Question about Sport & Outdoor - Others
Where do you hyd oil
Takehui excavator tb145
  • 3,600 Answers
You can get t at Wal mart if your in the U.S. or any shop that carries oil. or any tractor dealer will carry it but may a bit more expensive.
Posted on Sep 30, 2009
What tipe of oil And how many gals. of oil To service a bobcat 335
6 qts engine oil . 8 qts. 80-90 front diff. 12 gallons hydraulic oil John deere hyguard trans/hyd or Traveller trans/hyd oil at tractor supply
Dec 31, 2016 | Bobcat Garden
4496 CASE TRACTOR .Ran out of hydraulic oil , filled up and bleed lines , still have no steering and the brake is out ,.What valve is locked in ?
by bleeding lines where exactly did u do this ? , the place id try 1st is right off the pump to the dist block (carefully!!!) if no pressure there then a more aggressive repurdge of hyd sys is needed using another machines hyd system connected to remotes inputs off the dist block
reason 4 this is that hyd oil pumps don't just pick up oil again when run dry an have to be helped to pressure up again , Also another possible cause is that pressure relief is stuck open , this doesn't allow any pressure to build up
Nov 13, 2015 | Cars & Trucks
My mini excavator 334 lost hyds to boom and tracks. blade still goes up and down .the red ! light is on
could be a bad solenoid find out which on works that solenoid , make sure you are getting power to it could also be fused ck that first , cannot be to much to fix ,get a manual of it to ck the solenoid position
Nov 25, 2014 | Mini Cars & Trucks
EX58Mu hitachi Excavator will not lift main boom arm all other hyd actions work well
Is it leaking any fluid. Spool valve may have a blown seal.
Jan 29, 2013 | Garden
Leaking hydraulic oil around the turntable
The seal units at the turn table are worn or there are grooves worn around the sealing ring.. It is common for this area that is subject to such movement in the worst possible conditions of dust and other contaminents
Jan 16, 2013 | Caterpillar E70B Excavator
I just put oil on my cherrypickers manual hyd ad dosent pump what can i do?
sounds like it has a gut full of air which can be compressed whereas hyd oil cannot and is not circulating. must be some way of bleeding system
Dec 10, 2012 | Cars & Trucks
Where do you put hydrallic oil in a mtd white lawn tractor ,
First thing hyd. oil should not and can't come out the oil filter. May a hyd. filter. I'll try to find something. Most tranmission are sealed.
May 06, 2012 | Garden
My Ex200-2 excavator is slow in all functions and appears to have not power.
Hello
My friend has a ex75 ur that had the same problems after some vines caught the limit switches on the digging boom. I spent hours trying to figure out what switch or combination of switches was causing the slow boom with no power. I found a bank of 4 solenoids that control the hyd. flow, after jumping them with a switched hot wire- problem solved!
Jun 20, 2009 | Garden
Hyd controls get hard after machine has run ten
You got a pressure crossover problem there , main pump pressure is leaking into the servo system I would suspect the pump.
Apr 10, 2009 | Garden
Sport & Outdoor - Others Logo
37 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
