Mold My washer is less than 2 years old and gray coloured bladder between the door and on the front of loader tub has mold inside it. I have used every I know to remove the mold and cannot. I dont even know how it go in their
    Genius:
  • 1,036 Answers
This can be a design problem with some models.
The only way to keep on top of it is to use a spray oxygen based bleach product in the gap - and wipe out with a disposible cloth.
Also remove whole drawer assembly for cleaning above and behind the drawer - and as far down the fill pipe as possible.
I found using a foaming product helped a lot with these problems.
Wash a hot wash at least once a week to prevent regrowth - or use the dryer function on combo's to kill off spores.
Some machines are just prone to this problem.
Posted on Sep 30, 2009
Clothes Have a sour smell when dried
The moldy odor in this front loading washer (and most other front loaders, too) and the clothes washed in ti is due to the way the washer are built. There's almost always some water that doesn't get pumped out all the way. The water along with detergent residue left inside the machine is the perfect combination for mold growth between wash days.
First stop feeding mold. Stop using "regular" detergent in it. By regular, I mean anything that isn't an "HE" type. You've got to use the types designated as "HE" (High Efficiency). They suds up a lot less, and due to the significantly less water our front loaders use, actually leave less soap residue (that is a large source of the mold and musty smell) behind the tub of front loading machines. I use only about 1/2 of the HE detergent recommended on the bottle and get very good results.
Second, kill off existing mold. Run a clothes-less wash consisting of bleach and HOT water only 1 X week. This should be the last load run whenever the machine will be idle for a couple days or more.
Third, always wipe dry the inside of the tub, detergent & softener dispensing areas, the gasket around the door - particularly the bottom. Again, this is best after the last load is complete.
Fourth, leave all doors open or slightly ajar to allow for air circulation.
Some products that are designed to rid odors from your washer.
Finally, to remove the existing mold smell from the machine, one or two initial treatments (followed by regular treatments) of a product called "Affresh" (or equal) as directed. Some people have good luck with vinegar, too.
I hope this helps and good luck! Please rate my reply - thank you.
Mar 08, 2011 | LG DLE2101 Electric Dryer
Black stains on door
If it is inside, it is probably mold growing. Front loaders are much more susceptible to mold growth as they seal up tighter, and we all tend to keep the door closed when it is not in use.
Clean the inner door and bellows surfaces with a 50/50 bleach/water solution, applying liberally, and dump the rest into the tub of the washer. Add 1 more cup of bleach to the tub. Fill all of the dispenser cups with bleach. Run the hottest , longest cycle available with the hottest rinse cycle available. For us, it is the "sanitary" cycle. Run a normal cycle immediately thereafter to flush out residual bleach, and leave the door open. The cleaning along with the air drying will keep the mold from growing, and reduce the odors that these machines are famous for. Leave the door open between loads.
Best regards, --W/D--
Jan 23, 2011 | Zanussi FJS1225W Front Load Washer
Front-load steam washer smells like a stale sponge. How do you repair this? It is only a year old and was very expensive. The dryer works fine. Baking soad, vinegar, none of this helps. Thanks.
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Jul 05, 2010 | Washing Machines
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
I heard you are suppose to clean the washer once a month to prevent mold,is that true?
I have never cleaned my washer as i use bleach in with the whites when i wash. its up to you. they do make a cleaner for that.
Oct 31, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
My clothes smell! Less than one year old GE front load!
That happened to me too. Check for mold and mildue around the inside seal, if you find anything BLACK, clean it up. Also, pull out the drawer where the laundry detr is and clean it as well. Also, when the washer is not in use keep the door open, this will cut down on the mold and mildue.
Sep 23, 2009 | GE WSXH208A Front Load Washer
Clothes not fresh as with a topload washer
Call a servicing dealer and see if there is an update for your machine that has an extra circulation hose and port
Jul 04, 2009 | LG WM-2277HW Front Load Washer
Black mold growing on gray rubber boot inside door.
Leave washer door slightly ajar after use to air out any moisture. Should prevent any future mold.
Apr 10, 2009 | Frigidaire Affinity ATF7000E Front Load...
LG WM1812CW washer smell
First, clean out the filter behind the access door on the lower left front of the machine. Residue left in the filter can contribute to odor issues. Second, buy a package of AhFresh or Whilaway and run a cycle with that, hot water, longest cycle. (unfortunately you do not have the sanitary cycle or the tub clean cycle on your model) Third, and most importantly, USE LESS DETERGENT. Top load washers use up to 45 gallons of water per cycle. Your machine uses 12. Use one tablespoon of HE detergent and one teaspoon of fabric softener (if you use softener) per cycle. My personal LG washer is now over 5 years old, and have only had an odor issue one time. I leave the door closed after I wash. (the tub is vented) Never have had any mold or mildew issues with my washer. Was doing several loads per day when I had 7 at home, now only doing 3 loads a week with all the kids, their spouses, and grandkid gone. Still no odor problems. Great machines if used properly. Note: the odor / mold / mildew issues are basically the same with any front load machine, regardless of brand, and most can be solved following the above advise. Good luck.
Oct 22, 2008 | LG WM-2077C Front Load Washer
SMELL IN WASHER MODEL #MAH5500BWW AND BLACK MOLD
If you are using a high efficiency front loader than you suffer from the same symptoms that these front loaders typically have. The infamous bad smell and mold.. This is quite common because the front loaders actually seal the wash tub area with a water proof gasket around the door and left closed, the leftover water that gasket will get musty and if left untreated, may develop mold. Home Depot sells AFFRESH tablets that you cycle thru the qwasher about once a month and that usually does the trick.. The less desirable method is to wipe the gasket area with a towel or equivalent and leave the washer door open or partially open to air dry. That's been my experience.. Hope that helps !
Jul 24, 2008 | Maytag Washing Machines
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
