Question about Canon PIXMA MP830 All-In-One InkJet Printer
Hello, My Canon MP830 suddenly shut off when I told it to print a sheet. It will not turn on, and the print head is stuck to the right, and I can't move it. I left it unplugged for several days, but still it will not power up. Thanks!
    President:
  • 2,306 Answers
When the carriage is stuck on the right there's not much you can do, When the printhead goes bad it keeps your printer from powering up. You need to either remove the printhead, or unplug the light color ribbon cables from the circuit board on the right side of the machine inorder to power up, and then change the printhead. QY6-0061-000 around $60.00
Posted on Sep 30, 2009
The black only prints every other line. I've cleaned the print heads and aligned them. What's wrong.
Hi you are right its the print head only 1/2 of the black jets are working
keep cleaning but if that is not working look in your user book and you will see its very simple to replace the print head but not cheep.
if to go to www.amazon.co.uk and search Canon PIXMA MP830 print head you will see they have stock at £59.99
if this was useful please rate me
Ian
Mar 08, 2011 | Canon PIXMA MP830 All-In-One InkJet...
I'm getting the error message "The type printer head is incorrect" "Install the correct Print Head" I called Canon help yesterday. Took out the print head, turned off the machine, installed...
sounds like the print head contacts are getting loose or are dirty, try cleaning the contact pads, re-seat the unit and try again, to do this gently rub the contacts with a white eraser works good for this job. if this helps you, please provide some thumbs up. cheers.
Aug 26, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Jul 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Returning an error 5200 on my canon MP830 printer
Hi
I have an MP830 on my desk I use all the time. Whenever I use generic cartridges I get the 5200 error and the A600 error. This seems to be caused because the generic cartridges ooze a little ink. The ink falls down into the excess ink pad (as it should) but it also provides a minute amount of resistance when the print head first starts to move which generates the errors. What I do once a week is take out all the print cartridges and clean off their bases. Then I take out the print cartridge holder and clean that. Then I move the print mechanism to the left side. I take a folder piece of paper towel that I put a little glass cleaner on and I run that over the excess print well on the right side of the print head travel or where the print head normally sits. Of course I do this with the printer off. So far it's worked every time. When I first bought the printer and I got the error message I called Canon and this is what they told me also. Since I've been troubleshooting electronics for 40 years I wasn't pleased with that response so I began some troubleshooting on my own. his is what I came up with. I hope this helps. Good luck
Mar 07, 2010 | Canon MP830 All-In-One Printer
Have canon mp830, suddenly will not print yellow, cleaned print head, did allignment. do i need to replace print head?
The ink color cartridge is near empty or defective.
You need to get a new and HP genuine one.
Thank you
TechSaver
Jan 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Suddenly stopped scanning and now won't copy or print b/c keeps saying it's still scanning. Canon mp830. Scanning Wizard starts but just dies in the middle. Any button I'm not hitting or solution you can...
Any lightning strikes locally?
You can try to reset back to factory by removing cartridges and head.Power off unit ,then unplug for 45 minutes.repower and install all.
Do a nozzle check and see what happens.
Aug 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
6A00 code with Alarm light
6a00 is a purge unit fault, It could be there is a bit of paper or something stuck in the purge, causing it not to move back and forward causing your fault.
be best to contact some one to repair the product.
Oct 18, 2008 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp830
Error code 5200 means the print head temperature is too high. The only was to resolve this error is either replace the print head or replace the logic board. The print head is available, part number QY6-0061 but you will struggle to find a logic board. The only other thing you can try is resetting the EEPROM on the logic board, this sometimes clears the error. A service manual will show you how to do this: http://www.tradebit.com/filedetail.php/4546483-canon-pixma-mp830-printer-service-manual
Jun 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
314 people viewed this question
old marine
old marine
