Question about SI-TEX MAX10 NT GPS Receiver
MAX10 NT Chartplotter blank screen
Last season I was adjusting the contrast on this unit and all of a sudden the screen went blank. I was not able to shut the unit off through the normal shut off method and had to switch it off at the control panel. The unit will turn on, but will only show a blank screen and it will shut down a vast majority of the time by having to switch it off at the control panel. I have tried interchanging the CMap cartridges in the two slots and this does not have any effect. Any suggestions?
Thanks.
sailar@aol.com
How do i fix the screen on my pfaff 2140 creative sewing machine?
Unfortunately it probably needs a new logic board.
Not cheap.
Feb 26, 2015 | PfaFF Sewing Machines
TI-83 have adjusted the brightness but can't type or see flashing indicator
If the screen is not busted, adjust the contrast without going all the way to totally dark or to totally blank. Calculators do occasionally become unusable (old age, mishandling).
Mar 01, 2014 | Texas Instruments TI-83 Plus Calculator
Furuno 1650wf keeps losing gps fix . some time it will have a fix for awile , then it may only last a few seconds
Check your cable. Sometimes the cable connector goes bad and other times it's the connector on the inside of the unit. Get a dealer to check this one out. Try sending it to Mid-Shore Electronics in Maryland if you're in the U.S.
Dec 08, 2009 | Furuno 1650wf/Nt...
While using my gps 12, the screen suddenly went dark with just a narrow border of lit screen. batteries good. I can faintly see the pages behind the dark screen.
it turns out I inadvertently adjusted the screen contrast. This is adjusted by holding the left arrow key down after powering up, until the contrast is corrected. If the screen was completely white, holding the right arrow key down after powering up would bring contrast back into balance.
Nov 28, 2009 | Garmin GPS 12 GPS Receiver
How can I connect my chartplotter to my flatscreen tv
absolutely not! sorry that is the answer, no video out available period
Dec 19, 2008 | Furuno 1650wf/Nt...
Hitachi screen went blank?
1) Consult service manual for details.........procedure issues?
Sounds like the digital convergence unit got confused....
You may have to start all over again at default....
2) When converging a PTV, less is better ( adjustments) unless
you are positive adjustments will yield some improvement..
3) Info source = www.HitachiServiceUSA.com
Please rate this solution.............................
Nov 03, 2007 | Hitachi 43FDX01B TV
SI-TEX MAX 10 NT
Yes, they are. Call SITEX 727-576-5995 x139
Oct 05, 2007 | SI-TEX MAX10 NT GPS Receiver
Nokia 6600
maybe the lcd connector was off.takoff the front cover and screws and try to conect it again
Sep 06, 2007 | Nokia 6600
SI-TEX MAX10 NT GPS Receiver Logo
42 people viewed this question
Top SI-TEX GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a SI-TEX GPS Expert? Answer questions, earn points and help others
