Question about Kyocera Switchback KX21 Cellular Phone
Kyocera strobe keys 7,8,9
On front panel, I press 7,8 or 9 and they do not work. Is there a way to remove the front panel to repair this? Any suggestions would be appreciated. Thank you
  • Nette 23 Jan 04, 2008
    My Strobe keys 7,8,9 as well as the scroll button were not working either. Apparently it is the little button that gets pushed when the phone is closed. Very iffy to fix. But if I push that button just right all the buttons on the front of the phone work. I have taken the phone apart, replaced the button, replaced the keys nothing works it is almost as if the circut goes a bit haywire, and decides not to work unless forced. Or the rubber button doesn't seat well enough to push the circut properly.
BOTH LCD'S ARE BLUE..i need to know what happens
Posted on Jan 04, 2008
I would take it to your provider if it is under warranty. Very iffy to try to fix keys.
Posted on Dec 22, 2007
Kyocera c6745 hard reset
1. Back up all your data.(or not)
2. Turn off the phone.
3. Press and hold the "Volume Down" and "Power key" at the same time.
4. When the phone vibrates, release the "Power key" ONLY.
5. When the Android recovery screen appears, release the "Volume down key".
6. Press the "Volume down key" until "wipe data/factory reset" is selected, then press the "Power key".
7. Press the "Volume down key" until "Yes - erase all user data" is selected, then press the "Power key".
8. Press the "Volume down key" until "reboot system" now is selected, then press the "Power key".
9. They phone should now shut off and restart.
Dec 12, 2017 | Kyocera Cell Phones
Hello! I work in an office and we use the Kyocera KM2050 and are trying to figure out how to have a confirmation page print after a fax is sent just so we know it was delivered successfully. Thank you!
1 Press the System Menu key.
2 Press the down arrow key to select Fax Default.
3 Press the Enter key.
4 Press the arrow down key to select Print Report.
5 Press the Enter key.
6 Press the arrow down key to select TX Transaction.
7 Press the Enter key.
8 Press the arrow down key to select when you want the report to print out.
The asterisk (*) in the message display indicates the current setting.
9 Press the Enter key. The setting for that report is complete.
> If you want to continue the setting procedure for other reports, repeat steps 6 - 9.
> If you want to perform other setting procedures, select End and then press the Enter key.
> If you are finished making settings, press the Reset key. The operation panel will return to the
initial mode settings.
This information can be found on page 7-2 of the Fax System Operation Guide which can be down loaded from Kyocera's website.
Jan 06, 2011 | Kyocera Mita KM-2050 Printer
I have a kyocera strobe but i cant find the spot for my s.d card
you have to remove the battery and check where the sim enters from, its underneath the sim slot.
check and give a feedback to know if it is there.
all the best.
Jan 31, 2010 | Kyocera Strobe K612B Cellular Phone
Something is wrong with the display on my Kyocera Strobe K612B. When I open and close the phone sometimes nothing happens but sometimes one of the screens gets distorted. The outside screen is usally the...
This EXACT same problem happened to me and I had to pay $50 to some cell-phone repair guy to replace the whole front piece of the phone....I HATE Kyocera and will NEVER buy ANYTHING from them ever again!
Aug 15, 2009 | Kyocera Strobe K612B Cellular Phone
Screen is blank went blank and all buttons still work
Jun 22, 2009 | Kyocera Strobe K612B Cellular Phone
Brother mfc 420cn, machine error 46
Your waste ink absorber box has reached its limit. You have to replace the box (which is cheap, get one from your local brother service centre).
After replacing it you have to reset the purge counter and flushing counter.
This is not easy to do and I don't recommend it for anyone who is not technically inclined. You have to remove the front control panel, open the covers on the top cover assembly under the scanner. Unplug all the cables. Disconnect the ground wire (if any), remove the prop, remove the scanner assy by opening 90 degrees and sliding rearward. Put scanner aside. Remove four screws holding top case on, pry out the bosses at the front and remove the top cover.
At the rear you will see the flushing box or waste ink box. Lift it up a little. You should see two tubes attached. Remove the tubes and pull the box out. Dispose of old box. Attach the tubes to the new box and install it where the old one was. Reassemble in reverse order. Don't forget to plug in all the cables under the control panel.
Plug the unit in while holding down the Menu button. Keep holding until all the lights are flashing. Welcome to maintenance mode.
Press 8 and then 0. Press the Black Start key several times until you see Purge or Purge Count on the display. Now press 2, 7, 8, 3 to clear the count. Press Stop. Press 8, 0 again and the Black Start key several times until you see Flush or Flushing count. Again press 2, 7, 8, 3 to reset the flush count. Press Stop. Press 9 and 9 to exit maintenance mode. Job done.
Jan 19, 2009 | Brother MFC 420CN All-In-One InkJet...
Please
sorry to tell you sweety but that is the end of your phone. I first purchased a Kyocera Strobe, I had only had it for a month when it did the very same thing. I took it back to the metro store and all they could do for me was reimburse me for half of the money i spent on downloads. They replaced the phone with a another one and by the grace of god I've have this one for a year. It is on its last limb cause I have to open it up to dial 7, 8, and 9. Sorry that it happened but you will not be able to retrieve your info. That's why now I have an address book (paper) and I send all of my pictures that I take to my email cause I will not deal with that problem ever again.
Mar 09, 2008 | Kyocera Switchback KX21 Cellular Phone
Kyocera strobe
yes someone please answer where is the sim card?? i need it
Oct 30, 2007 | Kyocera Switchback KX21 Cellular Phone
Kyocera Switchback KX21 Cellular Phone Logo
57 people viewed this question
Top Kyocera Cell Phones Experts
Lawrence Oravetz
Paul Bade
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
