Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Bizhub C350 Black smudges on prints
On both sides the back smudges, especially with bold fonts. The imaging unit has been replaced but still nothing. Is there something that needs cleaned that I have missed?
    Problem Solver:
  • 8 Answers
Sounds like you may have a bad fusing roller. Run some blank sheets. If the smudges start to fade, that's your trouble. When the fusing roller is bad it doesn't clean as well, so when you run bold text or anything that has higher than normal toner coverage, there will be more build up on the fusing roller that then transfers to the paper.
Posted on Oct 22, 2009
Hi i just bought a second hand konica minolta c350 and when i print something it is notting enough clarity. please anybody can help me .
I would first starts by removing the Imaging units that are locked with blue levers below toner cartridges one by one for each colour and use the cleaning tool that is provided on the door (metal rod with handle and a pad on the opposite). When you pull the Imaging unit all the way out, you will see inside a long strip of LED and next to it on left hand side about a 1-2 cm another strip of MICRO LED Array. This is essentially yor print head and it has to be spotless clean. Use the rod and padded end to clean each of the arrays. This will give better sharpness and clarity to your prints. Then put Imaging Unit back in machine and pull the blue stick from the Imaging Unit out-in-out-in. The next step is to do Stabilisation and Gradation adjustments. This can be done in Service Mode. This should improve your printing. If it doesn't then you have either worn Imaging units _or_ Transfer Belt _or_ incorrect settings on Fuser or Fuser being worn.
Sep 29, 2016 | Konica Minolta Bizhub C350 Digital Copier,...
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
Black smudges & missing lines
replace the black image unit and the fuser
Apr 07, 2014 | Konica Minolta - Magicolor 1600 1600w...
I have a trouble code C-3727 showing on my photocopier konica minolta bizhub C353. What does that mean?
C-0F36 on the bizhub C350 means the machine has registered a really low toner density in the Black
Imaging Unit. I'd take the unit out, give it a shake and pop it back in. Also worth checking you have some Black Toner in it.Or in case You Still Having Konica Printer Problem Then Follow Us For On: Konica Printer Support
Oct 06, 2013 | Konica Minolta Konica Bizhub C353 Drum...
My bizhub c250 is printing smudged copies. It seems to have print a lite image from a previous copy. Im left with a streak along the top of what Im trying to print out. Any suggestions? The smudge is...
Hi Mike13660,
Usually the fault you are describing is caused by the fuser section being left in envelope mode.
Open the right hand side door, then lift the grey fuser cover up. Look at the levers on the fuser unit, make sure they aren't pointing at the envelope symbol. If they are, push them upwards. then close everything and try again.
Regards
M-PRESS.BIZ
Feb 09, 2011 | Konica Minolta bizhub C250 All-In-One...
Konica minolta Bizhub C350. Following message appeared on my printer: Malfunction detected. Please call your Technical Representative and provide code: C-0F36 What does this code mean?
Hi katienash,
Good luck
Regards
m-press.biz
Jan 25, 2011 | Konica Minolta Minolta Printer stand...
Cof32, blank copy on printing and copying bizhub c350
Have you open closed the front door to clear code? have you replaced the black image unit? Not the black toner but the image unit Black.
Apr 22, 2010 | Konica Minolta Office Equipment & Supplies
Unable to print in colour using GIMP
if i am correct the bizhub 350 is for black and white only and not colored, unless you use a bizhub c350
Apr 20, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
604 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
