Question about Radio Communications
Fm radio/speakers my fm radio does not work nor my front speakers.The rear seat speakers are fine.Also my cd,cassette and am works.
    Scholar:
  • 143 Answers
Check that there are speakers! stupid as it sounds, sometimes there are just covers with holes behind...
If there are speakers trace the wiring through to the source make sure it has been conected both ends...
Or check the balance & fader on the set.
Posted on Dec 23, 2007
Lost sound on 2005 impala. radio works. seems like amp problem.
Do you have base or up;level system ?
Table 1: Radio Features
Table 2: Cassette Features
Table 3: Compact Disc Features
Table 4: XM Advisory Messages
The radio receives power from the RADIO fuse in the junction block-right I/P. Ground is provided via G201 and G202. The radio is enabled/disabled by class 2 messages from the body control module (BCM). The radio routes audio signals from the digital radio receiver or the vehicle communication interface module (VCIM) to the speakers and/or amplifier when directed by class 2 messages.
The Entertainment System on this vehicle is configured with an AM/FM stereo radio with the radio data system (RDS) and either a cassette player or a CD player or both. CD and cassette. The uplevel system provides the customer with extended range speakers and an audio amplifier. Satellite digital radio (U2K) is available with uplevel systems.
The following list shows the radios available for this vehicle:
• Radio (ULO) - AM/FM Stereo, Cassette with RDS
• Radio (UNO) - AM/FM Stereo, CD and RDS
• Radio (UPO) - AM/FM Stereo, Cassette with CD and RDS .The complexity of the radio systems on these vehicle is mind blowing .
Your best bet take it to a GM dealer , has features you are unawear of .
DTC B1025, B1035, B1045, or B1055
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers.
DTC B1025 Audio Output Circuit
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, monitor the DTC Information for DTC B1025.
Does the scan tool indicate that DTC B1025 is current?
Jan 31, 2017 | Cars & Trucks
04 Infiniti sedan w/ factory Bose. Front speakers are not working (no sound at all) and I adjusted fade all the way both ways. Back speakers are fine. What's up?
If the rear speakers are fine, perhaps I can narrow this down. Fuses must be OK. Steering wheel audio controls connect to the audio unit which has a preamp function. The W/BK outputs connect to the left front inputs of the Bose speaker amplifier; the GRN/RED outputs connect to the right front inputs. Your ear test confirms the front door speakers are not working, therefore there is no front door output from the amplifier. The amplifier stages for the front doors may not be working or no front door amplifier input is being received from the audio unit. The fader and balance controls do not show on the diagram so must be on the front panel. They could be defective. There is a remote possibility of broken/disconnected wires
Sep 07, 2012 | Sony 2003 2004 03 04 Infiniti G35 Bose Am...
I have a 1999 Cadillac DeVille Concours with an AM/FM/Cassette/CD/RDS Radio. The AM works fine, the FM does not, screen shows digital info(stations like 99.3, etc) but no sound. RDS does not function at...
Well there's lots of possible reasons. The FM receiver portion of the radio is separate from the AM Band receiver, pre-amp, and amplifier sections of the radio. The FM receiver may have simply failed, as well as the CD player portion of the radio. Your car FM needs repair, you need a multimeter to check it or take it to a repair person. Please post further comments for further help or information......
Good Luck!!
Thanks
Jul 06, 2010 | Car Audio & Video
I have a 2001 Dodge Ram 1500 that I'm trying to up grade my radio form a A and fm cassette to a dual CD cassette . I need help with wiring because they are different colors.I have the new 16 pin harness...
2001 Dodge Ram 1500 Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Sep 09, 2009 | Durabrand Car CD Player and AM/FM...
ML320 2003-FM radio not working except by turning the volume to maximum and it can only be heard faintly. The AM, cassette, Cd and phone work fine at normal volume. Any ideas??
i was wondering if you were able to find a solution for this. I am currently having this same problem with my vehicle (as a few others as well). if you could please let me know, id greatly appreciate it. my email is josephelara@yahoo.com.
May 15, 2009 | 2003 Mercedes-Benz M-Class
I just purchased a 1990 nissan 240sx and want to replace the radio with a new cd receiver. how do i remove the old radio? it is an am/fm with a cassette player below it.
Just remove these trim pieces (start with the ash tray) I have also included the wiring list
Wiring
Constant 12V+: Red/Black
Switched 12V+: Blue
Ground: Chassis
Illumination: Red/Blue
Dimmer: Red/Yellow
Antenna Trigger: Black/Red
Antenna Left Rear
Front Speakers 4" x 6" Doors
Left Front (+): Blue/White
Left Front (-): Blue/Yellow
Right Front (+): Brown
Right Front (-): Brown/White
Rear Speakers 6 1/2" Rear Deck
Left Rear (+): Red
Left Rear (-): Green
Right Rear (+): Blue
Right Rear (-): Pink
Please rate this a fixya
Feb 02, 2009 | 1990 Nissan 240SX
FM Radio won't work on my Sony Xplode XR-C5300X
Same issue here, hardly used the unit, and have no radio reception, all else works including the CD changer
Dec 14, 2008 | Sony Xplod Car Audio CDX-F7810 - CD/MP3...
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
Radio Communications Logo
52 people viewed this question
Top Radio Communications Experts
Steve
Marvin
Marvin
Are you a Radio Communication Expert? Answer questions, earn points and help others
