Question about Sport & Outdoor - Others
Engine will not run when clutch is release.
1982 V45 Sabre when i try to crack the throttle and let the clutch out the engine dies. I need help! Can it be a vacuum line or my petcock vacuum rubber?
    Sergeant:
  • 173 Answers
HI suspect a sticky "slider" piston, or damaged diaphragm, the vacuum chamber covers (chrome caps at the top of the carburetors) can also be removed without removing the carburetors from the bike to check them.http://users.metro2000.net/~cdc/magna/tech%20section%20and%20issues/carburetors/carburetor%20page.htm
Posted on Sep 30, 2009
I have no carb. aair filters in my 1982 V45 does that make it burn oil? I get black smoke when cold right side
Hi, James running without air filters is extremely bad for your engine not only does it allow harmful contamination like dirt, water, boulders and small critters into your engine it upsets the delicate air/fuel ratio balance your engine needs to perform to its full potential without sacrificing longevity for openers it will cause your engine to run on the lean side which is an open door invitation to its worst enemy "HEAT" whose only job is to prematurely wear out your engine parts, piston rings and valves are its favorite meal. Black smoke is usually a rich fuel condition that can be caused by faulty spark plugs and or ignition components, a faulty choke qualifies as a usual suspect, it's the white smoke that is the telltale sign of engine oil burning, do yourself and your engine a favor and have a leak down test performed it's a relatively cheap procedure and will allow your engine to tell you if it needs surgery or just TLC and put some air filters back on I recommend K&N. For more information about your question and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
http://www.magnaownersoftexas.com/tips.htm
https://drive.google.com/file/d/0B6uU39dq308cNTUzODE4NmYtMDIxNy00MzAwLWFkZDUtNDNkMWUxYTVmYWQx/view?hl=en&pref=2&pli=1
1994 2003 Honda Magna VF750C V45 Service Manual Moto Data Project
Honda VF 750 Super Magna V45 1988
Mar 13, 2016 | Motorcycles
1982 v45 sabre front end wobbles when I'm turning
Struts maybe bad or one of you axles is bad.
Check also the inside of your tires.
Sep 11, 2015 | Cars & Trucks
Why does engine die
The clutch is not totally disingauging.
Jul 28, 2014 | Polaris 2009 Sportsman 850 EFI XP With EPS
82 honda v45 magna ignition problems
Hi, Anonymous before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
86 Magna will not turn over
http://www.fireblades.org/forums/general-discussion/87115-honda-vf700-magna-wont-turn-over.html
Honda 45 SABRE VF750S 1982 Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1995 VF750C Magna Owner Manual
May 06, 2017 | 1982 Honda VF 750 S
My 1982 Honda v45 will not run without the choke on. It sat in the garage for years with old fuel in the tank. We drained the fuel, changed all the oils, etc and completely REBUILT all 4 carburetors. I...
The slow jets and adjoining passageways are still dirty. As painful as it may be , take the carbs off and clean the slow circuit again or it will never idle. Double check the fuel pump is working properly and the fuel filter is not plugged. One time it took me four cleanings to get all four carbs working on a Suzuki that sat for five years. Also make sure none of the carburetor boots have developed rips from age.
Aug 31, 2010 | 1982 Honda VF 750 S
Hi,I have a 1982 V45 sabre,the problem is the stator plug is getting really hot.checked the charging and it's between 13.2-13.9.is it normal for this plug to get hot?
Yes some heat is normal, not so hot that it melts. Your voltage from stator is AC not DC,the voltage you read was after voltage regulator.To check the stator output unhook the wires from stator,run engine at 1,500 rpms as you read Volts AC on your meter,read from one stator wire to the other (do not use black to ground) untill you have tested all the combinations,write down the different set of numbers.You should read around 45 or 50 volts AC on each set. The high temp on the wire is more likely the result of wire connections needing to be cleaned and treated with dielectric grease to keep out moisture and deture corrosion.With good clean contact the wire will have less resistance and be cooler.The hot spot is usualy the weakest. OK well hope you get it done soon,Ride safe!
Apr 08, 2010 | 1982 Honda VF 750 S
I have a 1982 honda v45 sabre VF750S. I need the vaccum diagram for the carbs.I don't know how my carburetors are set up.I'm not sure about the vaccum line routing. Thank You,Bronx James
A service manual is a valuable tool with an aging bike. I suggest the dealer/mfr. or Clymer books. In the meantime, go to the library reference section...646 stacks should have what you need.
Sep 26, 2009 | 1982 Honda VF 750 S
I have a 82 v45 magna that has the same problem with the clutch aswell,it has no pressure we tried to bleed it and did it the correct way but now i have nothing in the clutch?
Either has a bad clutch master cylinder, or a bad slave cylinder. If you can line lock the clutch, does it have good pressure? If not, you need a clutch master, if so, it is slave cylinder, or a bad clutch.
Aug 03, 2009 | 1982 Honda VF 750 S
Sport & Outdoor - Others Logo
102 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
