Question about Nikon D90 Digital Camera with 18-105mm lens
When trying to use my camera with ring flash, and 105 macro, an r17 error displays. I know It has something to do with the buffer memory, but still, It doesnot work. can anybody help me
4 Suggested Answers
SOURCE: Memory buffer error - r07
I have the same problem with mine, unbelievable. desparate!
Posted on Jan 29, 2008
jcdill
  • 121 Answers
SOURCE: camera will not shoot a picture
The F-- error means the Auto Focus in the lens can't communicate with the CPU in the camera. Because you also have problems with the flash not popping up, I'm not optimistic that you can fix this yourself. Odds are high that you will need to send it in for repair.
The F-- error could be caused by many things. First, try removing and replacing the lens - the contacts between the lens and the camera may not be connected properly. Also try shutting the camera off and removing the battery, then replacing the battery and turning the camera back on (rebooting the camera) as this sometimes helps. If neither of these help, the next step is to remove the lens and carefully (CAREFULLY) clean the contacts on both the lens and the camera. Gently rub the contacts with a clean pencil eraser and hold the item upside down over a table so that any debris from the eraser will fall onto the table rather than into the camera or lens.
If none of these fix the F-- error then you may have a hardware failure in the camera body itself. If so, the only fix is to send it in for repair - you can't access the interior parts of the camera without special tools that only the repair facility has.
Posted on Dec 18, 2008
tonyy168
  • 45 Answers
SOURCE: New Nikon D90 with 18 105 lens ring broken
the repair is not expensive, should be around $200 or less, provided that you did not damage the internal glasses and mechanics and sensors. You will need a receipt to repair it at Nikon USA, or goto an authorized repair center to get quote.
Posted on Sep 15, 2009
Error code r17
Is this keeping the camera from shooting? Normally the "r" message shows up when shooting to tell you how many more shots you can take in the current burst before the buffer fills up.
Dec 27, 2012 | Nikon D3100 Digital Camera
Shooting with a D300, outdoors, landscapes - usually in Manual - I get the R17 flashing and the shutter release won't work. If I wait a while - 2-3 minutes sometimes, it goes away and I can resume...
To me you have two unrelated problems. The r17 if shown in the lower right is amount of reserve frames you can make in a burst with the lighting conditions. The number should change as you "burst" shot continuously. Another way of putting it is the amount of pictures that the buffer can handle before stalling the camera. Don't forget to that the camera is writing to the memory card as well as the buffer so this number is going to fluctuate.
Okay now for the shutter not releasing. Your camera requires contrast to focus not contrast no focus. So while doing landscapes you may have huge expanse of sky (no contrast) maybe water, bright sand, white clouds, infinity or all of the above. Your camera focus needs some contrast. so what I do in this situation is grab a focus well into the scene somewhere switch to manual and recompose the shot and take the picture in manual focus mode. I'll tell you were else you will have problems if you are talking about weddings is a bride's white dress Good Luck with that one. You need an edge of contrast or the camera just thinks it's looking at a painted wall.
Jan 13, 2011 | Cameras
Metz 15 MS1 Macro Ring Flash with Panasonic Lumix G1 4/3rd Camera
Set camera to manual exposure. Set Shutter below 60 Set F Stop until exposure is correct.
atdlee@netzero.com
Feb 08, 2010 | Metz 15 MS1 DIGITAL MACROFLASH TTL Ring...
Nikon d80 problem (err flashing with r09 in the lcd display)
I belive this isn't a fault but more to do with how you are using the camera. The r09 message is to do with the camera buffer and how many more pictures it can hold. You do have a memory card installed, right? The r09 is normally not an error, but simply an indicator of how many more pictures you can take in the current burst before the buffer fills. The number will vary according to the image quality and size settings.
Jan 17, 2010 | Nikon D80 Digital Camera
What would be ideal settings for canon 500d for dental photograph
That's the beauty of digital photography. It doesn't cost anything to experiment. You'll learn more by discovering it for yourself.
Oct 19, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Nikon D80, how do you turn off the r09, r11 and/or r17 alert (depending which Image Quality setting I have the camera set to)? I have sent the camera back to Nikon twice and twice it has come back with the...
The r09, r11 or r17 just tells you how many pictures you can shoot before the internal memory buffer is full. It's not an error message, and I don't think there's any way to turn it off.
Sep 29, 2009 | Nikon D80 Digital Camera with 18-135mm...
Canon Powershot S2 IS Super Macro mode
Make sure your camera isn't zoomed in (full telephoto) The camera can't handle both full zoom AND super macro. Don't forget super macro goes from Zero to 20cm from the lens. Zoom completely out and you should be able to see something within that range. The biggest complaint I've heard about the S2 IS is if you take closeups of bugs the chances of the bug crawling onto your lens is pretty good.:-) Be very carefull of blocking light with the lens at extreme closeup too. Although the flash squelches well to allow for closeups it can leave a nasty shadow. If you're really serious about macro you'll find a ring flash would come in handy. BMW
Jul 13, 2006 | Canon PowerShot S2 IS Digital Camera
Can the conventional Maxxum/Dynax flash units be used with this camera?
Yes. The following Minolta dedicated external flash units are compatible with the DiMAGE A1 for automatic flash control: Program Flash 3600HS(D), Program Flash 5600HS(D), *Program Flash 2500(D), Macro Twin Flash 2400*, Macro Ring Flash 1200*. * Program Flash 2500(D) will be available around August, 2003. *Macro Flash Controller is necessary
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
With Macro flash unit attached, and using the closest subject distance, images are extremely over-exposed.
The camera fails to control the flash output automatically due to the high intensity of Macro ring flash, causing the image to be over-exposed. Please set the camera as below to prevent a undesired result. Camera and Flash Settings - Set the sensitivity to ISO 100 using the function dial of the camera. - Set the flash metering of the camera to Pre-Flash TTL from the recording-mode menu. MACRO RING FLASH 1200 - Set the camera exposure mode to A or M mode. - Set the aperture to f/6.7. - Attach a ND filter x4 (0.6D) to the camera lens. MACRO TWIN FLASH 2400 - Attach a diffuser to the flash tube units. In case the flash tube and the subject is too close, eg. Not using the arms, set the camera exposure mode to A or M mode and the aperture to f/6.7. A subject at minimum distance may still be overexposed. Use exposure compensation to obtain the best result.
Sep 15, 2005 | Konica Minolta DiMAGE 7 Digital Camera
"r7" Error Code
If the camera works OK, then the r7 means that you have room in your memory buffer for 7 more pictures to take ("remaining 7"). As soon as you take a new picture, it gets transferred instantly to memory compact flash memory, and again r7 will display. The instance when there is r6, r4, etc. is short lasting, that you would not notice. Change you camera setting, let say for small size JPG, and you should see that many more files will fit in the buffer, as indicated by a larger number after the letter r.
Sep 14, 2005 | Nikon D70 Digital Camera
Nikon D90 Digital Camera with 18-105mm lens Logo
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
