Tub is loose in front loading machine.
On my Kenmore front loading washing machine, the tub is loose. Do you know how much it will cost to replace it.
    Genius:
  • 1,036 Answers
If it is the main drum which is now sagging - rattly and loose - check rear screws are tight. If they are, then you probably need a rear drum bearing.
Cost is around £50 for the parts - and around 2 hours labour as it is a fairly long job to replace.
Posted on Sep 30, 2009
The drum seems loose. When it spins to let the water out it will spin good then all of a sudden it will bump loudly
Search Results
    How to Diagnose Drum Problems in a Washing Machine ...
    ? 7:48
    https://www.youtube.com/watch?v=wUL5Wb1T71c
    Nov 19, 2013 - Uploaded by eSpares
    For all your washing machine spare parts go to http://bit.ly/1DumBrv The most common fault in a washing ...
    GE Washer Top Loader Out of Balance Shaking Repair ...
    ? 14:19
    https://www.youtube.com/watch?v=GA98ZmnzEfc
    Jul 12, 2014 - Uploaded by Mike Davies
    GE Washer that Shakes and is Load during Spin Cycle. step by step ... Washer Tub Seal Replacement - GE Top Load Washing Machine ...
    GE Front Load Washer Inside Drum Loose - YouTube
    ? 0:46
    https://www.youtube.com/watch?v=P8EcTTL2lcI
    Apr 4, 2013 - Uploaded by Wayne Meador
    I need help with my GE Front Load Washing Machine!!!! If you or anybody that you know can help me fix this, I ...
    Kenmore top-load clothes washer drum/tub is loose and bangin
Jan 08, 2016 | Washing Machines
My Kenmore front loading washer sounds like a airplane taking off when it is in a spin cycle, is it supposed to sound like that. They are only two years old!!
I can't tell you how many times a year I have that description about a front load washer.
I always find the same problem with them too. The tub seals has let water get into the rear drum bearing making the bearing fail.
Remove the back washer panel and look at the center of the tub. You will often see little trail of grease and water residue from the seal leaking.
If you do not have a extended warranty it's can be a costly repair as you can not just replace the rear bearing. You will need to replace the outer tub that come with the bearing pre installed and often the spinner shaft too.
How to receive the best washing machine repair help on FixYa
Aug 03, 2011 | Kenmore Front Load Washer
My Kenmore Front Loader washer machine is making a loud noise during the spin cycle
tub bearing more than likely.tub has a 10 yr warranty so call sears get the flat rate labor charge their offering then have them replace the tub
Jan 11, 2010 | Kenmore 43042 Front Load Washer
Washer makes loud clunk as it goes around. tub feels very loose. front load Gallery. I thought something in between tub and shroud but nothing. I think tub is loose.
it sounds like you have a broken spinner assembly,
this is the unit that connects your innur tub to you center shaft seal,,,,
it can be replaced and repaired by you no special tools but the cost could be quite extensive....
an outer tub and spinner is an absolute minimum and there are parts to inspect as you take it apart
do you need both halves of the outer tub would be the biggest one
unless this machine is less than just a few years I would just not bother putting the money into it
its well past cost effective 500.00 for the two parts ive mentioned
Nov 02, 2009 | Frigidaire ATF6000ES Front Load Washer
My Kenmore front load 4304 washing machine tub
I would need the complete model # to get you a breakdown showing the piece i believe to be broken and in need of replacement. I believe this Kenmore F.L. was built by Frigidaire and they have had a problem with a specific piece on this machine. I will be glad to help once you get me the full model, should be around the opening of the door.
Oct 25, 2009 | Kenmore 43042 Front Load Washer
Crack in the bottom of my Kenmore washing machine tub
What is the model number? Is this a front loader or a top loader? To answer your question, yes, the tub can be replaced. You need to take a look at your warranty information to see if this can be replaced at no cost to you. Most manufacturer's warranties cover the first year against any major defects. However, some warranties are extended on certain parts. Something you may consider.
If you post back with your complete model number, I can give you an idea on how much a replacement tub may cost you, and if you have to pursue this on your own...I can give you the steps required to replace the tub.
NOTE: Marine epoxy or plumbers goop may work as a temporary fix in the mean time.
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore HE3 Front Load Washer - Leaking Water into wash tub
THE WATER VALVE IN THE WASHER HAS TO BE REPLACED THE COST OF THE WATER VALVE IS ABOUT $25.00
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine
a gibson has a bar with 2 bolts that holds it on the trans shaft .... remove it and keep trying to turn tub till it breaks loose
Sep 20, 2008 | Kenmore 24032\24036 Top Load Washer
KENMORE HE3T BASKET RUBBING ON THE PLASTIC FRONT TUB
if ripped obvioussly youl need to replace the front rubber bellow, i would remove the bottom panel and have a look inside sounds like you have a broken shock aborber or 2 not properly supporting tub assy
Feb 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
