Question about Sport & Outdoor - Others
Spear pump wont work
Hear pump working but brings up no water
    Problem Solver:
  • 20 Answers
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
aaa9
Posted on Oct 10, 2009
We have the Penguin 630515 with the heat pump ..we get a strong musty odor when we use the heat pump or the AC... we have sprayed Lysol into all the duct work and still have it. We have had the roof...
There is a condensate tray under the coil. There should also be a drain hose or port that could be clogged. Take off top of AC unit and pour a 10% solution of bleach and water over coil, follow flow of water to drain and make sure it is working. Pour a very small amount first otherwise you will have water everywhere.
Jan 23, 2011 | Dometic Rooftop RV Air Conditioner
Water is dripping rapidly from my VCMA 15ULS. Do I need to replace it? Or can it be fixed?
I assume the unit is overflowing, because the pump is not running. Check th hose connection and be sure the line bringing the water into the pump is inserted in the opening. Can you hear the motor run? You can remove the top, and be sure the float switch is working and that the pump inlet is not clogged with debris. Sometimes you'll get mold and dirt mixed with water clogging the inlet. If the motor doesn't run, and the switch works, then it probably isn't worth fixing as you can buy these from 35.00--50.00
Jul 04, 2010 | Little Giant VCMA-15ULST, 1/50 HP, 65 GPH...
I have a GE washer that won't drain!
The pump is clogged. Remove the tub to pump hose and you will find debris in it not letting the pump work. Do this and you will be good to go. Thanks, Rick
Mar 04, 2010 | Washing Machines
My spear pump does not work Has not been used for about 5 months Does it require cleaning ? If so how can I do this ? Do not know how they work . Can you tell me what i can do to fix it .? I do not know...
have a go mate it sounds as if the pmpellars are blocked or ristricting the flow are y getting any noise from the motor at all more imfo please
Oct 08, 2009 | Plumbing
I have a 2008 kfx 450r and the cooling fan will not come on and the bike over heats. I checked the fan and it works. Where do I check next?
mine had the same problem,,, just pop out the hood,,and you will find two orange boxes,,,one is for the cooling fan i dont remember wich one is,,,and inside the box ,you will find,two fuses (one is the spear)and just replace ,,the blow fuse for the spear one,,,,,(sorry bad english) ,,,
Jun 20, 2009 | 2006 kawasaki KX 450 F
Water wont spin out but hear buzzing sound
The water pump is spinning but not pumping it out change the water pump.
May 12, 2009 | Washing Machines
Hotpoint wma12 not draining help please my work clothes are stuck
You need to check the pump filter which is accessed by removing lower rear panel of washer.
On the right you will see a large black hose, ondo securing clip and remove hose, be careful because there will still be water in it.
Better still , lay hose down into a bowl or similar to drain any remaining water in m/c.
Inside you will see the plastic filter, remove and clean, refit filter and hose, make sure you get it on properly
Test it for leaks, and that should be it.
If it still does not drain then you need to check the pump is o/k.
You can do this by listening or feeling if you can hear the pump going.
BE CAREFUL
Any more info , let me know.
Plz rate my solution.
Thanks.
Jan 04, 2009 | Hotpoint First Edition FEW12 Front Load...
Cant install rainbow six
what si your operating system? rogue spear works on all windows based OS's except for vista. if you have vista, search the internet for a rogue spear vista patch
Nov 26, 2008 | Red Storm Enertainment Rogue Spear Black...
Water notcoming out of spray arms
water circulating pump is not working or spray arms blocked.listen and determine if you can hear motor running
Jun 25, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Sport & Outdoor - Others Logo
55 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
