Question about Sport & Outdoor - Others
Spinscrub what do I do to get my spinscrub to take up water
    President:
  • 3,085 Answers
On this model the hose get a hole worn in it from raising and lowering the handle causing it to lose suction.
Order from a Hoover dealer.
Posted on Sep 30, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
My SteamVac SpinScrub works fine then all of a sudden, the noise level of the vac seems higher and does not **** up water. I turn off vac then turn it back on, works good for awhile, then noisy, higher...
It sounds as if the ball in the tank in shutting down the suction prematurely. Be sure there is a gap of about 3/4 inch between the top of the filter inside the tank, and the lid of the dirty water tank. Without this gap, suction will pull the ball up too soon.
Apr 04, 2011 | Hoover SteamVac F5914-900 SpinScrub...
HOOVER FLOORMATE SPINSCRUB WILL NOT PICK UP WATER
First make sure that you are getting suction from the bottom of the machine. Most of the time the squeegee is worn out which does not allow it to pick up the water like it use to. Turn over the machine and inspect the squeegee. If it looks worn or bent then it may be time to replace it. You may also consider replacing the filter. These are the two most common parts that wear out.
here is a link the parts for your a h3030 floormate
Hoover H3030 Parts Link
http://www.usavacuum.com/category-s/86.htm
Jan 16, 2010 | Hoover H3030 FloorMate SpinScrub 500...
Will not pick up water. vacuums well
H3030 Link
Oct 23, 2009 | Hoover H3030 FloorMate SpinScrub 500...
SteamVac F5914-900 SpinScrub won't stay upright or collect water
(1) Upright: Sounds like the tab on the lower handle that the handel release latches to has broken off. The machine is fully functional without it otherwise.
(2) Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Sep 18, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I have a hoover spinscrub 800. It washes great
in some cases when this happenes it's usually from a really bad filter or the squeege at the bottom of the nozzle. the squeege is what makes contact with the floor and suctions all of the water up. to take off. take off the nozzle and there will be (3) screws inside of the nozzle. once these screw are removed, the squeege can be removed. at hoover.com the replacement part # is 93001094. ( according to model # H3060 )
Jul 31, 2009 | Hoover H3060 FloorMate SpinScrub 800...
Hoover SpinScrub
I would almost guarantee the recovery tank is not seated properly. Trust me, I reseated the tank 5-10 times before giving up. I finally decided to give it one more try before forking out the money for another cleaner. I removed the clean water tank, turned the machine on (you could feel the air blowing out the sides on the bottom). With the machine still running, I unclipped the recovery tank and lifted it up (yes, you can do this, and it creates a very loud air thrust, but don't be scared), then I SLAMMED it back down into the seat and immediately I could tell the difference. The air stopped blowing from underneath and I could tell I had suction once again. I turned it off, put the clean water tank back on, and it worked like a charm. Trust me, you may be convinced that the recovery tank is seated properly.....LOL.....it ain't! Hope this helps!
Mar 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover spinscrub water keeps coming our
Check the machine where the water tank is installed, you will see a pipe stem this stem should have an o-ring gasket on it. also look at the plunger in the tank for proper seating.
Jan 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
