9530 Smartphone
I`M NOT SURE WHAT HAPPEND ALL OD A SUDDEN SCREEN
Might be issue with VGA cable ,pls unplug it from the CPU and plug it properly.if still issue not resolved then pls degause the screen from menu option of monitor.if still issue not resolved the replace the VGA cable with goods one.
Nov 21, 2009 | HP Pavilion F1703 17" LCD Monitor
Blackberry bold white screen how you fix it
You need a replacement lcd screen it sounds like.
If you'd like to have us help you fix the screen send me an email at blackberryrepairshop@gmail.com and I'll be glad to help.
Oct 03, 2009 | RIM BlackBerry Bold Smartphone
What does app error 523 mean and and how can i fix it?
Hi your problem is solved
Error definition:
JVM 523:System process died
A critical Java process has terminated, and the device cannot continue to operate in a normal manner
Here is the resolution for your problem
Reload the BlackBerry Device Software on the BlackBerry device
Procedure
To use BlackBerry Application Loader to load BlackBerry Device Software, complete the following steps:
1.Install the BlackBerry Device Software on your computer.
2.Open BlackBerry Desktop Manager.
3.Connect the BlackBerry device to the computer.
4.If prompted, type your BlackBerry device password and click OK.
5.Complete one of the following steps:
If the Application Updates Available window appears, click Update Now. The Application Loader Wizard appears.
If the Application Updates Available window does not appear, double-click the Application Loader icon. The Application Loader Wizard appears.
6.Click Next.
7.If prompted, type your BlackBerry device password and click Next. Note: When the Application Loader Wizard is finished examining the configuration on the BlackBerry device, the Device Application Selection screen appears listing the applications available for installation. The selected check boxes indicate applications that are already installed on the BlackBerry device.
8.Select the check box for the BlackBerry Device Software.
9.Click Next.
10.If the On the Device Backup screen appears, choose whether to automatically back up the BlackBerry device and click Next.
11.Click Finish to begin loading the BlackBerry Device Software.
12.Click Close when the software is finished loading.
Good Luck and do let me know
Feb 28, 2009 | RIM BlackBerry 7100G Smartphone
Blackberry pearl 8100 won't turn on.
My Blackberry also wouldn't turn on, till a sharp tap at the top left of the screen made the screen flicker into life and I realised it was on, just no screen. After intermittent screen failing, repeated tapping seems to have fixed the problem. I'll upgrade to a new Blackberry when my contract allows.
Richard
Jan 24, 2009 | RIM BlackBerry Pearl 8100
RCA HD52W59 Projection Big Screen TV
you have cold solder conections if you know how to solder you can fix it with a good light
Oct 14, 2008 | Sony Grand WEGA KF60XBR800 60" Rear...
Cell Phones Logo
21 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
